Question about HP Pavilion ZV5000, ZV6000, ZX5000 Series 12 Cell Li-Ion Battery - DP390A (DP390A1) CD-ROM Drive
HP Pavilion ZX5000
When plugged in without battery pack (no longer using battery pack because it is drained out), the laptop starts up but then shuts down, sometimes right away, sometimes after some time, sort of erratically. Any suggestions? Thanks.
    Scholar:
  • 83 Answers
Try to check your adaptor/ charger because it might have been the cause of your battery being drained. Your wire might have been worn out. some wires inside might have been cut off. So that is why even you directly turn into AC-DC connection your PC still doesnt work. If it doesnt work replace your adopter.
Posted on Nov 09, 2008
Hi, hp pavillion zx5000 will not power on. The power source is good. I have tried it with & without the battery. I tried no batt & ac and holding down the on button for 30secs; holding down the on...
I would try the following steps, then contact HP (if these don't work, chances are it's hardware related).
1) Remove the battery and power cable. 2) Hold down the power button for 3 seconds. 3) Reattach the power cable and battery. 4) Try to boot again.
Mar 01, 2011 | HP Pavilion zd7000 zx5000 zv5000 presario...
My battery always stays charged, so why is my laptop telling me that i need to replace my battery?
Hi,the reason why your laptop is telling you to replace Battery is,you have killed your battery without knowing by Charging it always,since you have constant power supply,you should at least after getting a new Battery,discharge it four to five times a week longer life of battery,by these i mean,unplug cord from mains let power drain to 5% or 10% before charging again while working and if fully charged and you are not making use of it disconnect and if you want to make use of it use battery instead do not connect immediately to mains until power drains from battery.Just like your mobile phone,you only charge it when need be(ie. when Battery is Low).
Jan 01, 2011 | HP Pavilion DV7-1020US Laptop
4 beeps on my Hp pavillion dv6000, blank screen
No Screen on Pavilion DV2000T
I had this problem before. Tere is a good chance this may work.
First of all remove the ram memory.
-remove battery pack and wait 10 mins
-now start charging laptop without battery pack for 2 mins
-unplUg the power AND press and hold the power button for 45 seconds
-REPLUG THE POWER CABLE BUT DONT PUT THE BATTERY PACK YET
NOW OPEN THE LID WIDER YOU CAN PRESS POWER BUTTON YOU WILL SEE YOUR SYSTEM WILL START. ONCE YOUR SYSTEM IS READY SHUT IT DOWN PUT THE RAM AND BATTERY PACK BACK AND CONTINUE TO USE YOUR LAPTOP.
It hope fully will work as if you get one or more beeps, the POST is completing alright.
Hope that helps.
Dec 10, 2010 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Is this hp pavilion dv1000 battery a cheap one?
From the link you gave its seen that its comparatively lower than the other series.. Brand: HP Laptop BatteryBattery Info:
Li-ion, 4400 mAh, 11.10V, Black, 310.00(g), 205.15 x 59.20 x 37.50 mm
Rating: rate4.gif
Capacity Voltage Price($) 4400 mAh 11.10V C $ 57.79
8800 mAh 11.10V C $ 79.69
Availability: In stock
Notes for charging Hp Pavilion dv1000 Series battery :
  1. You must fully drain the Hp Pavilion dv1000 Series battery until the laptop goes into hibernation for your first use it.
  2. Store it in a cool and dry area. Do not expose battery to water or other moist/ wet substances.
  3. Do not forget to take away your Hp pavilion dv1000 battery from the laptop if you will not use it for a long time.
  4. Know that after that plug in your charger and allow it charge for 12 hours or depending on what the technician has told you. 12 hours is the max and you can use it while charging .
  5. Charge new Hp Pavilion dv1000 Series battery for three times at first. After that it will take less than 2 hours to fully charge your Hp Pavilion dv1000 Series battery.
  6. It is normal for HP laptop battery to become warm during charging and discharging.
  7. Learn that this is recommended so that the Hp Pavilion dv1000 Series will heat up for the time allowing ions to reawaken.
Jan 20, 2010 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
HP Pavilion zv5000 - No power with battery in.
the jack is the problem it is not getting enough power to laptop
Nov 02, 2009 | HP Pavilion zd7000 zx5000 zv5000 presario...
I am getting audio devices not found on my HP pavilion zx5000....
Here's the website where you can get your audio driver. Download the .exe file and run it, the installation should start automatically after extraction.
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=ob-44349-3&lc=en&dlc=en&cc=us&lang=en&os=228&product=385151
May 19, 2009 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
Hp pavilion zv5000
It is most likely a motherboard problem. You would have to take it to a service center for diagnostics. If it is the problem it may be time for a new laptop
Mar 25, 2008 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
HP pavilion will not shut down
pull the power cord out and the battery (or just let it run out). Then, try turning it back on again. If it does the same thing again then yes it may be old blue death and your harddrive may be worse than dead. I don't believe that the power button doesn't work. Hold it in for 10-15 seconds or so, any computer is DOS programmed to respond to the power commands above all, even above the dreaded blue screens. Let me know if I'm an ******* and I don't know what I'm talking about or if you need more help.
Mar 07, 2008 | HP Pavilion zd7000 zx5000 zv5000 presario...
HP Pavilion ZV5000, ZV6000, ZX5000 Series 12 Cell Li-Ion Battery - DP390A (DP390A1) CD-ROM Drive Logo
83 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
