Hi, Is it possible that I can source a replacement front flap for a Honeywell ST6400C programmer. I believe the part No is 42009012-001 as indicated on the inside of the flap. Basically the hinged lugs have broken on the flap. Please advise. Kind regards, Steve Wright 07743 129821 steviepw@btinternet.com
  • Anonymous May 16, 2009
    Please advise.
    Kind regards,
    Gill Wilson
2 Suggested Answers
Therinnaiguy
  • 1420 Answers
SOURCE: Replaced thermostat on FA4ANF030 with Honeywell model rth3100c does not work
4-wire typical wiring of a thermostat is: Y (Yellow) G (Green) W (white) and R (red). Inspect the thermostat to see if it has a jumper from R1 to R2. If not, put your red wire on R2. On a 5-wire thermostat you may have a blue wire. This will go to the common terminal (usually C but sometimes B) check the inline fuse in the air handler to see if it has blown. Replace it only after wiring the thermostat correctly.
Posted on Dec 03, 2007
  • 40 Answers
SOURCE: Replacing a thermostat on a
your new t/stat need to be configured the best solution is to call tech support they are great I;am an A/C tech and I call them anytime I have a problem 1800 468-1502
Posted on Apr 13, 2011
Replace a honeywell t822l1000 with a programmable unit
Match the thermostat wires to the letters on the new thermostat terminals R Red Y yellow ETC.
Nov 16, 2014 | Honeywell T827K1009 Mercury Free EconoStat...
Our programmable thermostat turns to celcius. How do I change it back to fahrenheit?
Here is a tip that tells you how to get a manual for most any Honeywell product online...
Manual Honeywell How to Find Honeywell Manuals
heatman101
Jan 16, 2011 | Heating & Cooling
Need a manual on how to programme the heating
heatman101
Nov 01, 2010 | Heating & Cooling
How to program the honeywell 24 hr programmer model st699B1002
Here is a tip that tells you how to get a manual for most any Honeywell productonline...
heatman101
Sep 26, 2010 | Heating & Cooling
Looking for an owners manual for a digital programmable Honeywell thermostat-model CT3455A4443
you can get that online at honeywell,local hvac supply houses, and by calling the 800 # that should be online and in your stat please rate my comment and give me a vote I just started this
Sep 15, 2010 | Honeywell Heating & Cooling
Heating & Cooling Logo
308 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Cris Sparks
Cris Sparks
