Question about Plantronics CS50 Wireless Headset
No speaking ability
I can hear the call fine, but I can't seem to get the mouthpiece to work, is there a mute button I can't find or a setting somewhere that needs to be altered?
thank you
  • Anonymous Dec 02, 2008
    I have the Plantronics wireless office headset system CS50. Using the two switches on the back of the base, the speaker volume cannot be adjusted enough for others to clearly hear me. Any ideas to help me?
  • 16 Answers
The mute button on these is the little black button on top of the earpiece. It will only be on if you turn it on during a call. If you turn the headset off, the mute button goes off as well.
Check the compaibility 'wheel' on the side of the base station. The most common setting is 1 but some phones use 2,3 & 4. Just try it on each setting until it works. Other than that, check the microphone volume adjust setting underneath the base (ABCD switch) and see if changing that makes a difference. Of course there is always a small chance that the microphone is dead.
Posted on Nov 05, 2008
  • 5 Answers
The microphone is likely dead. As of Dec 2009, Plantronics will be raising the price of wireless headset replacements to almost double.
Get the replacement now.
Richard
www.telecomsuperstore.com
Posted on Nov 19, 2009
Others cant hear me?
Must have hit a mute button, try to locate that button. If no mute button then your phone might be broken.
Sep 03, 2015 | Lands Phones
When I call people, they can't hear me. What is wrong with my phone?
Your mouthpiece or receiver's earpiece might be not functional. To make sure, please record something and try playing it. If you can hear what you recorded, your mouthpiece is fully functional. Tell the receiver to increase the earpiece volume.Now test whether the receiver earpiece is not working. Tell the receiver to set his phone is speakerphone mode. If he can hear what you say in speakerphone mode, then the receiver's earpiece is not fully functional.
Hope this helps.
Mar 04, 2011 | HTC Wildfire Cell Phone
I can hear but customer can't hear me
You either have it set on mute or the mouthpiece isn't adjusted properly. Do a sound check to make sure it's where it needs to be.
Jun 14, 2010 | Plantronics PL-CS55 Wireless Headset
When I make a phone call I can hear the person on the other line, but they can't hear me. I have taken out the battery and restarted and checked if I was set on mute, but nothing helps.
Since you can hear the caller, but they can hear you, this not issue of removing battery or mute problem.
The problem with your phone i the mouthpiece, the mouthpiece is faulty that why nobody can hear you.
All you need to do is replace the mouthpiece of your phone,.
Doing this, i mean replacing it, people will now hear you.
Take care.
Apr 21, 2010 | LG VOYAGER VX10000 Cellular Phone
Whenever i'm trying to call, the person on the other line couldnt hear me if im using my lg prada.. i can hear them but they couldnt hear me, please help
Hello
The mouthpiece of your phone has either moved position or is no longer working.
To know what the problem is, open your phone and look at the part you normally speak through in the phone,you will see the mouthpiece move the mouthpiece so it is parallel to the mouthpiece hole of your phone.
Close the phone,put it on and try making a call to see if it is working
If it isn't then you should get a repairer to change the mouthpiece for you because it is faulty
But as a temporary solution you should get a headphone to use to make your calls
Thank you for visiting fixya
Mar 07, 2010 | LG Prada KE850 Cellular Phone
Plantronics CS60 - People I call say I sound too soft or distant
1. Check the configuration dial on the left hand side of the base to see if another setting works better. The recommended setting for most phones is 1.
2. Make sure your speaking (transmit) level is not too low. First, try increasing the volume on the telephone. Secondly, the master transmit controls are the ABCD switch settings on the bottom of the base. A is the lowest and D is the highest setting. You can fine tune this setting with the Plus (+) and minus (-) buttons on the back of the base that are above and below the picture of the microphone.
3. Double check the battery has a full charge.
To check the charge, press down on the headset into the base station to ensure it is in the base in the correct position.
The Amber Charge light on the base will flash while charging and will stay solid amber when fully charged.
3 hours = full charge
Jun 23, 2009 | Plantronics CS60 Professional Headset
I have a Samsung D900i mobile phone. It is just over 1 year old and has worked fine until today. The problem is that the person I am speaking to can hardly hear me. I have tried to clean the mouthpiece by...
They do not repair these phones nor sell parts for them, so the only real option if it out of warranty is to just replace it. Buy a UNIDEN they last much longer.
Jul 06, 2017 | Samsung Cell Phones
They can't hear me.
hi there
is there by any chance the mouthpiece speaker may need replacement? if you use bluetooth headset, it would be fine. but without bluetooth, they cant hear you.
i suggest you look for a replacement mouthpiece speaker for that to work.
hope this helps.
fixya!
Feb 04, 2008 | Motorola Mobility E815
People can't hear me - Mute button?
I have the same issue with Uniden cordless DCX640 - the phone was working fine but it seems to be on mute
Aug 27, 2007 | Motorola Mobility V180 Cellular Phone
Plantronics CS50  Wireless Headset Logo
379 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
shaun taylor
Michael Vincent Cruz
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
