Question about Eureka Smartvac 4870 Bagged Upright Vacuum
Roller will not move - Eureka Smartvac 4870 Bagged Upright Vacuum
    Problem Solver:
  • 7 Answers
Might be the belt have to take the bottom cover off and see or it might have a foreign object wedged in the roller have to take the bottom off just 5 screws.....hope this helps
Posted on Dec 17, 2008
The brush in my powerhead of my PowerPlus will not work even though the motor works
Check to see if there is hair or string or something preventing it from moving. Or, you might have a button or something that stops the roller from moving for suction for the hose only if it detaches for use that way. If it's not that, unplug the vacuum and see if you can move the roller by hand. If not, take the roller off by unscrewing the shield, probably 4 screws and check to see if the pegs that hold the roller in are in properly or broken. Rollers aren't expensive. If it's broken, just replace it. But, I'm thinking that there is something like string holding it. Another thing might be the belt is broken. If that's the case, do this:
First, make sure the vacuum is unplugged. Turn it over and you will see that on the rollers a cover. This cover should have about 4 screws holding it on. Unscrew and remove the cover. Note how it was put on. Take a look at the roller brush ends where it goes into the sides of the vacuum. Pull the roller straight out, noting how the pegs that hold it into the vacuum are situated. Take the broken belt off. It might be attached to one side of the roller. Note which side it is on and which side of the vacuum it is on. If it's not attached, no problem, just note which side it should be on. Now, on the bottom where the belt goes around, should be a silver peg that the belt slides over. Sometimes it's hard to see, but it's there. Take the broken belt to the store and match it up to a new one. Some are thinner than others, smaller or rounder than others. Be sure to get the right one. Now, back home, comes the hard part. Put the new belt on the proper side of the roller, only. Try and get the roller back into the vacuum snugly and secure. Once you do that, holding the roller with one hand, snug against the vacuum, pull the belt down and slide it onto that silver peg. If it needs to be twisted on, do that, but it probably doesn't need to be twisted. Once you have it on the peg, move the roller around with your hand to settle the belt into the proper position. With that done, replace the roller cover and you're done, Bob's your uncle! Plug the vacuum in and have at it.
Sep 26, 2014 | VAX Appliances Vacuums
HV9010P ROLLER BRUSH DOESN'T MOVE
That is probably the belt. Open up the bottom screws and take a look. The cat or dog hair usually gets stuck in the ends of the rollers and stops the belt from effectively pushing the roller. You may find that the belt is still on the drive and the roller. If you do just clean out the roller.
Jan 22, 2013 | Black & Decker AV1200 DustBuster Handheld...
I accidentally got a piece of string wound around the brush roller. It stopped the roller. I unwound and removed the string the but the roller is not rotating. Is there a reset button on a hoover tempo...
You could have broke the belt of the vacuum or it could have fallen off. Find the belt and evaluate the condition of it and if it is on track.
Please rate this post. Thank you!
Jun 10, 2011 | Vacuums
I have Bissell Momentum Cyclonic and when vacuum is on the roller will not work, but if I tilt it back the roller will start moving.
Hello, this is Ava with Think Crucial.
There are a number of reasons why your brush roller has stopped moving. General maintenance to your vacuum is crucial and will help it work at peak performance.
First things first lets focus on the brush roller. Unplug the vacuum and turn it on its side. Look for any noticeable clumps of debris or hair strands that may be caught in the brush roller. Remove these obstructions, probably best to do so with a scissor if it's hair or long pieces of carpet fibers. After removing the debris try manually rotating the brush roller to uncover other hidden clogs. Another thing to take note of is the condition of the bristles on the roll itself. Are they loose or worn down? These are signs that your brush roller is in need of replacing.
While checking out your brush roll you might as well take a look at your vacuum's belt. Your belt should be replaced about every three months. After regular usage, the belt will stretch out, lessening the tension on the brush roller. Lesser tension diminishes the brush roller's turn rate and speed. If the belt feels loose then it certainly is affecting your vacuums suction as well as your brush roll not moving at all.
You can purchase a wide variety of high quality Bissell replacement parts for your Bissell vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/collections/vendors?q=Bissell
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Jan 09, 2011 | Bissell Momentum Bagless Upright Vacuum
The brush roller is not rotating on my Kenmore Whispertone. It will pick up on floor surfaces. Help!
Be sure that there are no fibers wound around the roller or lodged in the wheel well of the brush roller. That is usually the cause of a brush roller not rotating. You might need to use scissors to clip the fibers and then pull them from the roller. The fibers might range from human and pet hair to carpet fibers, threads, string, yarn, embroidery floss. They wind around the roller and eventually "tighten up" so that the rotator will not move. I have found that, depending on my current craft project, I may have quilting thread, knitting yarn, embroidery floss, or other such goodies wrapped around the roller. When our daughters were at home we would have long, beautiful blonde hair tangled in the roller. I hope this helps.
Nov 10, 2010 | Kenmore 23313 Whispertone Bagged Canister...
The main roller will not work
Check for a broken belt that drives the roller. Remove the roller brush and clean as best you can. Add some WD40 at both ends of the roller brush between the brush and the pieces that hold the brush in place. Turn by hand to be sure the brush moves freely. Reassemble making sure the belt is on properly.
Oct 01, 2010 | Bissell Lift-Off(R) Revolution(R) Turbo...
Roller brush will not move when vaccum is turned on
maybe the belt is broken. clean the unit and replace the belt.
May 23, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Brush roller on windtunnel won't spin
It sounds like you need to replace the actuator arm or the cable to it. Look for Hoover part 43143046 for a start. I've got a similar problem.
Mar 21, 2009 | Vacuums
Eureka the boss 5893A brush roller will not work
is there anything jammed underneath.can you turn the brush roller by hand.if not then take it back where you bought it.sounds like you have a defective brush roller
Jan 11, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
Roller not moving
You can buy a new vacuum at walmart.
Feb 28, 2008 | Vacuums
Eureka Smartvac 4870 Bagged Upright Vacuum Logo
53 people viewed this question
Top Eureka Vacuums Experts
charlesjo336
Level 1 Expert
JoeVacs
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
