Question about RCA P46924 46" Rear Projection Television
Tv blew up
Well, when I turened on my tv it made a strange sound it almost sounded like a very small explosion and my tv never came on. I did smell smoke or like something had been burnt. I just don't know what it was?? any suggestions??
  • 53 Answers
You probably have a bad hv splitter module i would recomend calling a reputable shop in your area as there are dangerous voltages present.
Posted on Sep 23, 2006
White smoke coming out of tail pipe. but don't smell like oil or antifreeze
if its smoking it must be oil or antifreeze there is nothing else it could be ,it won't take much antifreeze or oil to cause it to smoke ,YOU really got me going and I know 79 small blocks chevys PLEASE if you do find it get back to me as to what it is.
Woody
Sep 23, 2014 | 1979 Chevrolet Camaro
Strange smell after bulb replacement
Sounds like cooling fan for bulb is not running or passage ways are plugged.
Feb 05, 2014 | Toshiba 72HM195 72" HDTV
My iron exploded when I plugged it in. How can it be fixed?
You have a short in the wiring inside of the iron. It will not work until you get the short fixed.
Oct 31, 2012 | DeLonghi Stiromeglio Compact PRO 300 Iron
Frigidaire GLG=F366asd stove igniter problems and solutions . ... on the element lights up the smell of gas is real strong and then it lights and sounds like an explosion.
Where is the problem -- in the oven burner or a stovetop burner?
If something got spilled on a burner ring and clogged the small holes, especially near the igniter, the burner will be slow to light. A stiff wire (small enough to fit) can be used to clean out the holes.
Mar 18, 2012 | Kitchen Ranges
When I first start the car a puff of blue smoke comes out the back after driveing for awhile a strange smell is in the car?
This sounds as if you have a rather High Mileage vehicle. (100,000+)
The puff of blue smoke is oil being burned in the cylinders. When the engine is cold, it will burn some oil, usually sucked in through the Valve Stem Guides.
Then after the motor warms up, and all the metal parts swell a little, it stops smoking as much. It is STILL smoking, but not enough for you to see it.
Obviously, you are losing engine oil, so check the oil level often, and refill/change as neccessary.
The 'strange smell' could be many different things. My best guess is that you have Oil Leaks on the engine, which is dripping on to the Exhaust Manifold, and getting burned there. Usually a Valve-Cover Gasket leak. When the car is all warmed up, open the hood, with the engine running, and see if there is any whitish smoke rising from the motor. if so, you have a leak on to the manifold. A very common problem, easily repaired. Or, you may have a leak in the heaters' Core, which will leak Anti-freeze into the cabin of the car. That would smell sort of sickly-sweet. This will be a much more expensive problem to repair.
Anyway, it sounds as if the car is in need of some maintenance.
Jun 21, 2011 | Lexus ES 300 Cars & Trucks
TV was working just fine.. no issues at all.. turned TV on.. and got a click click click sound... no picture, no sound (other than click) smelled like something was hot. TV is about 7 years old. TIA.....
It sounds like it is time for a new TV, unfortunately. Nowadays you can get a new one for about the same as your repair costs would be. If you smell something burning you probably smoked a circuit board.
Apr 10, 2009 | Televison & Video
When starting to reheat a loud crack, explosion, sound occurred,
As long as the door latches correctly there should be no danger. Some items will cause loud "explosions" in a microwave, such as whole potatoes when the skin has not been pierced. If the food contains pickling spices for example, the seeds will explode with a very loud sound like a gun.
As long as the oven continues to heat, there may be no other problem. But I suggest you stay near the unit when using it. Watch for smoke and be alert for strange odors. You don't mention the age of your oven but if it is new you can call GE customer care at 800 432 2737.
Ray
Nov 25, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
1998 volvo s70 heater smells strange and smoke fills the cabin
Your heater core is leaking. The smell and smoke is from the coolant evaporation.
Oct 17, 2008 | 1998 Volvo S70
Samsung 50' DLP Tv. Is it a lamp?
there is a lamp door in the back for end users open it up and check it out, could be the color wheel exploded also
Jul 08, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
RCA P46924 46" Rear Projection Television Logo
42 people viewed this question
Top RCA Televison & Video Experts
jason
Steve Allison
Steve Allison
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
