Question about Sanyo DP32746 32 in. LCD Television
Sound No Picture Sanyo LCD WIDE Screen HDTV
I have sound but no picture on sanyo wide screen LCD HDTV
    Genius:
  • 1,139 Answers
Hello heck75,
I wrote this for another post but it applies here also:
This sounds like your inverter or back-light has gone out. What you can do to test this is to turn the TV on and then turn off all of the lights until the room is dark. Then shine a flashlight at an angle on the screen and see if you can see a picture. If you can the back-light and or inverter has malfunctioned. If this is the case, then I would suggest that you have a qualified TV technician fix this problem, but first ask for a estimate because the inverters and back-lights are sometimes part of the screen and is it is you might as well buy a new TV.
If the inverter is a separate board, If you have a background in electronics you might be able to repair the board, however if you do not have a background in electronics, again I would suggest getting a qualified TV technician to work on your set.
I hope this helps,
Thank you,
Shuttle83
Electron-Age Technologies LLC
www.electron-age-technologies-llc.com
Posted on Nov 28, 2008
Sanyo hdtv lcd flat screen--no picture and no sound
first just for trying--unplug set for a few minutes and plug it back to see if it resets.
If not someone will have to open set and check voltages on Power board to see if there or not.
There is another issue common if set 1-2 years old but that is the set at first has to be turned on several times to get it on--let me know if you had that one and I will still advise you.
Mar 19, 2012 | Sanyo Televison & Video
My new 55in sanyo lcd tv has sound but no picture. The tv is one week old. Is the problem the backlight or something else?
Tv only a week old take it back were u bought it,trade it in for another tv.Tv have a picture than flashes only a few sec. than died have sound left only?Yes,than those tv 2 long LCD inverter boards are dead.These tv 2 long LCD inverter boards are only to help the tv to have a backlight for tv LCD screen panel only to produced pictures.
Jul 14, 2011 | Sanyo DP46849 46 in. HDTV
Sanyo 50" plasma flatscreen, hdtv
Picture frozen on one picture for some channels and blank on others. Sound is on. What could this be? We have a 50" Sanyo. HELP!
Apr 13, 2011 | Sanyo DP32746 32 in. LCD Television
Sanyo lcd-32k40 features
  • Model: Sanyo 32K40 Multi System LCD TV
  • World-Wide NTSC/PAL/SECAM Color System - Watch any video signal on this TV!!
  • World-Wide NTSC M, PAL BG, PAL I, Secam BG, DK/ PAL DK TV tuners
  • 32 inch LCD TV with 3 HDMI inputs and PC input
  • USB input for direct media playback
  • 45,000:1 Dynamic Contrast: While viewing either very bright or very dark scenes, it can be difficult to distinguish main images which blend into the background.
  • Dynamic Contrast dramatically mitigates this problem by adjusting the backlight intensity, providing up to a 4X improvement in contrast.
  • 6.5ms Response Time
  • Widescreen 16 X 9 Format
  • World-wide Dual Voltage 110-240 volts 50-60 hertz
  • HDTV monitor (HDTV tuner required for HD reception)
  • This is a multisystem TV. All Multi System TVs in the market do not have a digital TV tuner: What does this mean?
  • To watch digital channels (ATSC Broadcasting in US and DVBT broadcasting overseas) you need a digital source/tuner like a cable box, digital tuner, satellite service, etc.
  • To get the best quality video on this TV you need a source that has a digital connection like HDMI or component.
  • Wide Screen Mode allows you to watch conventional 4:3 aspect ratio broadcasts in wide screen (16:9) mode.
  • Steady Sound® equalizes volume levels so there is consistent output between programs and commercials.
  • Built-in hidden speakers includes 2 (5W x 2) speakers to deliver dynamic sound.
  • Component Video Input offers the best video quality for DVD (480p and 480i), and digital set-top box (1080p, 1080i, 720p, 480p and 480i) connections.
  • PC Input allows you to connect your PC and display the PC screen on your TV.
  • Surround Sound Audio Effect
Mar 04, 2011 | Sanyo 42 in. LCD TV
Sanyo dp42647 picture is black but has good sound worked great yesturday
sanyo lcd dp42647 turns on and has sound no picture black screen
Dec 27, 2009 | Sanyo 42 in. LCD TV
No picture, no sound.
contact sanyo, sounds like your display panel has gone bad
Sep 08, 2009 | Sanyo DS31590 31" TV
No picture on screen
No,Ur vertical/horizontal IC is shorted or cold soldiers.Could be the parts that support the IC is also.
Aug 19, 2009 | Sanyo DS27820 27" TV
Small picture from player (not wide screen)
Set the all settings to wide, not auto as if the player is set to 4:3 format then this sends a signal to the tv telling it so.Go into the setup menu and choose picture format set to 16:9 or wide. Set the tv to auto and this will keep all picture inputs to origional format. I.E. if it was recorded in 16:9 it will play in 16:9. You could set the tv to 16:9 but it will distort the picture on 4:3 recordings.
May 31, 2009 | Sanyo DRW-1000 DVD Recorder/VCR
Sanyo 42" 1080p, picture doesn't fit on screen
this is normal and this feature is for wide screen programs! normal shows and games will lose part of the top of the screen sides and bottem because it zooms in on whats in the middle of screen! hope this helps
Dec 07, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Wide screen lcd hdtv
LOTS of people have this SAME problem
Dec 05, 2007 | Sanyo DP26746 26 in. LCD Television
Sanyo DP32746 32 in. LCD Television Logo
225 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
