Question about Gateway Vipower VPET-20 Uni Skyper VoIP USB Phone Adapter Black Headset
No sound from other applications
While the analog phone works all right, the loudspeakers of the machine don't work; applications like Musicmatch stay mute. It seems the internal sound card is deactivated. Is there a workaround??? Mat
0 characters
1 Points
Inbuilt miccrophone of lenovoG450 is not working
If you have a driver disk, install the audio drivers to correct the communications linkage. If not....go to the manufacturer for new driver updates. Also, try going to the Control Panel and select Devices. When they open, go the Sound area near the bottom of the list. Right click on the application line and request Update Drivers and that may fix the issue also.
Dec 14, 2013 | IBM LENOVO VIDEO ADAPTER-G450 32MB 22P6640...
I could never get my software to work and when I tried to install it on another computer, I was informed I had run out activations.
That sounds right. You can't sell much of your work if the first person to buy it has the right to distribute it endlessly, after all.
Fix it by calling going to Bling Software and sorting out what's needed to make it work and get enough activations to use it on (at least) one machine.
Jun 08, 2011 | Bling Software 123 Copy DVD 10 Full...
I am trying to run Digimax Master on my Windows 7 Op System (just upgraded from XP Home) - appears to be incompatible?
Hi, I would like to help you out. You are absolutely right about this compatibility issues. But don worry there is always a solution.
You can make these applications believe that it is running in windows XP. Just follow these simple steps:
* click on start > control panel > programs and features > select "run programs made for previous versions of windows"
* just keep clicking "next" till the you can see the list of applications to choose.
*then select the "try recommended settings". and go on till you finish it.
I'm sure you will do it right! :) This will surely fix the issue for you.
Please let me know if you need more help. Good luck
And also vote if you think this solution will help others. Thank you:)
Oct 26, 2010 | Samsung Computer Utilities & Maintenance
Windows 7 will not run due to missing PX.dll
this dll file is related to sonic software you can try this link or try downloading the dll from
Jan 09, 2010 | Sonic RecordNow! Deluxe 7.3
My Musicmatch Jukebox, can't detect an internet connection
This is from musicmatch:
To prevent MUSICMATCH Jukebox from requesting a connection to the Internet, do the following:
- Open MUSICMATCH Jukebox.
- Click the "View" menu.
- Click "My Library".
- Click the "Options" menu.
- Click "Settings".
- Deselect the options under "Permission to communicate with MUSICMATCH server".
- Click the "CD Lookup/Connectivity" tab.
- Disable the CD lookup service.
So maybe the disbable the cd lookup service is on. Just a thought.
Has any MMJB subscriber found another music program that permits line-in recordings, similar to MMJ
Nov 06, 2009 | Computer Utilities & Maintenance
Audio not working i can access only my head set .i can hear song only through head set only when i plug out my audio device speaker problem for hardware.before i can hear song through only pc...
Double-click the "sound" icon (bottom-right, beside the Windows "clock") to open the "mixer" application.
Be sure that you have not "muted" your external speakers (not the internal PC speaker).
Sep 10, 2009 | Compaq Computer Utilities & Maintenance
I put a new os windows xp to my computer ,and i don''t know the right installer of her sound.
you can get the sound driver from the motherboard's manufacturer site if WinXP does not have it readily. The device manager will show if the devices are installed properly or it will show some yellow exclamation marks.
Aug 20, 2009 | Computer Utilities & Maintenance
Computer Utilities & Maintenance Logo
20 people viewed this question
Top Gateway Computer Utilities & Maintenance Experts
Clive Gray
Brian Sullivan
Brian Sullivan
Are you a Gateway Computer Utility and Maintenance Expert? Answer questions, earn points and help others
