Your mobile is locked with network provider.so whenever you insert a other network, your mobile asking the restriction code.You can get the restriction code from http://www.superunlockcodes.com/ .It helps to unlock your mobile easily.
SOURCE: i have nokia xpress music 5130 and it gives me
I myself own this awesome music phone.
Find the answers below:
1) As it shows less internal memory, it seems that you have transfered some data like mp3, video clips through bluetooth to this phone and it was saved in the recieved folder which autmatically saves in phone memory. Try saving the data to memory card and you will get the phone memory free.
2) Check the above reason for this same issue.
3) You need to select proper connectivity mode under settings of this phone. Go to settings and then open connectivity folder. Here select the connection mode.
Make sure to install the latest PC suite software on the computer. This can be downloaded from the NOKIA website.
Regards
Anand
Rate it, if it helps.
SOURCE: Forget my mobile security code(Nokia 5130c XM)...Plz Help
4745066750 try this. it is your master code, hope it helps
SOURCE: how i format my nokia 5130c-2 xpress music..
how i format my nokia 5130c-2 xpress music.. without using security code,, bcoz i forgot it
SOURCE: what is the code restriction
Ask service provider for Unlock code to Unlock the Mobile from Network Lock..
SOURCE: How can i reinstal my nokia 5130c-2 xpress music
It is very difficult to update a mobile software without any experience or training in software repairing. you need the flash programs and flashing tools and your mobile's software you wanted to update. If you are not a mobile repairer then don't do it by yourself because there is a risk of phone's being dead. so he if you want to update your mobile's software go to your mobile's service center and ask them for doing this.
