Question about Foxconn eBOT Barebone
Front LCM Time
I cant get the time right on the front LCM the time in the BIOS is right but when i shutdown my E-Bot in about 10 mints it will gain 15 mints and the USB is still powered after shutdown please can some one help this is the second E Bot with the same problems
    Problem Solver:
  • 5 Answers
I am assuming E-Bot is the model of your PC. Replace CMOS battery inside the computer (CPU), which stores your BIOS settings and powers the clock providing time.
Posted on Jul 28, 2007
Right low beam headlight does not come on but my right turn signal will stay even tho i diddnt turn it on. If I cut on my high beams the rurn signal cuts off. Whats wrong? Helo
It could be the lamp control module !
Headlamps
Battery positive voltage (B+) is applied at all times to the lamp control module (LCM) through the underhood fuse block HDLP fuse.
When you place the headlamp switch in the HEAD position, the headlamps input to the LCM is grounded. The LCM then applies battery positive voltage (B+) through the underhood fuse block HDLOBML fuse and HDLOBMR fuse, which feed the left low beam headlamp and the right low beam headlamp respectively. When you activate the headlamp dimmer switch by pulling on the multifunction lever until the switch clicks, the high beam input circuit to the LCM in grounded . The LCM then removes battery positive voltage (B+) from the low beam headlamps and supplies battery positive voltage (B+) through the underhood fuse block HDHIBML fuse and HDHIBMR fuse, which feed the left high beam headlamp and the right high beam headlamp respectively.
Check this fuse in the left under hood fuse box first. HDLOBMR Fuse 18 10 Amp. RH Low Beam Headlamp . If the fuse is good check for B+ voltage with the low beams on . Use a test light or volt meter . If you look on top of fuse there are two metal tabs ,check there for B+ voltage , If no B+ voltage the LCM - lamp control module isn't supplying any .
Lamp Control Module (LCM)
Under the left side of the IP, to the right of the steering column
Turn Signal Flasher
Lighting Systems Component Views in Lighting Systems
Lighting Systems Connector End Views in Lighting Systems
Turn Signal/Hazard Switch
In the left front of the passenger compartment, in the steering column
Apr 28, 2016 | 2000 Buick Park Avenue
Hd-56g647aa jvc tv theres a tv lock code kids got ahold of the tv remote but the lock comes up all the time and cant watch tv for longer then ten-fifteen minutes screen turns black and tv locks ive been...
Hi Anthony
Please try to go on the tv lock code features, may be you were able to set time. You just mention that 10 to 15 mints your tv will turn to black and then lock. You need to off the setting.
Jan 16, 2014 | Televison & Video
Fuse box layout for 2005 honda crv
No. Amps Circuits Protected 1
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38 7.5
15
10
7.5
(15)
(20)
_
10
7.5
7.5
10
10
10
7.5
7.5
10
10
20
15
7.5
20
_
_
(20)
20
20
(20)
15
15
20
(15)
20
20
7.5
7.5
10
7.5
30 Power Window Relay
Fuel Pump
ACG
ABS/VSA
Heated Seats*
Front Fog Lights*
Not used
Rear Wiper
ODS (Occupant Detection System)
Meter
SRS
Right Headlight High Beam
Left Headlight High Beam
Small Light (Interior)
Small Light (Exterior)
Right Headlight Low Beam
Left Headlight Low Beam
Main Headlight High Beam
Small Lights MAIN
TPMS
Headlight Low Beam
Not used
Not used
Moonroof*
Door Lock
Front Left Power Window
HAC Option
Rear Accessory Socket
Accessory
Front Right Power Window
Accessory Power Socket on the Center Table*
Rear Right Power Window
Rear Left power window
ACC Radio
ACC Key lock
HAC
Daytime Running Lights
Front Wiper * If equipped
Dec 06, 2013 | 2005 Honda CR-V
Headlights don't work unless you hold high beams
Check the headlight Relay and/or fuses - should be in the fuse panel.
GL,
Td
Oct 01, 2012 | 2004 Mercury Grand Marquis
I have imb r40 2681 its shutdown automatic after 10 or 15 mints tell me how to fix it
Sounds like you need to go in to the Control Panel and then Power options and change the settings.
Jan 26, 2012 | IBM ThinkPad R40 2897 Notebook
Translating japanese to english on fuse box
is located under the dashboard on the driver's side. The fuse label is attached under the steering column. If something electrical in your vehicle stops working, check for a blown fuse first. Below table outlines detail fuse number, its ampere and circuits protected. honda-crv-interior-fuse-diagram-thumb.png
No.
Amps
Circuits Protected
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38
7.5 15 10 7.5 (15) (20) _ 10 7.5 7.5 10 10 10 7.5 7.5 10 10 20 15 7.5 20 _ _ (20) 20 20 (20) 15 15 20 (15) 20 20 7.5 7.5 10 7.5 30
Power Window Relay Fuel Pump ACG ABS/VSA Heated Seats* Front Fog Lights* Not used Rear Wiper ODS (Occupant Detection System) Meter SRS Right Headlight High Beam Left Headlight High Beam Small Light (Interior) Small Light (Exterior) Right Headlight Low Beam Left Headlight Low Beam Main Headlight High Beam Small Lights MAIN TPMS Headlight Low Beam Not used Not used Moonroof* Door Lock Front Left Power Window HAC Option Rear Accessory Socket Accessory Front Right Power Window Accessory Power Socket on the Center Table* Rear Right Power Window Rear Left power window ACC Radio ACC Key lock HAC Daytime Running Lights Front Wiper
Dec 13, 2010 | 1997 Honda CR-V
2004 crown vic interior lights stay on
Don't think you have a door ajar switch problem , more then like the lighting control module is the culprit . Does the door ajar light on the instrument cluster stay lit ?
The interior lighting can be separated into two distinct modes of operation: the courtesy lighting and the demand lighting. The lighting control module (LCM) controls all of the interior lighting in the vehicle, as described in the following text.
The front dome lamps, rear reading lamps, and instrument panel courtesy lamps, can be illuminated either by opening any of the vehicle doors (courtesy lamp function) or by depressing the headlamp switch (demand lamp function).
When any door is open, the door ajar switch grounds an input to the LCM which then sends power to the courtesy lamps. The voltage sent to the courtesy lamps gradually increases from 0 volts to 12 volts within 500 ms (± 50 ms), to achieve the theater lighting effect. When the door(s) are closed the door ajar switch(es) break(s) the ground to the LCM input which then gradually reduces the power from 12 volts to 0 volts within 5 seconds. (± .5 second).
When the headlamp switch is depressed it grounds an input to the LCM which in turn sends 12 volts to the front dome lamps, rear reading lamps, and instrument panel courtesy lamps. When the headlamp switch is depressed a second time, it breaks the ground to the LCM input which then ceases to send power to the front dome lamps, rear reading lamps, and instrument panel courtesy lamps.
The battery saver will disrupt power to the courtesy lamps after 10 minutes, the demand lamps after 30 minutes, and the headlamps after 10 minutes. Turning the ignition switch to the RUN or ACC position will terminate the battery saver feature by disabling the interrupt timers and reinstate power to the lamps.
Do you know what DTC'S are ? diagnostic trouble codes !
LCM Diagnostic Trouble Code (DTC) Index DTC Description Source Action B1322 Driver Door Ajar Circuit Short to Ground LCM Go To Pinpoint Test F . B1442 Door Handle Switch Circuit Failure LCM Go To Pinpoint Test G . B1445 Door Handle Switch Circuit Short to Ground LCM Go To Pinpoint Test G . B1563 Door Ajar Circuit Failure LCM Go To Pinpoint Test C . B1566 Door Ajar Circuit Short to Ground LCM Go To Pinpoint Test H . B1685 Lamp Dome Input Circuit Failure LCM Go To Pinpoint Test I . B1687 Lamp Dome Input Circuit Short to Battery LCM Go To Pinpoint Test I . - All Other DTCs LCM REFER to Section 419-10 .
PINPOINT TEST C: THE COURTESY LAMPS STAY ON CONTINUOUSLY CONDITIONS DETAILS/RESULTS/ACTIONS C1 CHECK THE SYSTEM OPERATION Open and close each door, making sure that each door is completely closed.
  • Are the courtesy lamps still illuminated after the 25 second time-out period?
Yes GO to C2 .
No The system is operating correctly. C2 TEST DOME LAMP SWITCH Depress the dome lamp switch.
  • Are the courtesy lamps still illuminated?
Yes DEPRESS the dome lamp switch a second time. GO to C3 .
No The system is operating correctly. C3 CHECK THE LIGHTING CONTROL MODULE
LCM C2145a
Yes REPAIR circuit 53 (BK/LB). REPEAT the self-test. CLEAR the DTCs.
No INSTALL a new LCM. REFER to Section 419-10 . REPEAT the self-test. CLEAR the DTCs.
Apr 16, 2017 | 2004 Ford Crown Victoria
Both front power windows stopped working
hope this helps. if u have any other questions just let me know
Fuse locations for options not shown can be found in the corresponding wiring diagrams.
Amp.
1 - Headlight, Low Beam, Left (56b) 10
2 - Headlight, Low Beam, Right (56b) 10
3 - License Plate Lights (5icon_cool.gif 10
4 - Rear Window Wiper And Washer System 15
5 - Windshield Wiper/Washer 15
6 - Fresh Air Blower, A/C (X) 20
7 - Tail Lights, Right (58R) 10
8 - Tail Lights, Left (58L) 10
9 - Rear Window Defogger 20
10 - Fog Lights 15
11 - Headlight, High Beam, Left (56a) 10
12 - Headlight, High Beam, Right (56a) 10
13 - Horn (15) 10
14 - Back-Up Lights 10
15 - Engine Electronics (15) 10
16 - Power Sunroof, Front Map/Reading Light 15
17 - Emergency Flashers (15) 10
18 - Fuel Pump (FP), Heated Oxygen Sensor (HO2S)
Control Module 20
19 - Coolant Fan, A/C Relay (30) 30
20 - Brake Lights (30) 10
21 - Interior Lights, Clock, Luggage Compartment
Light (30) 15
22 - Cigarette Lighter, Radio, Luggage Compartment
Release 10
Separate Fuses
(Located above the relays)
- Fuse for ABS hydraulic pump relay 30
- Fuse for ABS main relay 30
- Fuse for A/C 30
- Fuse for power windows 20
- Fuse for cruise control 5
- Fuse for cigarette lighter 15
May 20, 2009 | 1997 Volkswagen Jetta
Foxconn eBOT Barebone Logo
99 people viewed this question
Top Foxconn Computers & Internet Experts
Alun Cox
Rommel Balcita
David
David
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
