Question about Ricoh Aficio CL3500N Laser Printer
Printing problem I was using the form feed for a print job, now I would like to go back to a regular print and can't figure it out.
    Problem Solver:
  • 6 Answers
Press the job reset, then menu, then online button
www.mfpsolutions.blogspot.com
Posted on Nov 26, 2008
HOT TO ADJUST THE TEAR HEIGHT ON A MICROLINE 490 WITHOUT USING THE SETUP DISC
If you are using regular letter size continuous printer paper, load the paper normally with the machine turned off. You can even turn the knob to feed the paper through, it doesn't matter how far. Turn the printer back on and press "PARK" button. Then press the "FF/LOAD" button and when you begin printing it will automatically print at the top of form (TOF). If the TOF ever gets thrown off you can press "LINE FEED" until the tear is where you want it and press "SHIFT" > "TOF" to back back to the previous page (or top of form).
Simply put, pressing "PARK" then "LOAD" should set the tear where you need it.
May 20, 2011 | OKI MICROLINE 490 Matrix Printer
Problems with Printing Special Size Forms
you have to chk the setting on the print setup.
Jul 04, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
It begins to print then stops half way
Having the same problem here... very random... send a print job of labels and it will print the whole lot, or freeze at random points but always halfway through a label... no error message... unplug usb and replug doesnt do anything, but unplug and replug power and off it goes printing more lables but may even freeze again after only a few more have come out... also, every day the first print job of the day prints half the label and pauses for about 10 seconds then keeps going...
- Windows XP Pro SP3
- LabelWriter 400 as supplied out of the box
- Genuine DYMO labels
Jan 28, 2011 | Dymo LabelWriter 400 Thermal Printer
One label printing over two label forms
Always check to make sure the printer is advancing one label at a time by itself before printing. If it does then you know the printer has a good read on the label size. Then if it misaligns when printing then you know the problem is in the printer driver because the printer is only going to do what it's told to do.
So best is to turn printer off, power up, press feed to see if one label feeds ok. If the label feed is off at this point then the printer needs to be calibrated which is done by pressing and holding FEED while turning the printer on.
Hope that helps !
Jun 03, 2010 | Zebra TLP 2844-Z Thermal Label Printer
HP Deskjet F4200, prints blank page
I went into print settings after failing the diagnostics.
Printing normally would just feed the paper through with no ink.
I set the settings to specifically "Fast Draft" and adjusted
minor things like paper to A4 and color to grayscale for the
print job at hand.
Bingo!
Sep 09, 2009 | Office Equipment & Supplies
How to do a reverse form feed in Visual Basic 6
Two things to consider:
1) The printer itself must be designed to handle reverse form feeds. I am not sure how many these days are.
2) If you're printer can handle reverse form feeds then it should be a simple matter to send the appropriate ascii code to the printer to initiate it. Much the same as if you wanted to have the printer do a line feed.
Good luck and thanks for using FixYa.
Mar 18, 2009 | Microsoft Visual Basic 6.0 for PC
When I send a 2 page 11 x 17 job to the printer. It prints the first page and then comes up with an error light that asks for >> Load ppr, Bypass or Form Feed 11 x 8 1/2 Plain Recycled  << When I...
THE PRINTER AND THE COMPUTER NEED TO MATCH THE PAPER SETTINGS CHANGE THE SETTINGS ON THE PRINTER AND TYPE..WHEN PRINTING YOUSE THE SAME SETTINGS AS YOUR PRINTING
Jun 22, 2017 | Ricoh Aficio AP610N Laser Printer
Feed and Tear Off position problem
You can give this a try. This will alter the top of form setting.
http://www.profitmonster.com/printers/ml320tb.html
Let me know if this helps.
Mar 27, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Tally printer form feeding continually on its own
When was the last time it was services? It may be nothing more than a dirty paper sensor. Also, some Tally printer sensors require adjusting, it may be a simple matter of adjusting a sensor setting. That would require a technician with the manual and settings chart. Let me know how it goes!
May 01, 2007 | Tally T6215 Matrix Printer
Unable to use duplex printing on LaserJet 1020
Do you have Status Messages turned off? Access the Printer Properties window. Click the Configure tab (figure 1). Re-enable Status Messages by selecting On . Power cycle the printer by turning it off, then back on. Wait a few seconds for the job to resume or try printing the job again. Here is the hp link : http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00383419&cc=us&lc=en&dlc=en&product=439320&dlc=en&lang=en Good Luck
Mar 08, 2007 | HP LaserJet 1020 Printer
Ricoh Aficio CL3500N Laser Printer Logo
262 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
