Question about Akai Ewi4000s Electronic Wind Instrument
Detuning of Akai EWI 4000s
My EWI plays one semitone higher on each note. ie When set up as a C instrument and I play C then the note sounds as C sharp. When I play C sharp it sounds as D. Help please
  • Anonymous Mar 27, 2014
    when pressing the program key the display dose not lite up to show the current program.
  • Anonymous Apr 01, 2014
    some notes play loud and together
Are you shure that you aren't touching the bend up plate with your right thumb? This isn't easy detected by sax players which are used to have a thumb rest at exactly the same spot where the bend up plate is. You might switch it off (see manual). With the bend up plate on you should aways use a tight strap which helps a bit to not touch the bend up plate accidentally. I'm still struggling with this occasionally.
Posted on Dec 08, 2008
Ewi 4000s cutting off
My EWI 4000s started to play by its self making a loud low note and then it stop and now it won't play at all. I Reset to Factory Preset but that didn't help. What do I need to do to get it to play again?
Feb 09, 2014 | Akai Ewi4000s Electronic Wind Instrument
Ewi and vocoder setup
hi, i have a YAMAHA WX5, and want to know if it's to use a Vocoder?
Mike Phillips is the same, or if it only works with the EWI 4000s?
and as a connection is made?
thank you!
Feb 04, 2013 | Akai Ewi4000s Electronic Wind Instrument
Cannot play staccato, there is latency
Consider joining the forum here: It sounds like it is a velocity setting problem but the solution should be in your manual. It may also be a setting in the sound module you are using.
Jul 04, 2010 | Akai Ewi4000s Electronic Wind Instrument
Internal and external sounds at the same time
Without reading the manual, the easiest solution that occurs to me is to not use a cable between the audio out on the Ewi and the amp or mixer you are using. You can also set the main volume to zero. That setting does not affect the program volume.
Jun 20, 2009 | Akai Ewi4000s Electronic Wind Instrument
Program change on the akai 4000s
Please try to wet your fingers a little bit.
When your fingers are dry the ewi would not react properly.
Jun 15, 2009 | Akai Ewi4000s Electronic Wind Instrument
My akai ewi 4000s kind of froze
Please try to reset the ewi. You can do this like this: Shut down ewi. Press down the four little white buttons Level, FX, Setup and Trans. Keep them pressed while starting up the ewi.
This is a factory reset.
I hope this works for you.
Apr 03, 2009 | Akai Ewi4000s Electronic Wind Instrument
EWI4000s only plays one note
Hello a_marechalro,
You can try to reset your instrument.
Turn off the EWI,
Press the LEVEL, FX, SETUP and TRANS buttons.
Then turn on the EWI.
This is a Factory reset.
I hope for You this is the solution.
Kind regards,
Fred Roubos.
Dec 26, 2008 | Akai Ewi4000s Electronic Wind Instrument
EWI won't respond to comands
I've got the solution.
Turn the EWI off.
Press the LEVEL, FX, SETUP and TRANS buttons all together.
Turn on the EWI.
This is a Reset to Factory Preset.
Greetings Fred Roubos.
Dec 13, 2008 | Akai Ewi4000s Electronic Wind Instrument
Akai Ewi4000s Electronic Wind Instrument Logo
352 people viewed this question
Top Akai Music Experts
Michial Gueffroy
Are you an Akai Music Expert? Answer questions, earn points and help others
