Question about Canon imageRUNNER C3220 Color Copier
Canon imagerunner c3220
The machine jammed then went into E000001-004 code i changed heater units and it still reads that  code how do i reset it?
    Sniper:
  • 57 Answers
Were the heaters at fault. It is more like a thermister problem. Replace the thermisters, both. And I would also change the thermostat as well. When you are sure thatyou have removed the faulty unit reset by doing the following.. service mode/copier/function/clear/error followed byswitching the machine off and turn on again.
Posted on Dec 25, 2008
  • 35 Answers
canon imagerunner c3220 - getfile.asp?rid=1258 January 9, 2008 Product : imageRUNNER C2620 / C3200 / C3220 Title : E001 Sub Code 0004 Error :
Machine would intermittently indicate an E001 error code with a sub code of 0004.
Workaround :
Try replacing the fuser connector inside the machine. Figure 105, Page 105-1, Item # 20 in the IRC3200 Parts Manual.
Part Number FG3-2310-000.
Canon USA, Inc. Systems & Technical Support Division 1-800-528-2830
Posted on Nov 09, 2008
Error code 000000-0001
The error code has to do with the fuser unit. Try to reset the error code in service mode. If that will not clear it, you will need to replace the fuser unit...... Good Luck
Jan 12, 2013 | Canon imageRUNNER C3220 Color Copier
Large paper printing
12 x 18 is the largest size paper that can be used on this copier. If anything larger is used the machine will jam. The copier uses a series of paper sensors to track and time the paper throughout the printing process. The max is 18 inches anything over that cuase the machine to jam.
Apr 14, 2010 | Canon imageRUNNER C3220 Color Copier
How do i solve error code e 002-0101
This error indicates a problem with the fusing unit.
It may be a false code or a real problem.
You must enter the service mode in order to reset:
press the following sequence:
Reset key.
Additional Functions key (asterisk)
#2 and #8 at the same time
Additional Functions key (asterisk) again.
The display changes to service display.
Select the "Functions" tab
Highlight the "Clear" button and press OK
Highlight "ERROR" button and press OK.
Turn the machine off and on.
The machine will warm up.
If there is a real mulfunction, the code will reappear.
Sep 24, 2009 | Canon imageRUNNER C3220 Printer
Error Code E00110-0110 "Canon C3220"
The only way for you to resolve this problem is to access the yellow laser motor. Unfortunately, you need to remove the laser and check for rotational operation and replace if necesary. That's it - no one can do that for you but you.
Sep 23, 2009 | Canon imageRUNNER C3220 Color Copier
Canon Imagerunner 2200 with error code e000000-0000
Try to enter service mode, and from function clear the error.
Switch off and on. If the problem persists you have a problem with your fixing unit...
Sep 02, 2009 | Canon imageRUNNER C3220 Color Copier
Error code E000732-0001
This error indicates that it cant detect the scanner unit of IRC3220
Check the cable that connect the machine and scanner unit .switch off the machine disconnect the cable and reconnect it and switch on the machine again hope this will help
Jul 01, 2009 | Canon imageRUNNER C3220 Color Copier
Ghosting image on canon c3220
Suggest to check the transfer unit. Especially the transfer cleaning blade..
Jun 12, 2009 | Canon imageRUNNER C3220 Color Copier
Canon iR c3220 problem code E00000 0211 HELP!
problem w/fuser unit.
either it's not turning on or the temperature is not correct.
check thermistor, thermofuse, lamp
Oct 09, 2008 | Canon imageRUNNER C3220 Color Copier
Stays in warm up mode
YOUR DC CONTROLLER CULD BE BAD OR NEED TO REMOVE ALL CONNECTORS AND RECONNECT BUT MAKE SURE THE MACHINE IS TURN OFF AND DISCONNECTED FROM THE OUTLET
May 14, 2008 | Canon imageRUNNER C3220 Color Copier
Canon imageRUNNER C3220 Color Copier Logo
747 people viewed this question
old marine
old marine
Corne Viljoen
