Question about Kenmore 18 in. 14432 / 14439 Built-in Dishwasher
Door won't close
The door on our Kenwood Integrated Dishwasher will not lock. Able to push in but the door is forced open again - could the catch be damaged?
    Problem Solver:
  • 16 Answers
Yes. They are available. often including the microswitch not too expensive.
Posted on Jan 24, 2010
My KitchenAid Dishwasher door won't stay closed. It keeps popping open after a few seconds.
I experienced the same problem after my tension cables broke. The door fell open with such force that it bent the hinges a little. If you've replaced the tension strings (which you should do every 5-8 years) then you don't have to replace the latch. I did and it didn't solve the problem.
Here's the solution:
Put a towel at the bottom of each side of the door by the hinge.
Push the door closed a couple of times to bend back the hinges.
Remove the towels and you're back in action.
Good luck
Aug 11, 2012 | KitchenAid Dishwashers
Electrolux Dishwasher door won't close or latch shut
Contact a professional to replace the door switch or adjust it.
Aug 07, 2012 | Electrolux Dishwashers
Samsung dishwasher door lock stuck in closed position
take small flat head screwdriver and on the door were the latch is push the screwdriver in about an inchpull on the open handle at the same time ps unplug it first.
Jun 22, 2012 | Samsung 24"" Dishwasher
Turn the dishwasher circuit breaker off inside your home electrical panel. Open and close the door and watch where the strike plate makes contact with the door. The strike plate is usually on the front top center of the dishwasher. If the strike plate is out of alignment, it will hit the inside of the door
May 19, 2012 | Bosch Dishwashers
Deactivate childlock on fully integrated neff dishwasher
If door won't close and you don't have a child-lock, just push the door closed a lot harder than you normally would - NEFF manual says to do that, and it worked for me! I think it just forces it to engage and 'releases' the catch, as after that it closed with just normal pressure applied.
Apr 09, 2012 | Neff 24 in. S5456 Built-in Dishwasher
I have a Kenwood KDW24FI/B integrated dishwasher.Door latch issue
go to searspartsdirect and get an image of the locking section and the parts and prices will be displayed. if this has been helpful post me back a 4 thumbs up rate .
Feb 27, 2010 | Dishwashers
Frigidaire dishwasher door won't close
with aa small thin screwdriver you can try to pry the "latch/catch "back to an open positon
Dec 17, 2008 | Frigidaire PLD4375RFC Dishwasher
Belling integrated dishwasher not working properly
are you sure it is the board at fault, not justv the door catch? (as the door wont open). If the dishwasher believes it has just finished a cycle and the door has not yet been opened it will not let you change the program.
I had this same problem so I hooked an allen key around the back of the white door catch and pulled it into the unlocked position with a pair of pliers. Has worked fine since but every now and then the catch will pop back into the locked position when the door is opened.
Nov 25, 2008 | Belling 24 in. IDW603 Built-in Dishwasher
Indesit dishwasher
I had the same problem, so I took the door apart as explaned above, found it was gunged up with residue from the washihg cycles. Gave it a good clean, while the part was disconected of course, and hay presto! the door works like new again.
Jan 06, 2008 | Indesit 24 in. D63 Free-standing...
Can't close Bosch Dishwasher door
I had same problem and was alarmed at the idea of taking the door apart, so I tried the 2 screwdriver option described below - it works!
Open door and get two small screwdirvers behind each side of the catch inside the top of the door and gently apply pressure. The catch should reset itself on 'open' and allow you to shut the door again.
Thanks to all for their postings and helpful advice!
Nov 10, 2007 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Kenmore 18 in. 14432 / 14439 Built-in Dishwasher Logo
208 people viewed this question
Top Kenmore Dishwashers Experts
Fred Sops
D. E. Hev
Raisin Brann
Level 1 Expert
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
