Question about NADEA N300R Digital Camera
Windows Xp driver
Windows Xp device driver
  • 23 Answers
I recommend going to the manufacturer's website. They almost always have free driver downloads for their products.
Posted on Dec 12, 2008
How to restore original windows on a toshiba satellite a105-s4184
I have toshiba laptop satalite with 2 operation windows 2000 and HP windows running thus slowing the system down consiradably. Idealy would like to delete the windows 2000 professinal. Please help
Sep 26, 2011 | Computers & Internet
My Akai Mpk25 works fine on my windows 7 system. When i plug the usb into the windows Xp system it asks for drivers which are not present. Help plz
You would need the manufacturer's device driver for Windows XP. Although it appears Windows 7 has the driver pre-built in, Windows XP does not have a lot of drivers for modern devices.
Got o Akai's website and download the drivers and install them on the Windows XP system and you should be good to go!
Feb 05, 2011 | Akai MPK25 Compact 25 Key Keyboard Storage...
How do i update my sound drive for free
1. Windows XP Update:
To update the sound card driver, follow these steps:
  1. Click Start, click Control Panel, and then double-click System.
  2. Click the Hardware tab.
  3. Expand Sound, video, and game controllers.
  4. Double-click the sound card, and then click the Driver tab.
  5. Click Update Driver.
  6. Follow the Hardware Update Wizard to update the sound card driver.
Another Option: Download From Web Link:
http://drivers.softpedia.com/
Jan 29, 2010 | Microsoft Windows XP Home Edition
Canon Canoscan D1259U2F dont have any driver for Windows 7 64-bit
the only successful method I found for using CanoScan D1250U2F in 64 bit Windows 7 (I guess the same would be for 64 bit Vista) is to use Windows XP Mode in Virtual PC (attach the scanner as USB device and that's it - works perfectly)
I had a problem with Windows 7 detecting the device as CanoScan (needed for Windows XP Mode to detect is as USB device and allow attach) - the solution was to unplug the scanner, plug it in and CANCEL Windows 7 hardware detection process before it finishes - this leaves it as "CanoScan" device (auto-detect will leave it as "Unrecognized device" and with that unusable/un-attachable in Windows XP Mode)
latest versions of Windows XP Mode will make your hard drives accessible as network locations (no need for external media)
Jan 01, 2010 | Canon CanoScan D1250U2F Flatbed Scanner
How to install usb
After you install Microsoft Windows XP Service Pack 2 on a computer that is running Microsoft Windows XP, the universal serial bus (USB) drivers do not appear to update. CAUSE After you upgrade from Windows XP to Windows XP Service Pack 2, the USB drivers... loadTOCNode(1, 'cause'); After you upgrade from Windows XP to Windows XP Service Pack 2, the USB drivers appear with the earlier version numbers, even though the files have been updated. uparrow.gifBack to the top RESOLUTION To resolve this problem, install Windows XP SP2, and then update the drivers for... loadTOCNode(1, 'resolution'); To resolve this problem, install Windows XP SP2, and then update the drivers for the USB devices that are connected to your computer. To update these drivers, follow these steps:
  1. Click Start, click Run, type devmgmt.msc, and then click OK.
  2. Double-click the type of device that you want to update.
  3. Double-click the specific device that you want to update.
  4. Click the Driver tab, and then click Update Driver.
  5. Follow the instructions in the Hardware Update Wizard.
  6. Repeat steps 2 through 5 for each USB device.
Note You can also install Windows XP SP2, and then disconnect and reconnect the USB devices that are connected to your computer. By doing this, you start the Plug and Play utility. The Plug and Play utility updates the version numbers for the drivers.
May 08, 2009 | Microsoft Windows XP Home Edition
Drivers for HP pavilion with win xp
HP does not offer Windows XP drivers.
But, the chipsets on the HP computer are made by 3rd party companies. So, you mighty find out, for example, who makes the Audio chip and on their website find generic drivers for that chip, that will work in Windows XP.
Here are some I found:
Nvidia Chipset GeForce 6150SE nForce 430 (mutiple drivers) XP DRIVERS
Realtek High Definition 8-channel audio, ALC 888S chipset XP DRIVERS
Have you already installed Windows XP on the computer? If so, did you look in the Device Manager to see what devices have problems or undefined devices with question marks?
Nov 30, 2008 | Computers & Internet
BCCode Error
CAUSE loadTOCNode(1, 'cause'); You may receive this error message when Windows attempts to use device drivers that are incompatible with Windows XP. uparrow.gifBack to the top
RESOLUTION loadTOCNode(1, 'resolution'); To resolve this issue, verify that each device in your computer uses a driver that is compatible with Windows XP. To do so, follow these steps: 1. Click Start, right-click My Computer, and then click Properties. 2. In the System Properties dialog box, click the Hardware tab, and then click Device Manager. 3. For each device, use the following steps to verify that it is using a Windows XP-compatible driver.NOTE: To narrow down the search, begin with devices that have been disabled. A disabled device has its icon overlaid with a red X.
a. Double-click the device name to open the device Properties dialog box, and then click the Driver tab. b. Examine the driver version. All Windows XP drivers should be version 5.1.2600 or later. c. If you are not sure about the displayed version, examine the driver date. Drivers created before the year 2001 may not be compatible with Windows XP. 4. After you identify an outdated device driver that may be causing the problem, follow these steps to update the driver: a. Insert your Windows XP CD into the CD-ROM drive. If Setup starts automatically, quit it. b. In the device Properties dialog box, click Update Driver to start the Hardware Update Wizard. c. Click Install from a list or specific location (Advanced), and then click Next. d. Click to select the Include this location in the search box, and then type your CD-ROM drive letter in the space below. For example, type D:. e. Click Next. f. Follow the on-screen instructions to finish updating the driver. 5. Restart your computer if prompted.
Sep 20, 2008 | Microsoft Windows XP Professional
Installing xp on acer aspire m1610
First you want a Windows Xp genuine CD and most of the drivers are built-in in Windows xp, also try to install windows xp with service pack 2 and after installation go the device manager and see how many device required drivers as you can see them with exclamation marks or question marks. go to google and download the device driver run it inside your pc also i recommend before you do got to device manager and indentify all your dirvers like VGA Sound and other devices
Jul 02, 2008 | Computers & Internet
Lenovo driver problem
Check the following location for the drivers for your Ideapad Y510.
http://consumersupport.lenovo.com/en/DriversDownloads/drivers_list.aspx?CategoryID=12
The drivers for lenovo y410 will not work for your laptop.
In fact most of the XP drivers at the above link were available since December 2007
Hope this helps.
Dec 27, 2007 | Computers & Internet
NADEA N300R Digital Camera Logo
Top NADEA Cameras Experts
Are you a NADEA Camera Expert? Answer questions, earn points and help others
