I have a d-link router di-524 how do i set security to control or stop others using it to connect to the internet
  • 1,879 Answers
>connect to the router using an Ethernet cable (looks like a phone cord but fatter, router configuration is not recommended via wireless connection)
>click start -> run then type in the box that pops up "cmd" without the quotes and hit OK
>black box (command prompt) on screen, type "ipconfig" again without the quotes.
>look for the Default Gateway address (that's the router) and type that exact address in Internet Explorer.
>now you'll have the router's configuration page, look for Wireless then the Security option will be presented to you.
>self explanatory setup. good luck
Posted on Oct 31, 2008
How do I find the security code for my router to connect me to Internet?
Use the web admin interface. Under wireless the user is SSID and the password known as the key.
Nov 24, 2012 | D-Link AirPlus DI-524 Wireless Router
Problem with Lenovo IdeaPadS10e and D-Link DI-524
This problem is with the firmware of your router so the best thing to do to correct this is to update the firmware of the router and you can get it from Dlink web site...
Apr 23, 2009 | D-Link AirPlus DI-524 Wireless Router
My D-link DI-524 Wireless router not working.
g´day m8,
Your D-Link AirPlus G DI-524 Wireless Router needs a hard reset.
Log in to your router, go to -> administration -> factory default -> Restore Factory Defaults: =  "yes"
Then save settings.
You have now reset the router.
First thing you do is set your wireless setup in your computer to the same, i.e. no security.
Test if there is connection, if, the start with the setup from the top, beginning with admin password.
/Teis
Dec 19, 2008 | D-Link DI-524 4 Port Wireless-G Router -...
DI-524 Wireless
Yes you can, it's easy.
1. Just connect one of the LAN ports of the DI-524 to a LAN port of your other router. Leave the DI-524 WAN port empty.
2. Disable the DHCP server on your DI-524, your other router will be the DHCP server.
3. Assign a static IP address to you DI-524, different from your other router's. Example, if your other router has 192.168.2.1, you may assign 192.168.2.4. Make sure that the IP address you assign is outside the DHCP range configured in your other router and that the subnet mask is identical on both.
Feb 20, 2008 | D-Link AirPlus DI-524 Wireless Router
Connecting a DI-524 to a DI-604
This shouldn't really be any problem simply use a short "Uplink" ethernet cable to join the routers thru the uplink port, or any port really, and that way ya should be able to wifi and access the net, set ya router that connects to the net for DCHP and disable that setting in the Wifi router and ya should be good to go?
Jan 30, 2008 | D-Link AirPlus DI-524 Wireless Router
Securing my wireless connection
Hi ladynb,
Open the DI-524 window by typing 192.168.0.1 into internet explorer address bar, and press enter.  Fill in your password, and press enter.  Click on the  Wireless button. This should open the Wireless Settings window for the 524.  Set SSID broadcast to  Enabled. Set Security to WEP.  Set Authentication to open system.  Set WEP Encryption to 64bit.   Set Type to HEX. Click and select radio button next to KEY1.  Enter a 10 digit number that you can remember, like 1234567890, or 1111122222.   Now click the Apply button at bottom of the screen.
Now any device that you wish to link  will will need to use this Key.   Scan for the router, connect and use Infrastructure mode, Type in the 10 digit number you were suppose to remember, and off you go.
Oct 09, 2007 | D-Link AirPlus DI-524 Wireless Router
Cant connect
Hi purplegarion,
hook up the router per instruction in manual and your particular internet connection.  With the Di524 powered up, use the end of a paperclip to depress the reset button located in a little hole beside the power connection.   open internet explorer and type in 192.168.0.1 and press enter.  The password is admin. once th screen appears, click on Wizard.  Follow the wizards directions carefully.
For simplicity of security click on the wireless button while in the  wireless screen.  Set radio to on.  Enter a SSID like purplegarion. Set to open system.  Set Security to WEP.  Wep to HEX.  64bit.  Enter into Key one a 10 digit number you can remember like 1234567890.  Click apply.  Change your password to a personal password other than ADMIN.
Any device that attaches will need to enter the WEP 64 Bit hex Security key 1234567890, or whatever 10 digit number you put in the router.
Internet connection will require powering down you modem, and the DI-524 router.  power up the modem first and let it go through the start up, then power up thte DI 524.  you may need to make sure your DHCP is set to Automatically assign an IP address.
Oct 07, 2007 | D-Link AirPlus DI-524 Wireless Router
Computers & Internet Logo
David Payne
David Payne
