Amplifier shuts off when push in clutch - Audio Players & Recorders
  • 1,512 Answers
Hi dylanlobey
Sounds a lot like thw wiring for the remote connection off the back of your head unit is getting fouled by the clutch pedal. I there is a fuse holder in line with the remote wiring, it may be being pulled apart when you push in the clutch. Check for this and get back to me here if you still have problems.
regards
robotek
Posted on Nov 01, 2008
Problem with pioneer m f10
Sounds like a capacitor is failing.
May 04, 2014 | Pioneer Audio Players & Recorders
No sound from speakers or headphones fan not working gets warm
The Crown CE series of amplifiers have a 7 stage fan that runs as needed when the amplifier is working. Generally the fan is running at some point most all of the time, and you should be able to hear it ramp up as you push the amp to deliver more power. If the amplifier fan is not functioning, you may be in a thermal shut off mode that protect the amp from overheating by shutting off any signal. My advise would be to contact the manufacturer, and have it serviced.
Apr 05, 2014 | Crown CE2000 2-Channel Amplifier
Car stalls out when you push in the clutch
When you push in the clutch you are pushing the crank shaft forward in the main bearings but the action of the throw out bearing for the clutch pushing the fingers of the clutch pressure forward. For the engine to stall under this condition I would be checking the throw out bearing for seizure and acting as a brake on the pressure plate. Some clutch systems are part of the engine start system where you have to depress the clutch to start the engine (safety device) This may be faulty and shutting the engine down.
Oct 04, 2013 | 1992 Toyota Paseo
Car will not accelerate when gas pushed
Clutch plate and pressure plate seem to be too weak to pull the car. To test the clutch plate, park the car on flat surface. Pull the hand brake up, start the car, depress the foot brake pedal, depress the clutch pedal, put the car in 1st gear, press the gas pedal and leave the clutch pedal at once, while keeping the brake pedal depressed.
Follow one of the two following statements:
1. Engine does not shut down and remain start. (Clutch plate, pressure plate and clutch bearing defective - Replace all as a set)
2. Engine shuts down. (Clutch system is OK and does not require any repair).
May 22, 2013 | Honda Civic Cars & Trucks
1996 mecedes c 180 shuts power when i press clutch to change gear
just I would like to ask you a question before giving any answer. Do you have the power shut off at any time you press the clutch ? Is it only just whilst clutch pressed? If so means that either you have worn thrusts on the engine crankshaft,where on applying to clutch you push forward the crankshaft and makes the engine running tighter where it shut off power. My advise is to visit a workshop and request a qualified mechanic to check this case as it is easy for him to get the crankshaft pulley in to his hands,pull and push it and if is what I said he will note the knock .
Nov 20, 2012 | 1996 Mercedes-Benz C-Class
It has stopped workin and the red light is flashing.Is this a code and if so how do you read it
The red light is a power protection circuit designed to shut the amplifier down due to an overload or wiring problem. If the amp was playing then shut off, my guess is a problem with the speakers or the speaker wiring. Some amplifiers are only stable to a certain load. For example, most car audio speakers are 4 ohms which is the resistance placed upon your amplifier to produce a certain volume of sound. If you bridge two 4 ohm speakers together in parallel, you cut the resistance in half, thus increasing the amount of power (and volume) to your speakers. This also creates more heat and could, in effect, shut your amplifier down. I would find out how the speakers are wired to determine the resistance of the load your amplifier is pushing. Also check the grounding.
May 26, 2011 | MTX X Thunder 300XD Car Amp
I changed the clutch on my 2003 hyundai tiburon gt 2.7l 6 speed now when i push the clutch it wont go into gear and if i push the brake it shuts off
Have you checked to clutch fluid? Did you disconnect and hoses or fittings that are part of the clutch system. You may need to bleed the system to get the air out.
Jan 14, 2011 | Hyundai Tiburon Cars & Trucks
Amp wasplaying red light came on and won't go away i check ground and it is good
Jun 20, 2010 | MTX Terminator TN400/4 Car Audio Amplifier
107 people viewed this question
 Grubhead
Grubhead
