Question about Quartet gbc 4220S Shredder
Gbc shredmaster 4220S just stopped working
This shredder just stopped working. Indicator lamps come on (all except "R" light). The unit was never jammed or forced. There is no smell that could be associated with electrical burning or melting, motor overloaded and running hot, etc. The gearbox is in good shape and moving freely. Is there anything else I should look at (fuses, reset buttons, etc. or even electronic components)?
Oh, I did check to make sure the outlet I'm plugging it into has power!
Thanks,
Jimmy
  • Jimmy Johnson Nov 01, 2008
    Thanks nerygi!
    I sort of came to the same conclusion, as the red "Door open" light shines all the time. When I shut the door the light remains on. The shredder is not sensing the door being closed. Do you have any idea how the door open sensor works (magnetic, lever, optical, etc.
    -Jimmy
  • Jimmy Johnson Nov 04, 2008
    I ended up fixing the problem myself. After careful inspection, it appears that there was a filler strip between the door and the collection bin. That filler is missing. I disassembled the shredder and found the "Door open" switch is magnetically activated. I made a wooden filler strip to replace the missing one, attached it to the top of the door and glued a small magnet on the top of the filler strip. Everything works fine now!
    Thanks to everyone for their help!
    - Jimmy
The swich is contac only , look corner up right for the located the swich internal machine. if have dude of located the swich answer........good luck
Posted on Nov 03, 2008
    Problem Solver:
  • 3 Answers
Check swich door , if door is open the machie stopped for securyti of the operator . the swich is closed whith the door is closed , good luck
Posted on Oct 31, 2008
What gallon bags does shredmaster 1256S use?
GBC Shredmaster Personal Shredder Bags Staples i use the plastic bags you get when grocery shopping they don't look pretty but they work for me
Jan 08, 2015 | Shredder Office Equipment & Supplies
On, Fwd, Rvs button has stopped working on my Shredmaster 75X. How do I fix this?
First check the power point is still working - plug in another appliance, like a table lamp. If OK check the fuse in the shredder cable plug.
The commonest reason for a shredder stopping is a paper jam, or running the shredder for too long. By 'too long', many shredders will cut-out after 5 minutes continuous working, and the sensor may take 15 minutes to cool down! Read the manual.
It maybe that the shredder cutters are jammed. Unplug from mains, and lift off top and place upside down. Use a small screwdriver and/or long nosed pliers to poke at any compressed paper wrapped around the blades - can take a while.
Apr 02, 2014 | Quartet gbc 75X Shredder
The "Bin Full" indicator light
There is a sensor in the bin area of the machine that is faulty. If you have cleaned the bin area completely and still have that problem then the sensor is bad and will have to be replaced. Look on the manufacturer website for the replacement part.
Jul 11, 2011 | Quartet gbc 4220S Shredder
Gbc shredmaster 5550x: this machine has badly worn plastic gears & one has teeth missing. Is a rebuilt drive unit available?
For an answer to this question, you will have to inquire through the manufacturer, or perhaps, there will be a advertiser who does this type of work whose name will come to you along with this answer. Look around on this page right now.
FixYa.com is not a parts or repair depot.
Thanks for your question today at FixYa.com
Jan 27, 2011 | Quartet gbc Shredmaster 5550X Confetti-Cut...
Paper shredder does not rotate in either direction
You most likely have a paper jam in the unit. Check rollers and also check gears in the motors at edges or machine. Leave unplugged while doing this and an hour or to later to reset machine's memory
Aug 20, 2009 | Office Equipment & Supplies
How to fix a stuck shredder
get a pair of needle nose pliers and pull the jammed paper out. (you may need to figure out how to pop off the top cover to get better access to the blades)
May 27, 2009 | Quartet gbc ShredMaster 950S Strip-Cut...
GBC SHREDMASTER 4220S
This is how a got my hard to fine gear!
Contact Michael Business Machines for your local dealer 1-800-223-2508
Good luck, Tom
Feb 14, 2008 | Quartet gbc 4220S Shredder
Quartet gbc 4220S Shredder Logo
589 people viewed this question
Top Quartet gbc Office Equipment & Supplies Experts
Pie-man
Level 1 Expert
pantomac nv
pantomac nv
Level 1 Expert
Bill Boyd
Are you a Quartet gbc Office Equipment and Supply Expert? Answer questions, earn points and help others
