Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
Problems when i try to turn the television on, t the standby/timer light flashes and the and that is all the i get. the television will not turn on. kv-32fs120 32". is this fixable?
  • 1 more comment
  • hatebreedins Nov 02, 2008
    same problem on my sony wega that is the standby light blinks 6 times..
  • chrctr_zero Nov 03, 2008
    Press POWER button > Sound comes on > STANDBY light flashes 3
    times > Set shuts off > Standby light flashes 4 times after set
    shuts off, then continues to flash in groups of 4 (On, Off, On, Off,
    On, Off, On, Off, Pause) this repeats continuously after the set is off.
  • wushu12003 Nov 11, 2008
    i turn on the tv and no picture comes on, i have in the past waited a whole 2 days for the picture to come on. Upon turning the set on the sound comes on but no picture.
    The ligth flashes in series of 4 and then stops.
    I have had it repaired twice and i was told that the voltage into the set would need to be increased and that the inline output transistor would need to be replaced which it was and this did indeed offer a solution for a few months and then the tv was turned of one night and since then it has not turned back on since.
    The set is nearly 10 years old and i have never had any problems with it and so i have not wantewd to throw it away as it was excellent and also that it was surround sound and theses areset up all over the living room.
I have a Sony 28" TV. KV28LS35U. It is about 6 years old.
For some time now it has been very slow in coming to life and the little light flashes 5 times and then pauses , then repeats the pattern for a while.can you help?
Posted on Nov 03, 2008
  • Sony Master
  • 5,568 Answers
If the flashing seems irregular, it may be showing a trouble code.
Considering the number of folks having problems with their newer flat-panel sets of all different brands, if you can find a TV repair shop in your area any more, you might want to have this one repaired. They were quite reliable as you probably know if this is the first failure you've had.
The problem is probably pretty straight-forward and in the power supply section of the set, an area that isn't prohibitively costly to repair and uses parts still available and likely even in stock in a decent shop.
If you are in the US, I would recommend further that you go shopping for an honest repair shop in the member directory of your local Better Business Bureau.
Posted on Oct 31, 2008
  • 4,234 Answers
Yes it is fixable. Depending upon the blink count, the repair cost will vary. Can you post the count please? It should be a repeating count with a pause inbetween. This will indicate the problem circuit.
Thanks,
Dan
Standby timer blinks times
There are particular blinks meaning on sony TV. I can give you the problem from your sony tv if you specify or count how times the LED flashed.
Jul 06, 2014 | Sony KV-27S42 27" TV
My Sony Trinitron tv is not turning on. It has turned on a couple of times, but the standby light on the front is blinking. WHat's wrong?
Sony TV LED & Blinking Codes - What Does It Mean When Standby/Timer Light Flashes
Sony has provided a "self-diagnosis function" with your TV, that in the case of abnormalities or problems the LED or red blinking light on the Timer/Standby indicator flashes a number of times to indicate the issue.
when there is trouble with your Sony Television set -- it indicates the issue in either the diagnostic mode, or even more commonly by flashing a series of LED blinks or flashes on the front of your television. Each set or frequency of the blinks indicates a very specific problem with the television itself.
Sorry but unless you may be able to repair the television set yourself , please call a local repair shop to the have a repairman sent out,,
Take care and please Remember to rate/vote for us to
continue f
or Helping out the Community :)
Jul 08, 2011 | Sony Televison & Video
My Sony tv will not turn on. The standby/timer light keeps flashing red.
Problem with the Sony Trinitron KV-J16PF 20" TV The standby/timer light keeps flashing red
Jun 07, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
My standby/timer light is flashing and will not turn on.
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV.
The self-diagnostic function of the projection TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue. As per the two examples below, some of the issues may be resolved without the need for service.
If the STANDBY light flashes three times in sequence, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
If the STANDBY light flashes four times in sequence, the TV may be overheating. To resolve this issue, ensure that the back of the TV is well ventilated.
If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
If the issue continues to occur, service may be required.
Thanks for using Fixya.
Jun 02, 2011 | Sony KV-27S66 27" TV
My Sony Trinitron TV 1999 (KV-32V42) made a strange popping sound and I lost both the sound & picture. When I turn it back on, the two red lights on the front of the TV(standby/Timer light & Stereo...
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV. The self-diagnostic function of the TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue.
Few examples are given below; some of the issues may be resolved without the need for service.
1 blink / 2 blinks / 5 blinks: - This indicates that there may be a power-related problem with your set.
3 blinks: - This indicates that there may be a power-related problem with your set. The set will need to be serviced to allow a technician to determine the specific issue that needs to be repaired. If the power light flashes three times in sequence in a Lamp TV, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
4 blinks: - This indicates that there may be a back light or lamp power problem.
6 blinks: - This indicates that there is some kind of audio problem with your set.
7 blinks: - This indicates that there is a temperature problem with your set. Please check to make sure that the air vents on the sides and back of the set are not blocked or clogged and there is adequate ventilation around the television. We recommend that you check and clean the vents periodically to make sure the set receives adequate air flow. If the problem continues, the set will need to be serviced.
8 blinks: - This indicates that there may be a video-related problem with your set. If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
Feb 04, 2011 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Sony Trinitron TV. No picture; red standby/timer light flashes.
My Sony trinitron has the stero lite on steady and standby lite flashes four times then pauses and repeats. Can you tell me the circuit/condition causing the set to not turn on.
Jul 15, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Timer Standby light flashing No pitcher
Sony
Model # KP-53HS10
Serial # 9718217
MFG 2000
Plugged in TV. Timer Standby Light just flashes continusly. No Picture and No Sound.
Apr 02, 2008 | Sony KP-51WS500 51" Rear Projection...
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
163 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
