Question about Fellowes P70CM Shredder
Working great until i emptied it now nothing is working
Shredder was working fine until i lifted the top to empty the bin now nothing is working. forward or reverse!!! nothing appears to be jammed in there.
  • 25 Answers
There is a sensor at the back, you can only see a small slot with a little piece of metal, the actuator, that when the top section, the shredder, is in its rigt place in contact with the box will function.
GOOD LUCK.
Posted on Nov 01, 2008
  • ClaudineDC Jan 28, 2011
    Thank you! I have been so frustrated with this shredder. Frequently, when I've removed the shredder from the basket, it wouldn't start again. After looking for jams, I finally discovered that by dropping it onto the basket it would usually work. This time that didn't affect it at all. Upon reading your suggestion, I used pliers to bend the small metal L bracket up toward the top of the basket, and now it sits in the correct position to trigger the actuator. It works!
    Thank you for taking the time to help the rest of us.
How can i empty my bin because it is full i am doing this from my friends computer because mine no longer works
1. Unplug it; it's sharp inside.
2. Place it on an old towel.
3. Lift the top off, and set it aside.
4. Dump the bin into a bag.
5. Replace the top and plug it in.
Jan 16, 2015 | Office Equipment & Supplies
Shredder bin full
Most models: 1) unplug, 2) put something down to collect paper bits, 3) lift up the shredder top unit off the bin, 4) empty the bin, 5) try and pull out any paper from the shredder top using tweezers - first remove paper that has not fed through by pulling it back out.
Often if the bin is overfull the shredder gets clogged and won't work or beeps. When unplugged, you have to carefully remove all the bits of paper from the teeth to unjam the two rows of teeth. Remedy is to frequently empty the bin.
Jul 29, 2014 | Office Equipment & Supplies
Shredder will not operate in forward mode.
Sounds like the bin might be over full. Switch machine off. Remove top section, or open door, Empty bin. Look at shredder blades to make sure nothing is stuck in them. When sure blades are clear put back together and then switch on.
Mar 18, 2014 | Royal 15MX Shredder
The bin on my royal cross cut paper shredder will not open . It is full and needs to be emptied. It seems to be stuck near the top. If I pull any harder I am afraid the hard plastic will crack.
Yes it is probably "over-full".... you will just have to try to somehow get it open a little and start to fish out the paper without breaking the waste bin....it has to be emptied more frequently, there is no "bin-full" indicator.
Dec 28, 2010 | Royal Office Equipment & Supplies
I did not empty the shredder soon enough & now the drawer will not open. Is there a way lift off the top without messing up the machine?
Try tilting the shredder forwards and pull the waste bin out as much as you can...you may have to reach in to try to pull some of the "compacted" paper out of the waste bin...once you remove some of the paper then the waste bin should slide out more freely. This may make a bit of a mess while fishing out the paper.
Sep 12, 2010 | Royal VF1012mx Shredder
I can't get the door open do empty the shredding
You have probably got the bin so full it is stuck/jammed full of paper and you now can't remove it...this is a "consumer" model machine and to keep cost low they do not provide a "bag-full" light on the panel...you should regularly empty the bin so that the shredded paper does not totally jam the bin and in extreme cases then get caught back up into the cutting machanism and blow the pcb inside the machine...check your "users" instructions to remove the bin.
Aug 23, 2010 | Royal PX1000MX Shredder
The empty basket light stays on all the time
Try cleaning the bin full sensors. located on both sides of your machine, inside the bin,under the cutter head. If that does not solve problem, you need to replace bin full sensors.
May 04, 2009 | Fellowes Powershred 320 Shredder
OM99733
Apparently this shredder keeps going until the bin is so full you can't open it easily. That is the problem we had with ours. After unplugging the unit, I pulled the bin back and forth using the front recessed handle until I could squeeze my hand in there. I wasn't too forceful fearing I would break the front door....and this took several minutes to accomplish. I grabbed as much paper as I could....espically the compacted mass in the top section. Eventually I was able to fully open the door and clean out the bin. Hope that helps.
~Mike
Oct 22, 2008 | OfficeMax 0M96431 Shredder
Staples SPL-1506X Shredder Issue
I had the same problem. I have a solution but I do not recommend this unless you have technical experience with repairing electrical appliances. I took the back cover of the main shredder unit to expose the wiring (there are 7 screws in total). The bin full sensor has a blue, green, and red connected to it. I clipped the blue wire to defeat the Bin Full error. You can look through the plastic window to check that the bin is full.
Apr 25, 2008 | Office Depot Ativa DQ60M Shredder
Fellowes P70CM Shredder Logo
443 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
Jim Keysor
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
