Question about Western Digital 250GB ELEMENTS EXTERNAL USB 2.0 250 GB Hard Drive
Help! the green light flashes then nothing happens
Switched it on Green light flashes and goes off power seems to have died help. Will I need to replace the black bit? It has been working fine since last xmas. :(
  • 2 more comments
  • Anonymous Dec 15, 2008
    I have the same problem but when I mail to WD services, I got no answer!
  • chuffingell Jan 18, 2009
    Have a WD 500GB Elements External USB drive. Green light flashes on power supply. Drive not spinning. PC does not detect. Will contact WD and let you know the response.
  • FGub Jan 24, 2009
    the power supply problem for the WD Elements HD, was it solved with the new power supply that you got from WD? I have exactly the same problem...
    Thanks, FGub.
  • Anonymous May 18, 2009
    Mine has just done the same thing today, went to bed last night, awoke. Will contact them tomorrow, about the power supply. The warrenty is still around, went to a couple of computer stores, they tested it with other power supplies and it works fine. So, hopefully, I can get a new cable. Since I can't find it anywhere (I am based in the U.K)
Exactly same problem with my 10 month old WD elements 500 GB. Got a new power supply FROM THE DEALER (waiting 3 weeks). Plugged it in and ........ guess what! NOTHING - SILENCE. Only a short green blink from the (NEW) power supply, as from the old one.
To finally get back the stored data, I dismantled the case and use it as normal HD with SATA connector.
Posted on Dec 06, 2008
The exact same thing just happened to me (WD elements 500 gig) and it's only about 10 months old. I called the customer help line (on the official website) and after they asked me what the serial number of my HD was they were going to send me a new power supply. Simple as that. They said they'd be able to send it out early next week. I'm hoping that the HD didn't get fried and it's just the power supply but what you've described is EXACTLY what is happening to mine.
Posted on Nov 03, 2008
Trying to replace lamp in HDTV and having trouble. Does not function correctly after putting in new bulb. Boots up and then visuals go black and the green power light keeps flashing. Help?
Panasonic DLP TV Bulbs
Make sure its an original Osram or Philips bulb inside the housing. If its a cheap lamp it will act this way. If it is an original lamp, then you may have a power supply issue. It shouldn't affect your TV but you may want to try resetting the lamp timer by following the instructions that came with the lamp.
TY-LA1001 Timer reset
While pressing the VOL- button on the projection display, hold down the number 0 button on the remote control at the same time for more than 5 seconds.
Aug 15, 2015 | Panasonic Pt-52lcx16 Projection Television
Optoma HD66 replaced lamp, LAMP WARNING light keeps flashing, still won't turn on?
i just had the same problem i took the top of the projector off and cleaned the color wheel and sensor seemed to have fixed the problem that is for now. seems to happen to me once a year on the dot but last time it was warranty. good luck hope it helps.
Mar 17, 2012 | Optoma Office Equipment & Supplies
When connecting up to charge red light comes on 'power on' button on front and no charging happens - any ideas? thanks
What does indicator light mean?
  • Steady red light: Battery is charging.
  • Steady green light: Battery is fully charged.
  • Flashing red light: Battery needs charging.
  • Flashing green light: The music receiver is switched on.
  • Flashing red/green light: The music receiver is available to be added to your phone.
Aug 24, 2009 | Sony Ericsson T303 Mobile Phone (Shadow...
Compaq Presario 5000 won't turn on
The machine is getting the power but no display.This seems a RAM or motherboard issue.
1.Press and release NUM Lock after turning on and if it is responding this is a RAM issue and if not then the mainboard issue but before all refix the RAM once.
Thank You.
May 30, 2009 | HP Compaq Presario SR1830NX PC Desktop
Vizio P50HDM No Picture/No Sound
this is most likely the sustainer board(s) problem. Replacing the sustainer boards should correct this problem for you. you can get the parts at
May 29, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
replace the sustainer boards should correct this problem. New sustainer boards may cause red and green pixilation. If this happen, replace control board and TV is as good as new.
Apr 05, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
I opened the transformer up, and found a lot of corrosion on the board, creating a short circuit between tracks. This corrosion was caused by poor workmanship in the manufacture. This board never had the fluxes cleaned off after soldering. I will be contacting Western Digital and requesting a replacement transformer. I suggest everybody with this problem should do the same.
Jan 27, 2009 | Western Digital 500GB ELEMENTS 500 GB USB...
Viewsonic VA903b Flashing green light (slow)
It's seems you got a busted backlight inverter problems... Need replaced with a new one. Happy Holidays!
Dec 03, 2008 | ViewSonic VA903B Monitor
Green light
check horizontal o/p&osc
Mar 11, 2008 | Televison & Video
Western Digital 250GB ELEMENTS EXTERNAL USB 2.0 250 GB Hard Drive Logo
2,354 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
