Power shuts off after 10 mins of normal use - Computers & Internet
  • 41 Answers
Sounds like overheating.... Take the cover off, then start the computer to make sure the fan over the cpu is running also make sure the fan in the back of the computer in the power supply is running. If it's running then shut it down, get some compressed air from RadioShack ( Has No Water In It ) and Blow all the dust off the cooling fan and heatsink under the fan. Blow the dust out of the power supply. Your coputer should run like new....
Hope this helps..
Have A Nice Day.....
Posted on Nov 01, 2008
    Scholar:
  • 89 Answers
When a system shuts off after about the same amount of time every time--and it can't be traced to having one particular program, it usually means it's shut down because it's getting too hot. Do you get any warnings? Can depend on chipset/settings what alerts you get. Something often overlooked is the cpu fan, if your system is a couple years old, that'd be a generally cheap/easy replacement that often fixes it. It can be very hard to tell just by looking at it if it's working normally or not. Any noise?
Posted on Oct 31, 2008
Hoover bagged wind tunnel 2 vacuum turns its self off after about 10 min. of normal vacuuming I can press the power button right away and the vacuum will turn back on and vacuum for sometime as long as 5...
There is a thermal sensor in the motor which shuts power off if it gets too hot but usually it won't turn back on until it cools down. It seems you might have a defective switch
Oct 06, 2013 | Hoover U6437-900 / U6439-900 Windtunnel...
My LTV32w1 Westinghouse TV keeps shutting off while watching after about 5-10 min. It won't come back on unless I unplug, wait about 20 min, plug back in, and turn it on. Then again only 5-10 min and it's...
Ur tv power supply have dying leaking parts call capacitors.The board where the power a/c cord plug into it.That the power supply board.U know basic electronic's,have the tools and know basic soldering?Searches the power supply board for these dying leaking capacitors and replace them,ur tv will power up normal an last.These dying about to be dead are alway bulges up on tops or puff on it tops.These Capacitors must be replaced.Or tries websites like Shopjimy.com,Ebay.com to buy a whole refurbish power board for the replacement.
Jul 05, 2010 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Watch TV and it shuts off after 10 min.s
Its the power source of the TV, something is causing a change in the power supply or the TV is overheating...no sure but one of the two...I had the same problem...I think they changing the power source and its back to normal.
Sep 10, 2009 | Televison & Video
Power comes on and boots up
try to reset you motherboad bios... make sure to unplug the power cord.. remove the bios battery for 10 mins then put it back... and try to switch the jumper setting to "2-3 configure" for a moment and then bring it back to "1-2 normal mode" position..
Jun 22, 2009 | Computers & Internet
Shuts down
I would check the intake air temperature sensor
Jul 14, 2008 | 2001 Pontiac Grand Am SE
Shutdown
plz check the power supply
Jul 01, 2008 | E-Machines T6420 PC Desktop
Dropped signal after 10 min opertation
This sounds like a thermal issue. Maybe the lcd is overdriven and getting hot. To find out if this is the case, blow cold air on the receiver while it is running. If it stays connected longer than normal under these chilly conditions, then chances are that some component is overheating and shutting off. It will be most likely a transistor on the signal receiving portion of the board. In that case, I am sure that you will need to send it in to Garmin for repair. Good Luck!
Jan 30, 2008 | Garmin Nuvi 660 GPS Receiver
RCA 20f510td
Sounds like a thermal breakdown of a componet. it could be in the main power supply regulaor supply or even a bad capacitor in the power or sweep supply. In some cases Zener diodes can break down and change values after warm up. In some cases also bad solder connections in the highvoltage section, or the power supply can cause this problem. It is a hard call without being able to look at the set. Just a few leads on where to go first. most likly a combo unit, such as this one , would cost you more then a new one these days. Good Luck PS Please dont forget to rate this thread.
Dec 09, 2006 | RCA 20F510TD 20 in. TV/DVD Combo
Computers & Internet Logo
143 people viewed this question
David Payne
David Payne
