One display hinge on the laptop is broken. I have replacement hinges and covers.
It looks as if I have yo take the cover off the LCD. Does this just prise off or is there a another way?
Comments:
Oct 31, 2008
- The response is not an answer to the problem. I have spare hinges (see posting). To be advised to go to e-bay to buy some more is hardly helful. My question on how to fix the new hinges was ignored.Oct 31, 2008
- I am afraid that I do not believe this advice. The hinges fit into the bottom of theLCD display unit. Removing the keyboard and/or the LCD cover would get you n further. I really would like advice from someone who has replaced these hingesOct 31, 2008
- To Ekse
I have read the manual. The pages you refer to describe how to remove the whole display unit from the computer - which is not relevant. They do not describe how to replace the hinges into the display. I have since found a brief respons from 2007 which confirms that the display has to be gently prised apart.Oct 31, 2008
- Ginko
What you advise is not relevant. The problem is not to unscrew the hinges from the chassis. This is entirely straightforward and does not require anything other than the hinge covers to be removed.
The problem lies with the other end of the hinge which fits into the lid.Oct 31, 2008
- Ginko
What is the procedure for removing the screen front cover?
That is the advice I have been seeking throughout. I have the manual that you quote and it does not address this pointNov 01, 2008
- The original question - still unanswered by anyone -is hpw do I remove the front cover of the LCD display. This is not described in the service manual which I have.
It would be really helpful to have a response from someone who has actually replaced these hinges.Nov 01, 2008
- Ekse
This does not address the problem askedNov 01, 2008
- Does not address the question askedNov 01, 2008
- This is more helpful. There are no obvious screws holding the fromt of the LCD display. There are small "rubber" dots. Do they need prising off? The cover does not come off readily and I am hesitant to use force.Nov 01, 2008
- The final response was helpful. However it is obvious that none of the repondents have actually replaced broken hinges on this model of laptop - and this makes the advice less than compelling
