Question about Kodak EasyShare C875 Digital Camera
Battery chargring for Kodak Easyshare DX7590
Can the camera be charged simply by using the USB connection plugged into a computer ?
    Guru:
  • 509 Answers
No. The camera does not have a charger on it. You will have to get a separate charger.
Posted on Mar 28, 2010
Kodak dx7590 camera dock will not light up
Although you did not mention what Dock you are using, I assume it is the Camera Dock 6000. Is the Dock connected with the power supply? Because only connected to the PC with a USB cable will not be enough. Also the LiIon battery in the camera, should be charged at least once. If the battery is completely empty the dock will have trouble to. The dock can be used to charge your camera. Then the lights should indicate the state of the battery. And the Dock can be used to transfer pictures to the PC. But before that will work correct you have to install the software that came with the camera. (Easy Share software)
Jan 12, 2014 | Kodak EasyShare DX7590 Digital Camera
When I plug the USB cable from my Kodak M340 camera into the USB port on my computer (running Windows 7) the camera instantly turns off. The battery is fully charged (green LED is steady when the charger...
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Dec 19, 2010 | Kodak EASYSHARE M340 Digital Camera
I have a Kodak EasyShare DX7590. Love it, works great. All of a sudden I can't load pics from the docking station to my computer. Everything is hooked up correctly. It even clicks as if the pictures are...
Consider NOT connecting your camera to your computer.
Sep 01, 2010 | Kodak EasyShare DX7590 Digital Camera
Kodak dx 7590 camera will not format a memory card?
as a short cut try putting the sd card into your sd slot and format it with your computer
May 15, 2010 | Kodak EasyShare DX7590 Digital Camera
How can I download pictures from my kodak dx7590 without easyshare software ?
Connect your camera to pc via USB and switch it on. With luck the PC will recognise your camera as an extra drive.
Its then a simple case opening up the "new" drive and cut/copy and pasting your photo's.
Or you can go to :-
http://www.kodak.com/global/en/service/publications/urg00273toc.jhtml
And download the software.
Mar 23, 2010 | Kodak EasyShare DX7590 Digital Camera
I have a DX7590 that won't charge the batteries.
Jeff, you didn't verify the type of battery that you have on your camera, is that the KLIC-5000? if yes then still it will not charged on your dock try to charged your camera using the 5V AC adapter. If your camera will not turn on using the 5V AC adapter or will not turn on using your dock it means the camera is defective and not your battery or charger. You can still contact Kodak repair center at 1 800 665 6515 they will handle your issue.
Feb 09, 2010 | Kodak EasyShare DX7590 Digital Camera
Hi, our kodak dx7590 will start up but a 30seconds
1. Make sure you will install a new or fully charged battery/batteries into your camera. Please use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher). 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera 3. Turn on your camera without the memory card. (If it works then it?s your memory card that is faulty)
Dec 29, 2009 | Kodak EasyShare DX7590 Digital Camera
Kodak easyshare c530 troubleshooting won't start
Red light indicates that the battery is out of charged., Now if th ebatetry is out of charged there will be no chances for you to connect it using your computer., C530 will not charged using the USB cable., try to charged the batetry or purchase new sets of battery
Nov 17, 2009 | Kodak EasyShare C315 Digital Camera
My Kodak Easyshare V1233 will only power up when plugged into the wall charger. Even after staying on the charger it will not power on unless plugged in.
Kodak has 3 types of charger that can be connected to a wall socket
USB AC Adapter - is especially useful when traveling, away from your computer, or just plain on-the-go. Connect your camera's USB cable to the adapter and plug it into a wall outlet to conveniently charge your camera.
5V AC Adapter - Provides in-camera charging for all KODAK EASYSHARE M and V Series Digital Cameras
Input: AC 100-240 V 50/60 Hz Output : DC 5.0 V
3V AC Adapter - Provides direct power to your camera but it will not charge the camera battery
Input: AC 100-240 V 50/60 Hz Output : DC 3.0 V
* You need to check the type of adapter your using. If your using the 5V AC adapter or USB adapter and the camera won't charge the battery contact kodak support line 1 800 235 6325 (23KODAK) for possible repair.
Nov 16, 2009 | Kodak Easyshare V1233 12.1MP Digital...
Kodak digital camera
Camera will not charge through USB interface, only DC input jack or camera dock.
Jun 13, 2008 | Kodak EasyShare M853 Digital Camera
Kodak EasyShare C875 Digital Camera Logo
66 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
