Question about Goodman GMS90703BXA Heater
Goodman Gmp150-5 The fuse still pops even after i remove the wiring for the stat. The only time it wont pop is if the red wire is off the transformer. People tell me that the board its gone and that a new one is around 200. HELP is there any way to test the board
    Problem Solver:
  • 22 Answers
Sorry if you disconnect all the low volt wires from the board and it still blows fuses, th board is gone.
Posted on Nov 03, 2008
I installed a goodman 5 ton heat cool unit and a 5 wire battery operated tstat, the unit is 2 stage will it work with this tstat cant get anything to work even jumping the tstat
See if there is 124 VAC across the common and the red wire. If not then the thermostat transformer inside the unit will have to be replaced or the fuse changed if it has one(not likely).All t/stats are not the same. If your T/stat doesn't have a provision for the 2nd stage or emergency heat then you have the wrong T/stat That will definitely blow the transformer that supplies 24 vac to the control relays
Nov 15, 2015 | Goodman Heating & Cooling
My dog chewed up the t-stat wiring on my outside a/c unit (compressor?). I purchased some t-stat wire at Home Depot and replaced the wiring. At the outside unit, I connected the new white wire with the...
Hello,Yes there is a 3 amp blade fuse(same as in a car) in the blower unit,take off the door and it is plugged in to the(curcuit) board.Pull it out and slip a new one in.That will restore the control voltage.Your repair sounds correct.Some times there is a tiny button on the transformer itself (square box) that pops up instead of a fuse just push that in to reset it(if applys).
Oct 19, 2010 | Heating & Cooling
No power on the t stat
Either the battery is dead in the t-stat or you have a blown transformer in the airhandler or furnace...if power is sent from the airhandler or furnace for the t-stat then you need to check the fuse and the transformer inside to make sure that you have power there...is there is power there and not at the t-stat then you may have a bad wire...
heatman101
Aug 13, 2010 | Goodman CLQ36AR49 Air Conditioner
UI need to make sure the wireing for my new stat
Generic wiring for most all a/c units, except Lennox: Red is power from transformer to t'stat. White is for heat. Yellow is for cool. Green is for indoor fan. Some times a "C" or even an "X" us used as a common from the transformer on some t'stats to power lights and screen.
Let me know if I can be of any more help
Dec 29, 2009 | Goodman CKL60AR60 Air Conditioner
Touch pad control not working
Put fan switch to "on" position..
Does it come on?
If yes , you still have the 24 volt control circuit ,thus the high voltage as well!
If not you may have a bad transformer or stat
Remove stat
jumper red wire to green wire
Does fan run?
If yes , bad stat
if no
possible time delay fuse or breaker at air handler disconnect or bad transformer
Aug 23, 2009 | Heating & Cooling
Goodman furnace
double check your wiring. R terminal on the furnace will provide 24 volts to the t-stat. W terminal in the t-stat will send 24 volts back to the furnace W terminal to turn on the heat. G terminal in the t-stat will send power to the G terminal in the furnace when the t-stat is switched to fan on. Y terminal in the t-stat will send power to the Y terminal in the furnace which in turn will send 24 volts to the A/C outside. The C terminal in the furnace should be connected to the c terminal in the A/C outside as well as to the T-stat. Check the fuse again
Jun 02, 2009 | Goodman GMS90703BXA Heater
Problems with low voltage control wiring turning on cond. unit
Only 2 wires going outside.
Yellow from the thermostat and the common wire from the lv side of the transformer.
Apr 28, 2009 | Heating & Cooling
LED light blinking constantly
short in a/c wires on contactor is bad, disconnect wires at a/c and power up if no pop fuse it is the contactor. if still pops replace wire.
Apr 24, 2009 | Goodman GDS80703ANA Open Flame Mid-Size...
Have a goodman furnace and it won't turn off even though thermostat is disconnected
remove 1 of the 24volt wires from the transformer do you still have the problem? If you do reinstall the wire back to its terminal where taken loose then do the other wire. and see. If it shuts off with the red wire removed from the transformer 24 volt side the problem is a shorted wire from the furnace to the thermostat.
Dec 12, 2008 | Goodman Heating & Cooling
Wiring diagam for goodman heatpump and air handler to thermostate
On your t-stat you have Y, W1, W2, R, O, G, B or C or X. Y is your cooling circuit and will be the same in the air handler and heat pump unit, use the yellow wire for this circuit. W1 and W2 are your back up elec. or gas heat. Depending on how many kws or heat strips you have and t-stat wires you will put the white wire to W1 in both the t-stat and air handler. W2 is for your second stage back up heat if air handler calls for it, this will be a tan or brown or black t-stat wire and goes to W2 on t-stat and air handler. R is half of your 24v control power from the transformer and is the red wire and goes to the t-stat, air handler, and heat pump. O is for the reversing valve in the heat pump that switches it from heating and cooling. You guessed it the orange wire connect to t-stat and heat pump. G is for the blower and is the green wire to the t-stat and air handler. B or C or X is known as the common which is the other half of control circuit from 24v transform it is the blue wire and goes to the t-stat, air handler, and heat pump.
Oct 09, 2008 | Goodman Heating & Cooling
Goodman GMS90703BXA Heater Logo
223 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
