Hotpoint Aquarius 1000.Makes noises when internal drum turning-internal drum appears loose at front.
Possibly the bearings have gone but check the nut on the pulley wheel has not come loose first.
Posted on Nov 04, 2008
Drum not turning
check the motor brushes after taking out the plug
Mar 06, 2014 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius 1000 WM62 The drum makes a screeching noise when turning ? Any ideas ?
it could be drum bearings or even some thing that has got past the inner drum and is jamed inside hitting the drum when it turns,,,,could also be the motor bearings,,,,open the door and try lifting the inner drum up,,if there is any lift in it then the drum bearings are going,,this will also cause it to screem on spin speed
Dec 01, 2010 | Washing Machines
The drum is loose how do i make tight again, makes noise when drum is spinning washing
Bearings and drum shaft seal need to be replaced, not for the faint hearted advise engineer or dump.
Nov 01, 2010 | Hotpoint Aquarius WD640 Front Load...
I have a Hotpoint Aquarius WF541 that has started making ean extremely loud noise when on spin. The machine remains still, but sounds like a jet engine. The drum makes an awful noise when I turn it...
maybe it the pulley tensioner came up the back of the machine and check if the belt is tight...if not get the spanner out retention the pulley arm and retighten.
Jul 20, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Drum makes loud noise as rotates clockwise
put few clothes in it drum to switch on its ball in there
Oct 06, 2009 | Hotpoint Aquarius WD63 Front Load...
Hotpoint aquarius 1100 bangs while spinning
Several possible reasons for this. M/C not level, causing it to move about.
Overloading of m/c.
Loose concrete balance weight, there is one at top and one at bottom.
Suspension spring broken or unhooked.
Suspension leg loose or broken.
Main drum bearings worn, to check this, turn drum by hand and if it feels noisy or rough , then bearings have gone (expensive repair).
There are other possible causes, but these are the main reasons.
Plz rate my solution.
Dec 29, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Drum makes grinding noise when turning
spin the drum by hand, if it feels rough or is noisy, then you probably have drum bearing failure.
Another possibility is one or more of the drum paddles may have come adrift..
These can be replaced.
Nov 24, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint aquarius drum makes a noise and is stiff at one point
You take the top off. A couple of screws on the back of the unit, then the top slides off backwards
Sep 07, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint aquarius 1000 washer/dryer
cleared blockage from end of drain from machine.
Jul 27, 2008 | Hotpoint Aquarius WD640 Front Load...
Washing Machines Logo
150 people viewed this question
Top Washing Machines Experts
