Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
WHIRLPOOL TOP LOADER MODEL GSQ9669LWO
MOTER IS WORKING BUT AGAITORIS NOT SPINNING?????HOW DO I REMOVE AGAITOR,OR WHAT COULD THE PROBLEM BE
  • Ron Coons
    Ron Coons May 11, 2010
    can be a few different things.
    when set to agitate does the agitator move at all?? and during spin does it just drain the water but not allow the tub to spin at all?
    Novelist:
    Champion:
  • 261 Answers
Trick or Treat. You coupler is out and I will supply a link for parts and schematic, please note part 13
http://www.searspartsdirect.com/partsdirect/retrieveSubComponentPartsAction.action?modelNumber=GSQ9669LW1&productCategoryId=0153200&brandId=1198&modelName=WASHER&diagramPageId=00004&componentDescription=BRAKE, CLUTCH, GEARCASE, MOTOR AND PUMP PARTS&documentId=W0403060&backToLink=Return to Sub Components list
Posted on Nov 01, 2008
Whirlpool super capacity plus (commercial quality top loader) does not spin on all settings and does not spin fast enough
sounds like you have a worn out clutch. depending on model it could be an easy fix. would need to know model number to know for sure.
Apr 03, 2013 | Whirlpool Washing Machines
Whirlpool top loader model #LA9500XTNO won't agitate
the agitator dogs need replaced sounds like.4 little comma shape pieces underneath the top of agitator
Jan 15, 2010 | Washing Machines
Spin cycle is not working
one possible problem the lid swicth might have broken but if you hear a moter noise when it trying to spin the swictch is ok you can verify
if washing machine agitates during wash cycle
if no agitation newer design has a drive coupling between moter and transmission lean machine back
you will find debries center of machine about 8 inches back usually black rubber the drive coupling
has 3 pins on each outside peice that fit into the center bushing lean machine back have second person for safety unplug machine to change drive coupling there are two clips that hold pump to top of moter remove clips slide pump off shaft remove two screws from top of pump clips unplug wiring harness
undue clips remove moter drive coupling peices can be remove by pulling or can use large flat blade and work from oposites sides till plastic parts come off
reassembly place outside parts one on transmission one on moter install center part on transmission side
line up pins from moter to line up with 3 holes in center part normally top clip i install first so gravity assist with install of bottom clip reinstall screws plug in harness line up pump with moter shaft and reinstall clips run check if no noise from moter when lid is closed then lid switch might be bad the new style of washer is front serviceable there are two screws bottom outside corners of panel remove
light pressure pull panel forward then lift is hinged at
top back roll back there are two brass clips catch front of clip with flat blade screw driver and move top of handle toward back of machine clip will pop off wiring for lid switch on top of case needs to be unplugged outside case will tilt toward you then can be lifted off alignment tabs at bottom front there are two screws where lid switch is held to top of case can be seen when case is removed good luck ron
Dec 10, 2009 | Kenmore Washing Machines
My washer is not spinning or draining properly, the timer is working, it will continue until it is in the off position but once it is my clothes are sopping wet. Is there a part I need or anyway I can fix...
if it is a top loader the moter controls the pump and spin u need to check power to the moter and clutch i.e if the moter runs but no spin the clutch has gone if its not geting the water out i can be the moter the best way to check is take the waste pipe out and put it in to a bucket and turn on the water should jet out if not the pump may be blocked try these first
Jul 29, 2009 | Kenmore 24032\24036 Top Load Washer
Whirlpool direct drive top loader will not spin
Hi, Is the humming noise coming from the timer area? Do you know if it agitates ok?
When you have it in spin cycle, Try lifting the lid and see if the hum stops.
The reason for these questions is that on this model, if it drains the water out but does not spin, it is either lid switch, coupler, or transmission.
If it's the coupler, it will not agitate either.
Please let me know so I can assist you further.
Thanks
Vic
May 30, 2009 | Whirlpool LSR8433K Top Load Washer
LAT9604AAE No agitation but drum spins and drains water
cold possibly be just the agaitor but odds are u need a transmisson not worth repair
May 20, 2009 | Maytag PAV2300 Top Load Washer
Washer spinning irregular.
your counter balance spring has broken off..onthjob
Jan 17, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Does not spin
The close pin most likely broke the switch. Unplug the washer, remove the screws that hold the top and flip it back and remove the cabinet. with the cabinet off it is easy to replace the lid switch. Cost should be $20. to $30.
God Bless and Happy New Year.
Dec 31, 2007 | Whirlpool LSR6334LQ Top Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
375 people viewed this question
Dan Webster
Dan Webster
Sal De
