Question about Bose LifeStyle 5 Series-III CD Shelf System
Bose system 5 amps out put for speakers
What is the bose system 5 amps out put for speakers
SOURCE: Bose Cube Speakers separated
Ok…
I had the same problem with a Bose separated double-cube Acoustimass speaker/array but was able to fix it as follows:
Tools:
small, thin, flat-head screwdriver
large pliers
C-clamp
Instructions:
1. Disconnect the speaker wires from the cube.
2. Remove the grille from the top speaker cube. It just pops off.
3. Insert a small, thin, flat-head screwdriver around the perimeter of the speaker. You will have to pry lightly to break the glue’s seal.
4. Using a set of pliers (large, plumber-sized) wiggle the speaker until it comes free. You might need to grip it top to bottom and then left to right. The speaker will come free of the case.
5. Remove the white insulation to get a clear view of the dislodged brace/connector.
6. Stack the top and bottom cubes. Make sure that the rubber seal between the cubes is seated properly and that the black and white cables are not pinched.
7. Using the C-clamp, compress the brace/connector until it seats on one side. Loosen the C-clamp and compress the opposite side. The brace/connector should snap into place. Be sure the make sure that you do not pinch the speak wires that are running through the center of the brace/connector.
8. Test the articulation. It should be the same as your other speakers.
9. Replace the white insulation in the back of the speaker case.
10. Press the speaker into the case’s face. If you wish, you can apply your preference of glue to the edge of the speaker prior to pressing it into the case.
11. Snap the grille onto the speaker.
12. Connect the speaker wires to the cube and you are done.
You should be good to go.
Posted on May 17, 2008
  • 265 Answers
SOURCE: car speakers pop when on/off new stereo preamp out to Bose amp
Hi mate
this maybe caused by a positive and negitive wire touching somewere down the line!
just follow up your wires and check
Posted on Feb 16, 2009
dunnbiker
  • 8546 Answers
SOURCE: Bose 802 C series II to Yamaha rxv 459 Amp
Tech data sheet with diagrams:
http://www.bose.com/pdf/professional/802III_techdata.pdf
In a nutshell, the controller would go between a preamp Stereo OUTput and a dedicated amplifier INPUT. You can't use Bose 901 or 802 EQ in a multichannel setup without separate amps for the Bose speakers.
The Bose 802/901 family uses full-range speakers instead of traditional woofer/tweeter combinations, so they compensate for the response limitations at the extreme frequencies by using severe electronic modification of the program material. Hence, they are a system, functionally inseparable, but the results are outstanding. Consequently, they need a dedicated amplifier so they alone get the processing provided by their electronic component.
In a vanilla stereo configuration you would just put the controller/EQ into a Tape Monitor loop but multichannel sound and digital sources won't work that way.
You should be able to draw off the (assumed) Front L&R channel preamp signal from the MD/CD-R or DVD-R Audio Out (REC) jacks (*). Run that to the Preamp In (or whatever it's labeled on the Bose EQ/Controller). DO NOT run a return RCA pair back to the Receiver as Bose-processed signals will not play well with non-Bose speakers. (*) Run the Output of the Bose EQ/Controller to a powerful separate amp for the Bose 802/901's. I use two channels on a Carver multichannel AV-406 amp but a stand-alone Carver MT-200T also works well. A good clean 100 watts/channel should suffice at home.
* If possible, choose the recorder loop you are NOT using for something else. If you're using the MD/CD-R or DVD-R Audio OUT for a recording device just get some RCA splitters to share the Stereo signal between the Bose and the device at the same time. However, once you select monitoring of that recorder two things will likely happen - 1) you'll lose the Bose and anything digital in the receiver will be disabled.
It's the nature of the digital beast that analog monitoring gets in the way of DSP.
Of course, if anyone who reads this has a receiver with individual analog Audio Outputs for the various 5.1 channels (as I do), the solution would be to draw off the Front L&R channels to the Bose EQ and downstream amplifier and the rest would be the same but without Recorder Loop limitations.
Posted on May 08, 2009
fixyathing
  • 341 Answers
SOURCE: Bose Companion 5 Speaker System won't work
check if the volume control needs to be replaced. volume controls gets bad in due time coz of the carbon layer which gets thinner and thinner till it gets cut off
Posted on Aug 12, 2009
  • 8 Answers
SOURCE: Want to connect non-bose speakers to a bose lifestyle system
this is possible, however not a very good idea.
Bose speakers are designed a little different than other brand speakers, the Equalizer built into the bose system will probably not sound amazing when you hook up your other speakers. Are you looking for more bass? cleaner highs?
if you want more bass, you could try doubling up your subs, if you want cleaner highs you could buy Bose Jewel Cube Speakers (purchased from a Bose Built-Invisible Dealer
Posted on Sep 12, 2009
Reconnecting/retiring Bose speaker cones. Inside speaker I have four coloured wires....Red,Black, Green & Orange....which connectors do they attach to on the speaker cone?
Since you posted this in cars and trucks I assume this is a bose car system. Most bose auto systems have the amp physically attached to the individual speakers. This means each speaker needs the following wires +12v, 12v ground, + signal and - signal. It also means that the head unit cannot directly drive a non bose speaker. If you are replacing the speakers and bose radio the best thing to do is to run new speaker wires. You can reuse the factory ones if you can identify which ones are what...and that may be a pain. If the bose amps are ok and you want to replace the speaker you would need to leave them connected and wire the new speaker to the wires on the bose speaker that come from the bose amp. Depending on the specific bose system there may be an actual wire that runs to the speaker from the amp but on others the amp is directly connected to the voice coil leads of the bose speaker.
Oct 13, 2016 | Cars & Trucks
Bose L1 speaker short circuit, blow out speaker
If you reset the system (disconnect all cables including power for two minutes) and power it back on, and there are no lights or sound then there is nothing you can do to fix it. You'll need to talk to Bose L1® Support
Call Bose® Product & Technical Support at (877) 335-2673 (U.S. and Canada only)
Monday-Friday: 8:30 AM - 9:00 PM ET
Saturday 9:00 AM - 5:00 PM ET
Or write to them at the Bose Forum
Aug 12, 2012 | Bose L1 Speaker
How can i bypass the stock amp in a 2000 pontiac grand prix with the bose speaker system in it with out taking the bose speaker's out?
you can't. the bose system is just that, a system. you need all the pieces for it to work. the head unit doesn't have any power and you need the amp to drive the speakers. also, bose is a proprietary system. only bose parts will work for it. so you can't buy any amp off the shelf and swap it out. if the amp is bad you need to buy a replacement bose amp or replace everything with a new head unit and speakers.
Apr 12, 2011 | Car Audio & Video
@I got a bose acoustmass 7 it has three inputs left right center,and three outputs left right center dont have paper work I need like a diagram or instructions on hooking it up please help.
you need to run the left speaker output from the amp to the left speaker input on the Bose, the right speaker output on the amp to the right speaker input on the Bose, the center channel output on the amp(assuming it has one), to the center channel input on the Bose...then the right output on the Bose , to the right Speaker..the Left output on the Bose to the left speaker...and finally the center channel output on the Bose to the center speaker
Jan 07, 2011 | Bose Acoustimass 5 III System
I have the following equipment and am going crazy trying to figure out how they get connected together. I also have the Carver Multi CD player and Carver Cassette Deck which I was able to connect to the...
Get a separate amp for the 901's and the rest falls into place.
1,2, 5) Place the 901 Active EQ between the pre/main front OUT of the receiver and the TFM-55X. Attach the 901's. Keep track of the jumpers you remove from the receiver. Or replace the jumpers with RCA splitter cables so you still have pre/main connection but can share the output with the TFM.
3) Pinnacle subwoofer (self-powered?) to the subwoofer out of the receiver.
4) Bose (AMS???) 5. As surrounds on the receiver. Place the sub module toward the rear so it mates sonically and directionally with them.
What? No center speaker? I'd get something more robust with bass capabilities, like a pair Bose 301 series 1's because the tweeters face in one direction only.
Except for the amps and the cube stuff that is essentially what I have. 6.1 with full-range speakers everywhere.
Aug 31, 2010 | Onkyo TX-SR803 Receiver
Speakers causing computer problems companion 5
Hi, I have these also & mine occasionally go to the red light while the PC is on.. Are they visible in the 'Sound' in control panel as Bose USB Audio' is this set to default? Is the USB kept in the same socket? & are they too close to other speakers?.. Let me know
Mark
May 04, 2010 | Bose Companion 5 Multimedia Speaker System...
I have a bose companion 5 and when i pwer it up the sub buzzes and then trips on overload has anyone had this issue before ?
Yea, thats why i switched to a Logitech Z2300, get the same sound for less.. the amp in your bose is gone. Need to replace the system or but the above mentioned product.
Apr 18, 2010 | Bose Companion 5 Multimedia Speaker System...
Jul 28, 2009 | Bose Lifestyle 38 System
I have a Bose Accumass 6 system connected to an Onkyo amp running as a entertainment system on our boat. The quality is sufficient for what we need. The amp (a TX-DX575) has A&B speaker switches for a...
two 8 ohm speakers in parallel is 4 ohms.
if series 16 ohms.a high resistance will just produce less power.
too low a number can activate the speaker protect,or blow the amp.
radio shack sell wall mounted speaker controls,but 5 watt max.
the best thing is to run 2 amplifiers.one for in ,2 for out
speaker a and b on the amp parallel the speakers.
if you run 2 sets of 4ohm speakers,the amplifier load will be 2 ohms,and overheat the amp.4 8 ohm speakers,gives a 4 ohm load
May 09, 2009 | Onkyo TX-DS575 Receiver
Bose Lifestyle 50 - connection to a non-bose amplifier
The 2 system are completely different your is low level input and its is having only 2 input L and R when those signal they get inside your sub it process through an DSP ( Digital Signal Processor ) and become 5 output to yours satellite cube speakers
The AM6 or 10 are high level input connected direct to any output of any AMP from those signal they convert down to low frequency for sub woofer
Nov 26, 2008 | Bose Lifestyle 38 System
Bose LifeStyle 5 Series-III CD Shelf System Logo
236 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
