Question about Kenmore 75944 Gas Dryer
Gas dryer won't dry
Mod 110.75962401 Ser 3003909
burner lights for 6 seconds then gas stops.
    Problem Solver:
  • 10 Answers
Kbaker926:
This is a purchased product manufactured by another manufacturer for Sear.
It sounds as if have a flame sensor or a thermostat opening turning power off to the burner thus flame goes out.
If you are able to to catch the dryer just as it shuts off you would be able to do some ohms readings to find out what components have opened in the curcuit.
((((This is only if you are able to properly use and read a Volt-Ohm meter))))
These checks should only be done with the Electrical supply turned OFF and at least one wire disconnected from the component being tested
Woodychoppers
Posted on Nov 01, 2008
AMANA GAS DRYER, MOD.#LEA1OW/LGA10AW . CLOTHS WILL NOT DRY-IGNITER LIGHTS, BUT GO OUT BEFORE BURNER COMES ON.NO HEAT.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 14, 2011 | Amana Dryers
Hello my dryer doesnt work properly it runs
The valve resistance is 1995 ohms and the ignitor is 185.
Inspect the dryer venting from the rear of the dryer to the outside vent hood of the home.
If there's a restriction in the vent--the clothing in the dryer takes longer to dry.
When the dryer is functioning normally---the time required to dry laundry is determined by the *Sensor* located on the drum side of the lint filter housing and by the main control board.
When laundry is near dry--any Time Remaining on the control panel that is *not* needed will be eliminated---except for the last 6 minutes.
The final 6 minutes of any automatic cycle is for cooling down the laundry before the dryer ends the cycle.
If a dryer *counts down* to the last 6 minutes but the laundry is still not dry--the computer will allow the dryer to run until the laundry has dried or defaults (not drying within the additional time allowed).
Dryer vents that are longer than 8 feet with more than (2) 90 degree turns--can affect drying performance.
Setting the DRY LEVEL selector to *Very Dry* will solve most dryability issues. In homes with abnormally long vents--even the longer run time in the *Very Dry* setting is usually not sufficient to dry laundry loads.
Reducing the length of the vent or starting a second cycle becomes necessary to fully dry the clothing.
If a second cycle was started---only the amount of time that is needed to dry laundry will be used before dropping to 6 minutes and then the cycle will end with dry laundry.
LG gas dryers are more sensitive to venting length and air flow resistance. The gas burner can cause a rapid increase in temperature compared to an electric burner.
Rapid temperature rise in a gas dryer leads to premature burner shutdown (longer time required to dry laundry).
The gradual temperature increase of an electric element is more "forgiving" in homes where the dryer venting is less than ideal.
Problem:
The dryer has an auto dry feature which never fully dries the clothes so we wind up manually setting the dry time to an hour
Solution:
LG gas dryers are VERY temperamental in long vent set-ups. If fabric softener sheets are used in the dryer--clean the two stainless steel strips of metal on the lint filter housing with a SCOTCHBRITE PAD--scrub back & forth several times to remove the waxy residue from the fabric softener sheets. Most,if not all manufacturers do *not* recommend using sheets in dryers that have a moisture sensor (electrodes).
However--using a SCOTCHBRITE pad keeps the wax off those sensors which can be seen if looking *into* the dryer drum and at the lint filter housing.
If only *liquid* fabric softener is used in the washer--clean the dryer sensors once a month. Liquid softener also contains wax which can slowly accumulate on the dryer sensors from the laundry washed in the washer.
LG dryer manual
Dec 13, 2010 | LG D2526 Gas Dryer
Gas dryer burner does not light... no glow plug, no call for gas. Dried one load while I was gone second load put in, would not dry.
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jun 07, 2010 | Dryers
Have a Maytag Dependable Care dryer. Model MDG9606AWW. The glow bar comes on, gas lights and stays on about 30 seconds, go off for about 30-60 sec. then comes back on for about 10-18 seconds. Then goes off...
When an LG dryer is functioning normally---the time required to dry laundry is determined by the *Sensor* located on the drum side of the lint filter housing and by the main control board.
The final 6 minutes of any LG automatic cycle is for cooling down the laundry before the dryer ends the cycle.
Apr 01, 2010 | LG DLG5932W Gas Dryer
No heat during either drying cycle automatic
heatman101
Feb 15, 2010 | GE DVLR223 Dryers
MOD. MDG6200AWW SER.# 31658508YW WILL NOT DRY CLOTHES. TORE DRYER APART AND CLEANED. BURNER COMES ON FOR A FEW SECONDS THEN SHUTS OFF.
Hello, This problem is going to be your safety valve coils...basically they get old and over time of heating then cooling develop a short when they heat up...It may appear the gas lights to start but then goes out until the safety valve coils cool back down. Here is a picture of a set of coils Yours may differ but it's the same concept. You will find them mounted to the saftey valve at the rear of the igniter. 57d5263.jpg This should solve your problem. Hope this helps, Please feel free to comment again if you have any further questions or concerns. Good Luck! Mike
Aug 26, 2009 | Dryers
Frigidaire gas dryer, burner lights but gets shut off immediately
ckd coils on burner /valve they are probably breaking down..be sure you have good gas supply sounds almost like low or no gas pressure but believe you'll find coils bad
Jun 18, 2008 | Dryers
SLOW DRYING WITH MAYTAG DRYER
Have you checked to see if there is an obstruction in the gas valve itself or if the solenoid is worn? If there is, it will not allow as much gas through, therefor making a smaller flame and less heat. If not, check for pinched gas flex lines either before or after the gas valve or leaks in the combustion chamber. Also take out the lint trap, seal it up with cardboard cutout with a hole in it, take an air compressor with a blowout valve on it set at about 200psi, cover your face and blow out the trash out of the internal ventilation system on the dryer. Should work better after all this. Hope this helps.
Jan 28, 2008 | Dryers
Kenmore 75944 Gas Dryer Logo
136 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
