Question about Whirlpool WED5100SQ Front-Load Electric Dryer
Turns on for 15 seconds then turns off..
The unit is brand new i've never used it. i select a load then press start button and it will run for about 15 seconds; then it turns off....
    Problem Solver:
  • 10 Answers
Testdriver03:
What you are describing sounds as if you have an electrical issue,
If you are able to check the voltage to the unit you shold have 240 voltsAC to the unit L-1 to L-2 and 120 volts Ac to L-1 to neutral and 120 volts Ac L-2 to Neutral while the unit is running I`m supecting the 120 voltage is dropping out on the L-1 leg which is normally the line on the left side.
((((But only do this test If you know how to properly use a Volt-Ohm meter
I also suggest that you contact your dryer manufacture if this is not an electrical supply issue.
woodychoppers
Posted on Nov 01, 2008
Virgin mobile venture won't start
Take the battery out. Then put it back in. I couldn't find anything that would work but doing a hard reset. Once I did that the phone worked again. I lost everything but my phone works again.
To hard reset the Virgin Venture please follow the instructions below:
Start with the phone turned off.
  1. Press power button until the phone turns on and vibrates.
  2. Press and hold the up volume button until you see the word hello.
  3. Release the up volume button.
    Note
    : You will see the word hello on the screen for about 5-7 seconds.
  4. The screen will display the android guy next to an exclamation point inside a triangle.
  5. Press the home button to access Android system recovery screen.
  6. Scroll to and select wipe data/factory reset.
    Note
    : The volume button scrolls and the enter/return key selects
  7. Scroll to and select Yes.
  8. The Venture will reset.
  9. Select reboot system now.
The Venture will reboot to the initial setup screen
Aug 10, 2012 | Virgin Mobile PCD Venture No Contract...
Tip
How to Turn Off Demo Mode
<span style="font-weight: bold;">Blaupunkt:</span><br /><br /> <ol> <li>Press the (PWR) to turn the unit off.</li> <li>Press the (DIS) and (1) simultaneously for more than 3 seconds to activate the demonstration mode.</li> <li>Press both buttons again from more than 2 seconds to cancel this mode.</li></ol>or<br /> <ol> <li>Try pressing and holding menu for 10 seconds to turn it off.</li></ol><span style="font-weight: bold;">Bose:</span><br /> <ol> <li>Unplug the unit and wait ten seconds.</li> <li>Plug it back it and press repeatedly on the eject button.</li> <li>The demo disc will eject.</li></ol><span style="font-weight: bold;">Clarion:</span><br /> <ol> <li>Press and hold the "D" button to enter the settings menu.</li> <li>Use the next track button until SCRN SVR is displayed, use the rotary knob to select "OFF".</li> <li>Press the "D" button to exit the settings menu. </li></ol><span style="font-weight: bold;">Garmin:</span><br /> <ol> <li>DO NOT DO THIS TO A FUNCTIONING UNIT. Hold down your MENU key, Go to your SYSTEM tab, SYSTEM INFORMATION.</li> <li>When the software version window come up, hit ENTER.</li> <li>Press RANGE UP 3 time, Range DOWN 3 times, RANGE up 1 time, RANGE down 1 time.</li> <li>The system should reset, when asked to use RETAIL mode say NO.</li></ol><span style="font-weight: bold;">JVC:</span><br /> <ol> <li>Hold down the SEL button for 2-3 seconds.</li> <li>Use the &lt;&lt; or &gt;&gt; buttons to find DEMO.</li> <li>Turn the VOLUME knob until it says OFF or DEMO OFF.</li> <li>Press SEL again.</li></ol><span style="font-weight: bold;">Kenwood:</span><br /> <ol> <li>Go into standby mode, hit menu and then press "hold". A menu should pop up.</li> <li>Use knob to select demo.</li> <li>Press in on the knob and hold until it says "demo OFF".</li></ol>or<br /> <ol> <li>Switch to Standby.</li> <li>While holding down 5, press Reset with a paperclip or similar and continue to hold down 5.</li> <li>Demo mode should now be off.</li></ol><span style="font-weight: bold;">Magnavox:</span><br /> <ol> <li>Press and hold the menu button for 5-10 seconds until the normal menu pops up and then go to the section that says demo and turn the demo mode off.<span style="font-weight: bold;"></span></li></ol><span style="font-weight: bold;">Pioneer:</span> <ol> <li>Turn the vehicle's key to the Accessory or ACC position.</li> <li>Press the "Source" button, located on the left-side of the radio, and press the "Off" button that appears on the screen to turn off the unit.</li> <li>Locate the "Volume/Mute" button, located on the left-side of the unit.</li> <li>Press and hold the "Volume/Mute" button until the demo mode turns off.</li></ol>or<br /> <ol> <li>Turn the radio off.</li> <li>Push "Memory 5" or "Memory 6" (depending on your model) for just a second.</li> <li>When you hear a beep, demo mode is off.</li></ol><span style="font-weight: bold;">Pioneer Premier:</span><br /> <ol> <li>With the unit Off and the car ignition On and Running, press button number 5 and release that button to turn off Demo mode.</li></ol><span style="font-weight: bold;">Sharp:</span><br /> <ol> <li>When the unit is in the power stand-by mode (demonstration mode), press the X-BASS/DEMO button.</li> <li>The demonstration mode will be cancelled and the display will disappear.</li></ol><span style="font-weight: bold;">Sony:</span><br /> <ol> <li>Press display twice to turn off Demo mode.</li></ol>or<br /> <ol> <li>Press and hold the select button.</li> <li>Press the select button repeatedly until the desired item appears.</li> <li>Rotate the control dial to select the setting DEMO.</li> <li>Rotate the control dial to select the setting DEMO-OFF.</li> <li>Press and hold the select button.</li></ol><br />or<br /> <ol> <li>Press the STOP and the EJECT buttons simultaneously for 5 seconds.</li> <li>UNLOCKED should now appear in the display and you should be able to eject the disc.</li></ol>If Demo mode comes back on every time you turn off the ignition and back on, you have a wiring problem with your Constant +12 Volt Memory wire.
on Jun 22, 2011 | Audio Players & Recorders
My washer has the "control
Various control lock features on differing models:
Press the end of cycle signal button for 3 seconds
OR
To reset press the DRAIN/SPIN button and hold it for 15 seconds.
OR
Press and hold the END OF CYCLE button for 15 seconds to reset the control.
OR
Press options and select for 10 secs till LOC is no longer displayed
Jul 09, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have a Breadman TR875 breadmaker. It will not do anything when I hit start. I've tried to unplug it, but didn't help.
I believe for this perticular model to power-up, you must press the Select button first to select a mode, then press the Start button.
Here's more on the subject...
Addressing Power-up/Start-up Issues:
1. Unplug the breadmaker.
2. Confirm the power source your accessing is live using a blender, toaster, etc.
3. Plug the breadmaker in.
4. Confirm the breadmaker is receiving power:
    1. Some models have a built-in off/on switch. Turn it to the ON position.
    2. Some models make an audible tone when plugged in.
    3. Some models have a colored light and/or a lighted display screen that lights up.
    4. Some models require you press the Select button down until the unit powers up.
    5. Some models require you press the Start button down until the unit powers up.
    6. Some models require you press the Select button first to select a mode, then press the Start button.
3. No, you were not able to confirm that your breadmaker is receiving power? Sorry to hear that. Attempt to have the breadmaker serviced by a small appliance repair facility or discard it.
4. Yes, you have confirmed that your breadmaker is receiving power? Fantastic! Now reset the breadmaker by pressing down on the Start button until you notice a visible and/or audible confirmation, usually within 5 to 10 seconds. Note: It bears mentioning again at this point that some models require you press the Select button first to select a mode, then press the Start button.
Jun 20, 2011 | Breadman Kitchen Appliances - Others
Dead? wont turn on
I had this happen to me on one occasion. Pressing the power button any number of times would not turn on the unit. Also, plugging in the car charger did not turn on the unit or charge it either.
I found that holding the power button for 10-15 seconds forced the unit to reboot, and it started just fine after that.
Since then, I've had an even more irritating issue, where holding the power button for 10-15 seconds would restart the unit, but it would freeze at the "loading maps." part. I ended up plugging the unit into my PC, which started it for purposes of data transfer. I then disconnected it from the PC and it restarted properly.
Try those out and see if you have any better luck.
Apr 16, 2010 | Garmin nuvi 260W GPS Receiver
No turn on gps garmin
I had this happen to me on one occasion with a nuvi 1300. Pressing the power button any number of times would not turn on the unit. Also, plugging in the car charger did not turn on the unit or charge it either.
Apr 14, 2010 | Garmin nuvi 765T GPS Receiver
Nuvi 750 will not turn on
Apr 14, 2010 | Garmin nuvi 750 GPS Receiver
How can i reset a router
There's a reset button on the back of the router, it's a small button that you can press using a paper clip. Press it for 15 seconds to reset it.
Reset 1:
Press the reset button for 15 seconds at the back of the router while the router is on.
Reset 2:
Press the reset button for 15 seconds while the router is on after 15 seconds unplug the power cord while holding the reset button then count another 15 seconds and release the reset button. Then plug the power cord back in.
Reset 3:
Press the reset button for 15 seconds while the router is on after 15 seconds unplug the power cord while holding the reset button then count another 15 seconds and plug the power cord back in while the reset button is plugged in and count another 15 seconds release the reset button.
Hope this helps.
Jan 11, 2010 | D-Link Computers & Internet
Trouble turning on, displays no mech mode then goes to cartridges
From HP Tech support:
1. Verify that configuration button (Setup button) was not pressed (it was not pressed)
2. Disconect the power cord from the unit
3. Press and hold configuration button
4. Connect the power cord to the unit
(this way the unit gets out from the "No Mech Mode")
5. Stop pressing configuration button (I waited about 15 seconds)
Doing this, the unit seemed to be reset by an intialization process as the cartridges adjusted. It worked fine for me. Not sure of the purpose for error.
Aug 07, 2009 | HP PSC 1610 All-In-One InkJet Printer
Telko s002 manual
Nesecito manual programming! s008b of Telkes. Thank you now!
Sep 12, 2007 | RCA 25110RE3 Phone
Whirlpool WED5100SQ Front-Load Electric Dryer Logo
61 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
