Mag Innovision LT976S 19 in. Flat Panel LCD Monitor
Problem for Mag Innovision LT976S 19 in. Flat Panel LCD Monitor
Monitor blacks out
By mcdusty on Sep 16, 2006
Im having a problem with my moitor. The screen goes completely black but the power light it still on. It started doing this after it was used for a bit but now does so as soon as I turn it on.
The thing I dont get is I took it up to best buy to have them check it out but it didnt do it there. Im assuming then that it is my computer but have no idea how to fix this. Any ideas for me? Thanks!
Same Problem
May 22, 2009
-   monitor blacks out-   Guest
Aug 31, 2008
-   My monitor it works for a littel while but then it black out-   lenlukesan
Aug 31, 2008
-   IT JUST GOES BLACK-   Guest
Feb 12, 2008
-   I have a nec 1810 18" lcd monitor I bought as A SET OF THREE UNTESTED MONITORS FROM EBAY. TWO ARE FINE BUT THE ONE METIONED ABOVE TURNS ON BUT THEN FADES OUT. WHILE IS ON THE RESOLUTIONS ARE GREAT -LIGHT STAYS ON GREEN AT ALL TIMES BUT NO IMAGE -ANY IDEAS?-   gouldianguy
Jan 01, 2008
-   HP M70 monitor comes on o.k. 90% of the time, but it fades to a black screen and then it fades back to a normal screen. If it does not fade back to normal in a few seconds, 1 or 2 light taps on the monitor brings it back to normal. Fading to black and then back takes about 20 seconds. Somedays it does it 5-10 times, other days it does'nt do it at all. 10% of the time we tap it to make it come on.-   kaleen
Best Solution
posted on Apr 30, 2008
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Its not you or your PC. if you read around, its clearly a monitor problem, a manufacturer monitor problem, since so many people are having the exact same problem.
I cant turn my computer off once my screen is working, in fear of me having to sit there for a good 5-60 mins turning off and on, and off and on the pc and monitor again after again to hope the next time the screen isnt just plain black.
Solution #2
posted on Sep 18, 2006
Somewhat Helpful)
dugiehowsa
Rank: Wiz
Rating: 77%, 871 votes
Sounds like your video adapter settings have been wedged. If you are running Windows XP Service Pack 2, you can use the following steps.
1) Boot the laptop into safe mode. Boot into safe mode with networking support if possible. This can be done by tapping the F8 key as the computer first turns on.
2) Once you are at the Desktop, right click on My Computer and select Manage.
3) In the window that appears, select Device Manager from the menu on the left.
4) Find Display Adapters on the right and click the plus sign. This will list the video adapter that you have.
NOTE: WRITE this down EXACTLY. You may need to go and get drivers for this. Seeing this is an older model, I doubt you'll need it, but better to be safe then sorry.
5) Go to your manufacturers support web site and download these drivers. You may not need them, but better to be safe then sorry.
http://tcc.toughbook.com/
NOTE: Skip step 5 if you did not boot with network support or cannot get to the Internet. This can be done from normal mode.
6) Right click on the display adpater and choose un-install. Hit OK on the window that appears and reboot the machine when the process is done.
7) The machine will take longer than usual to boot, as Windows XP is re-discovering the video adapter and resetting everything to the defaults. When it is done booting, the screen may look weird since the settings are now the defaults. You can the set them to what you want by right clicking on the desktop and selecting properties. Then go to the settings tab.
8) IF it did not re-discover the video adapter (this can be confirmed through the device manager), then go ahead and install the drivers. Windows Update will most likely also have the drivers.
NOTE: This process should work with Windows 2000 as well, although I was not able to test it. The only issue I can think of is that it may not auto-discover the video adapter, and you would have to manually download and install the drivers.
Was this helpful?
Yes
No
Popular Solutions for Mag Innovision LT976S 19 in.
Questions and Unsolved Problems for Mag Innovision LT976S 19 in.
Do you recommend Mag Innovision LT976S 19 in. Flat Panel LCD Monitor?
Answer
Answer
Envision monitor speakers were working an hour ago now not working... help? All sound settings are... (More)
Answer
I was working in excel while avg anitvirus software update 8.5 was downloading in the background and... (More)
Answer
the screen change color and then now it just all yellow. i try adjusting the color but it doesn't go... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Mag Innovision LT976S 19 in....:
Top Monitor Experts
Rank: Guru Guru
Solutions: 744
Experience: 30 Years of professional repair and design.
Ask Me
Find more Monitor Experts
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
