Question about Lexmark X8350 All-In-One InkJet Printer
X8350 uninstall difficulty with vista upgrade
I upgraded from Windows XP to Vista 32 bit. The Lexmark site says I have to uninstall old version before installing Vista version. But when I attempt to uninstall Lexmark through Control Panel it does not remove it. It almost immediately wants to restart the computer. How do I get the old version uninstalled?
  • Thomas F. Schneider May 11, 2010
    START - CONTROL PANE L- PRINTERS & FAX - highlight printer then on the left side of the screen hit - DELETE THIS PRINTER
    You did al of that?
  • 33 Answers
If you have the print driver still installed, go to "printers & faxes", right click on the lexmark printer, select properties from the drop down menu, if you are on the general tab look for the button that says print test page, print the test page and look at it for all the ".dll" files the printer installs, search for these one at a time and delete them from computer as you find them. If you dont find them then the printer is truly un-installed. Finally make sure you download the latest driver from the Lexmark site and install it.
Hope this helps,
printdoctor
Posted on Jan 04, 2009
Can Vista Home Premium be upgraded to window's 7?
      If you're running a 32-bit version of Windows Vista, you can only upgrade to a 32-bit version of Windows 7. Similarly, if you are running a 64-bit version of Windows Vista, you can only upgrade to a 64-bit version ofWindows 7. Otherwise, you'll need to use the Custom option to install Windows 7.
      Upgrading from Windows Vista to Windows 7 - Windows Help
      windows.microsoft.com/.../windows7/.../upgrading-fro... Microsoft Windows
    Feedback
    windows.microsoft.com/.../windows7/.../upgrading-f...
    Microsoft WindowsIf you're running a 32-bit version of Windows Vista, you can only upgrade to a 32-bit version of Windows 7. Similarly, if you are running a 64-bit version of Windows Vista, you can only upgrade to a 64-bit version of Windows 7. Otherwise, you'll need to use the Custom option to install Windows 7.
    How To Upgrade from Vista to Windows 7 Home Premium ...
Feb 08, 2016 | Computers & Internet
I could not upgrade neither windows XP, Windows 7 of this Product Model: GT5662. Would you assits? Thanks.
Hello kelvinvu, according to the information that I gathered from this computer model, it has Windows Vista 32 bit home premium installed on it. Windows XP is an older operating system so you can't "upgrade" to it. You could however install a fresh copy (more likely completely erasing all your previous information on vista and data files) or you could upgrade to Windows 7. Since you are using "Windows Vista 32 bit home premium", you have to upgrade to "Windows 7 32 bit home premium" or better. So if you were trying to "upgrade" to Windows 7 Home Basic, it will not allow that since it considers that a downgrade in the Operating System. You should actually be able to pop in the Windows 7 Home Premium CD while vista is running and start the upgrade process pretty painlessly that way. Just access the CD and walk through the menus for upgrading Vista to Windows 7. As a reminder, you must use the 32 bit discs. If you try and use the 64 bit discs (a different operating system as far as windows is concerned) you will have to go through the same process of installing a new version of windows (not upgrade). I hope this has solved your specific problem kelvinvu, have a great day!
May 15, 2011 | Gateway GT5662 Desktop PC
Where I´can finde a driver
You can download the Lexmark X8350 driver from the Lexmark website for free. Use the Vista driver in Windows 7. First, check if your computer is running on 32-bit or 64-bit system type. Go to Start menu-> right-click on Computer -> Properties. Take note of the System Type.
Download the driver using the link below: Download, execute the file and follow the instructions on the software. Hope this helps. Thanks.
Jan 20, 2011 | Lexmark X8350 All-In-One InkJet Printer
INSTALLATION OF LEXMARK X5250 PRINTER ON WINDOWS 7
Hi, Lexmark printer drivers can be found on this site: Driver Update Software for XP Vista 7 8. Have a nice day
Thomas
Apr 09, 2010 | Lexmark X5250 All-In-One InkJet Printer
Can not get to work with Windows 7 - Tried Driver for Vista, XP and even let Windows 7 find driver with no luck. Tried it was a printer through another computer on home network no luck. Ready to give up......
Hello. Podita's link to the Lexmark website for the X8350 driver is correct. But you need to uninstall the existing driver first before using the driver from the website. To uninstall the software properly, go to Start Menu > Programs > Lexmark Series folder > Tools > Uninstall. Restart pc. Then, check if your computer is running on 32-bit or 64-bit operating system. Download cjr8300EN.exe for 32-bit or download cjs8300EN.exe for 64-bit operating system. Install the software. Hope this helps. Good luck!
Mar 24, 2010 | Lexmark X8350 All-In-One InkJet Printer
Vista x32 want to upgrade vista x64
microsoft provides upgrade discs from it's site (you should payteh freight).
If u are using Microsoft Windows Vista Home Basic, there is no way to upgrading.
else, the other versions allows u to upgrade.
remember: the only difference between 32 and 64 bit is the RAM memory usage (32 bit will not use more than 3,2GB RAM), and there are a lot of programs that won't run properly in 64 bit version .
Jul 26, 2009 | Microsoft Windows Vista Home Basic with...
Canon MP500 all in one printer is not compatible with Windows Vista. Is there a solution for this problem, or do I need to buy a different printer?
My Canon PIXMA MP500, purchased in mid-2006, came with the (then) ScanSoft OmniPage SE2 software on a CD. The PC had WinXP Installed. I had no use for the ScanSoft it so I made no effort to install it.
Fast Forward:
Two PC crashes later, July 2009. Using Win Vista Home Premium
LOST, important WinWord document file, only a hard copy available.
I tried to recover, scanning the "Xerox" copy. The SE Version of OmniPage was very complicated but I succeeded in producing a replacement *.doc file.
It appears that newer editions of WinVista contain the right printer drivers for this Canon Model.
Apr 26, 2009 | Canon Pixma MP500 All-In-One InkJet...
Upgrade vista home premium
As per my knowledge, there is no version of Vista called Vista Professional like in Windows XP.
Make sure what is the version to which you want to upgrade to from Vista Home Premium to Vista Business or Vista Ultimate.
The available versions of Vista Operating Systems along with the features supported from the Link below :
http://www.microsoft.com/windows/windows-vista/compare-editions/default.aspx
However, if you want to Upgrade the current version of Vista to a higher version like Vista Business or Vista Ultimate, you need to purchase Vista Anytime Upgrade kit from any retail store or directly from Microsoft.
You can find the required information related to Anytime Upgrade Kit from the link below :
http://www.microsoft.com/windows/windows-vista/get/anytime-upgrade-overview.aspx
However, make sure that you had created the Recovery Disks for your notebook using which you will be able to reinstall the preinstalled Operating Sytem along with all the Preinstalled Applications and Drivers after which you need to use the Vista Upgrade Kit to upgrade to higher version of Vista.
However, if you are currently having a 32 Bit Vista preinstalled in the Notebook, it is not possible to upgrade to a 64 Bit Vista since you can upgrade only a 32 Bit of Operating System to a higher version of 32 Bit Operating System and a 64 Bit Operating System to a higher version of 64 Bit Operating System.
Hope this helps....
Nov 12, 2008 | HP Pavilion dv6000z Notebook
Lexmark X8350 All-In-One InkJet Printer Logo
75 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
