Question about Sony KV-32DX20 32" TV
Flashing LED code plus odd screen info display problem
Standby LED flashes five times at irregular intervals. Screen info displays picture mode, channel number and stereo/mono status at irregular intervals. Picture has faint greenish tinge. Any ideas? Just need to sound like I know whats wrong when I ring the service outlet so I don't get ripped off too badly. Thanks. Zakk
  • 556 Answers
SOURCE: Sound, but no picture. Standby light blinking 5 times
A few weeks ago my set started flashing to a black screen. Now a couple of weeks later, i have no picture, but the set turns on and i have sound. The standby light is flashing. I purchased the set in 2000 so it is seven years old. This is the first problem. Could it be all three of the bulbs? Could it be all three of the bulbs? no as you say that sound is ok that means your power supply &high voltage section is ok. please check chroma ic luminance section or system control section stand by ckt ihanks
Posted on Sep 11, 2007
SOURCE: SONY - TRINITRON 26" TV (PICTURE TUBE TYPE)
I have the exact same problem! I'm assuming it's time for a new tv.
Posted on Oct 25, 2007
  • 9 Answers
SOURCE: RE: Flashing "Standby" light
Go here http://www.avsforum.com/avs-vb/showthread.php?t=928945&page=4
for my post #108 for a step-by-step solution with pictures. $21.83 is all it cost me. I fixed my own TV as many others on that forum have. Feel free to contact me at eclipsedave@yahoo.com if you run into difficulties.
-Dave
Posted on May 12, 2008
  • 4234 Answers
SOURCE: KV27S42 problem
The 2 blinks is an indication of overcurrent. That translates into a short somwhere inside the set. since you can get sound but no picture, that suggests that the problem is in the high voltage section. The most common failure there is the Horizontal Output Transistor. This is a 3 legged part attached to a heatsink close to the flyback transformer (part with large red wire coming out the top). That part should be marked C5438 or something similar. Post the marking here and I'll give you the complete part number.
Dan
Posted on Aug 01, 2008
cactus bob
  • 267 Answers
SOURCE: Sony KV-32s40 (picture flashes in and out)
YOUR CRT (PICTURE TUBE ) IS GOING BAD . this is the most common way a sony tv crt fails . the tv is to old to make it worth a crt . but if your handy and carefull there is a way to get a little more time out of it . start with the tv cold , remove the back and look on the little board connected to the neck of the crt . there is a control marked "SCREEN " plug in the tv and cable and start it , with it flashing adjust that control , one way will make it flash more and one way less , adjust this no more than you need to , just enough to stop the flashing .NO MORE ! just be carefull the voltages in a tv can KILL . dont touch anything else in there and use a little inslated screwdriver to make the adjustment good luck .... if this answer helped please leave me 4 stars rateing , this high rateing will keep me in the paid answer department , thank you
Posted on Jun 21, 2009
I just changed the oil and filter on my LX420 twin cam how do I get the blinking light to go out. Its a 2006
  • The Service Monitor meter contains a service minder function that utilizes the 4-digit LCD display.
  • The letters "CHG" will display followed by the letters "OIL" and then followed by the meter accumulated time.
  • CHG"/"OIL"/TIME will alternate on the display for five (5) minutes after the meter reaches 50 hours.
  • While the LCD is displaying the "CHG"/"OIL"/TIME letters, the red LED "oil symbol" will also be flashing for the entire five (5) minutes.
The display will also flash as described above for five (5) minutes every time the tractor has been started during the maintenance time interval. The interval will occur every 50 hours and will be in effect for two (2) hours.( Example: this feature will display from 50-52 hrs., 100-102 hrs., 150-152 hrs etc...)
THE METER DISPLAY WILL RESET TO NORMAL AUTOMATICALLY, after the reminder maintenance time interval of two (2) hours. There is no method of manually re-setting this Service Monitor gauge.
May 01, 2017 | Cars & Trucks
I HAVE A SONY-KV-ES34M61TV,PICTURE GOOD,SOUND GOOD BUT LIGHT BLINKIG FIVE TIMESWHEN NOT PICTURE ON TV SCREEN FLESHING LIGHT IS STOP, PICTURE GOOD,SOUND GOOD BUT IN SELF DIAGNOSTIC SCREEN DISPLAY 005:255,IT...
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Type in the brand name of your device, in the search box [at the top right] of the display window, and press enter to get all related posts. It will make surf easy.
Feb 11, 2015 | Sony Televison & Video
520230. 31520193. 7Polaris 550 Xp eps 2009About 20 hours on unitStored indoorsI understand one code is Idle air and the other is power steering is disabled or not functioning. First I would try and...
Diagnostic Mode
The diagnostic mode is for informational purposes only. Please return your ATV to your dealer for all major repairs.
As long as the gauge is in the diagnostic mode, the wrench icon will remain lit.
To leave the diagnostic mode, turn the key switch off and on.
NOTE: Any movement of the tires will also take the machine out ofthe diagnostic mode.
To enter the diagnostics mode:
1. Turn the key switch off and wait 10 seconds.
2. Set the park brake and shift the transmission to neutral.
3. Hold the mode/reverse override button and turn the key switch on.
4. Release the switch as soon as the display is activated.
The initial screen display refers to the software version installed in
your ATV. This information is displayed briefly.
Use the mode/reverse override button to toggle through the diagnostic
screens.
Screen 1: Battery voltage
Screen 2: Tachometer
Screen 3: AWD diagnostic
This gauge indicates whether or not current is flowing through the
AWD coil (only on models with switchable AWD).
Screen 4: Gear circuit diagnostic
This screen displays the resistance value (in ohms) being read at thegear switch input of the gauge.
46 FEATURES
Instrument Cluster
Rider Information Center
Diagnostic Mode
Screen 5: Programmable service interval
The purpose of the programmable service interval is to provide the consumer and dealer with a convenient reminder for routine maintenance. When your vehicle leaves the factory, this feature is set at 50 hours. You must enable the programmable service interval before it
can be used.
Once the service interval mode is set with the hours when service is due, the hours of actual engine operation are subtracted from the set
hours until 0 is reached. When the counter reaches 0, the wrench icon will flash quickly for 5 seconds each time the vehicle is started as a reminder that the periodic maintenance is due.
To set the hours, press and hold the mode/override button until the wrench icon flashes. When it begins to flash, release the button. The setting will increase by one hour each time the button is pressed.
Pressing and holding the button will allow the numbers to escalate much faster. When the desired time increment is displayed, release the button and wait for the wrench to stop flashing. When the wrench stops blinking, your service hours are set.
NOTE: If you scroll past the intended number, hold the button down until the count turns over to 0. You can then reset the number.
If the service interval is enabled on your ATV and you wish to turn it off, toggle to the service interval mode. Press and hold the mode button for approximately 7 seconds until the word OFF appears in the
Rider Information Center.
Jun 28, 2013 | Polaris 2009 Sportsman 550 EFI XP With EPS
Dell backlight indicators
A computer monitor has a front-mounted LED that displays its current status and flashes in the event of an error. When an error occurs, the flashing may be accompanied by an error message on the screen. If the screen does not display an error message, the problem most likely falls into one of four common categories.
Unsupported Display Mode A video card has the ability to send output to the monitor at many display resolutions and refresh rates. However, no single monitor is capable of supporting every possible display mode. When the video card sends an unsupported display mode to the monitor, the monitor shuts off to prevent damage and blinks, or displays an error message. Standby Mode b> When a monitor detects no video signal from the computer, it assumes that you have turned the computer off and enters standby mode to reduce power consumption. Dell and HP monitors display an amber light when in standby mode. The status light on an Apple monitor blinks slowly. Incorrect Power Supply Some monitors such as certain Apple Cinema and Studio displays use external power adapters. Because different power adapters may have similar connectors, these monitors are designed to detect when an incorrect power supply is connected and blink the status LED rather than attempting to turn on. In the case of an Apple display, the LED blinks in an alternating short and long pattern. b> Backlight Failure b> A flat panel LCD display has an LED or fluorescent backlight that illuminates the pixels and makes it possible to see the contents of the screen. If the backlight fails and requires replacement, the monitor is unable to display any information. In some cases, you may be able to resolve this issue by turning the monitor and computer off, disconnecting and reseating all cables. If the monitor still has a backlight issue, it requires professional service.
Jan 14, 2013 | Computers & Internet
The TV keeps going into standby mode , comes back to proper picture and with-in 15-20 seconds goes back into standby mode. It happens continueously.
May I know if the standby led light at the front panel is blinking, if so please count how many times it will flash to determine the error code? If not follow the steps below.
In standby mode press the button of the remote control in sequence, " Display ", " Channel 5 ", " Vol (-) ", " Power ". Self diagnosis screen will displays. Le me know the result.
Jdvillanueva
Sep 02, 2011 | Sony Grand WEGA KF60XBR800 60" Rear...
How do i reset the change oil light on a 1040 cub cadet 1000 series
The Service Monitor meter contains a service minder function that utilizes the 4-digit LCD display. The letters "CHG" will display followed by the letters "OIL" and then followed by the meter accumulated time. "CHG"/"OIL"/TIME will alternate on the display for five(5) minutes after the meter reaches 50 hours. The display will also flash as described above for five(5) minutes every time the tractor has been started during the maintenance time interval. The interval will occur every 50 hours and will be in effect for two(2) hours ( Example: this feature will display from 50-52 hrs., 100-102 hrs., 150-152 hrs etc...). While the LCD is displaying the "CHG"/"OIL"/TIME letters, the red LED "oil symbol" will also be flashing for the entire five(5) minutes. The meter display will return to normal function automatically after the reminder maintenance time interval of two(2) hours.There is no method of manually re-setting this Service Monitor gauge.
Aug 30, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Turns on/off
Sony Blinking Codes
Many of the later model Sony TV's have a built in Self- Diagnosis function. If
the timer/standby indicator is blinking, this could be an indication of the
problem with the unit. The diagnostic blinking will occur automatically with no
action required by you to engage it.
The timing of the blinking you see would be as follows: two to eight blinks
(depending on the fault) about a third of a second apart, then pauses for 3
seconds, then the two to eight blinks about a third of a second apart again.
Here is a list of the problems that might have occurred indicated by the
number of blinks. The words in parentheses are those which you will see for
each of these faults on a diagnosis screen described later in this article.
Unit is dead and there are no blinks---Problem in the standby power
section. Might check fuse, R607, Q601, IC601, R612 and VDR601 (should
show open)
Continuous Blink Once A Second, No Pausing As IC301 (data bus is busy, shorted to ground or held
high), IK video path is defective.
ONE Blink--- not used for the self-diagnosis
TWO Blinks---B+ over current protection (OCP) , unit goes to the standby
mode then displays the 2 blink fault. Could be a short in the power supply of
any of the circuits.
THREE Blinks---B+ over voltage protection (OVP), unit goes to the standby
mode then displays the 3 blink fault. This is also a problem in the power
supply circuit, check T603 and R672.
FOUR Blinks---No Vert. Deflection (V STOP), Screen goes to a single
horizontal line then the video signal muted. Check IC1509, Q1505
FIVE Blinks---AKB circuit (AKB), the timer/standby indicator blinks for about
30 seconds then goes to the self-diagnosis function. Something is wrong with
the video. Check video out, Q705, 732, 761 and other components on the C
board, also check Q218, 219, 220 on the A board. Also unit be in IK blanking,
try turning up screen slightly.
SIX Blinks---No Horizontal (H STOP), no raster, goes to the blinking selfdiagnosis
function immediately. Check C515 & 516 and the jungle IC, IC206.
SEVEN Blinks---High voltage shutdown. The high voltage has exceeded 33k
and the unit goes immediately into safety shutdown. Check power supply
regulation and horizontal circuits.
EIGHT Blinks---Problem with the audio (AUDIO), unit goes to standby and
blinks the self-diagnosis code. Check IC406 audio amp, PS401 and 402.
Intermittent problems ?? This is a great feature. You can also bring up
these fault codes ON-SCREEN to see a list of the problem numbers with the
abbreviation of the problem and the number of times this problem has
occurred. This is slightly different than entering the service mode. To see the
diagnostic screen, Press the following buttons:
Display, Channel, 5, Vol Minus, ( Not plus ) then Power. This brings up
a screen with a list of the problems and number of times they have occurred.
Each of the problem names is abbreviated as, "OCP", "OVP", "V STOP", ETC.
We have repeated them in parentheses in the text for the "Blinks" described
above so you can correlate between the diagnostic screen and the blink
codes.
So, now that you know about these self-diagnostics, how do you use them?
Say that you have a set with a black screen. You see that the LED is blinking
4 times....This would tell you that you have no vertical and that is why the
video is muted. If it was blinking 6 times, you would know that you have a
horizontal fault.
It's not a sure cure, but it's a little better than a poke in the eye with a sharp
stick.
IMPORTANT: after you repair the unit, PLEASE clear the values on this
diagnostic screen. These codes do not reset themselves after the fault is
corrected, so if you don't clear them, you'll be seeing "old" fault codes the
next time you enter this screen.
Clearing is done by going into the service mode ( display, channel, 5,
volume plus, then power ) then press 8 and Enter, which of course returns
everything to the factory preset condition.
Apr 25, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
BRAVIA KDL-V32A12U PICTURE LOSS
THREE Blinks
FIVE Blinks
30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. Also unit be in IK blanking,
Jun 19, 2017 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Getting out of standby mode
That blinks and flashing have a diagnostic code;
Here is a list of the problems that might have occurred indicated by the number of blinks. The words in parentheses are those, which you will see for each of these faults on a diagnosis screen described later in this article.
  • Unit is dead, No blinks - Problem in the standby power section. Might check fuse, R607, Q601, IC601, R612 and VDR601 (should show open).
  • Continuous blink once a second, no pausing - No reply from the jungle IC301 (data bus is busy, shorted to ground, or held high), IK video path is defective.
  • One blink - not used for the self-diagnosis
  • Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
  • Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
  • Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
  • Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206.
  • Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
  • Eight blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback transformer), or the associative components in the high voltage circuits are defective on the D board.
  • Nine blinks - Replace D 6116 and D 6301 on the "G" board, do not resolder as this will fix the problem temporary. Or Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -12 or -13 (negitive).
  • Ten blinks - Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board.
Intermittent problems? This is a great feature. You can also bring up these fault codes on-screen to see a list of the problem numbers with the abbreviation of the problem and the number of times this problem has occurred. This is slightly different than entering the service mode. To see the diagnostic screen, press the following buttons: Display, Channel, 5, volume Minus, ( not plus ) then Power. This brings up a screen with a list of the problems and number of times they have occurred. Each of the problems named, are abbreviated as, "OCP", "OVP", "V STOP", ETC. We have repeated them in parentheses in the text for the "Blinks" described above so you can correlate between the diagnostic screen and the blink codes.
Now that you know about these self-diagnostics, how do you use them? Say that you have a set with a black screen. You see that the LED is blinking four times. This would tell you that you have no vertical sweep, which is why the video is muted. If it was blinking 6 times, you would know that you have a horizontal fault. It's not a sure cure..
IMPORTANT: After you repair the unit, you MUST clear the values on this diagnostic screen. These codes do not reset themselves after the fault is corrected, so if you don't clear them, you'll be seeing "old" fault codes the next time you enter this screen. Clearing is done by going into the service mode (display, channel, 5, volume plus, then power ). Press 8 and Enter, which returns everything to the factory preset condition.
Hope it may help you;
Regards,
VOTIT
Aug 19, 2008 | Sony FD Trinitron WEGA KV-36HS500 36" TV
Televison & Video Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
