Question about Bush 1433GRN2 14" TV
NEED TO GET GREEN MENU ON
I WAS MESSING AROUND WITH THE REMOTE AND A GREEN MENU POPPED UP,IN THIS MENU YOU COULD CHANGE MANY THINGS LIKE SOUND 1 OR SOUND 2,PAL SECAM OR NTSC AND VARIOUS OTHER THINGS THIS NEW MENU IS NOTHING LIKE THE NORMAL ONE,THE NORMAL ONE IS BLUE,AND YOU CANT CHANGE AS MANY THINGS TO CUT A LONG STORY SHORT I CHANGED A FEW THINGS IN THE GREEN MENU,NOW I GET A CRACKLEING SOUND AND CANT WATCH THE TV NOMORE IVE TRIED GETTING THE GREEN MENU ON AGAIN BUT I CANT I THINK IT HAS SOMETHING TO DO WITH THE COLORED BUTTONS ON THE REMOTE,BUT IM NOT SURE. PLEASE HELP ITS DRIVEING ME MAD.
  • mz spanner Jan 08, 2009
    I AM TRYING TO HELP AN OLD CHAP WHOSE TV WHEN TURNED ON GOES TO FULL VOLUME . IT SEEMS THE 'PP' CONTROL IS ON.
    HOW DO I RETURN TO NORMAL MODE?
    President:
  • 3,130 Answers
You some how got into the service menu, and your going to need to call an authorized servicer for this brand, and they are going to have to tell you how to put the TV back to factory defaults, If thats not possible, the sets going to have to be re adjusted and go through every alighnment to see what you changed. If that ever happens again, cancel out of that menu, as its for the trained tech to change things, as theres a process that has to be followed.
Posted on Sep 16, 2006
Need to change input, no remote
There is no way to change the input to this set without its remote control.
Apr 12, 2012 | RCA Televison & Video
How do i adjust centering the the picture? can it be done with the remote?there are no external adjustments.
with tv off press and hold both CH- and Vol- at same time untill tv comes on you should now be in service menu.
Feb 15, 2010 | RCA 20F511T TV
YAMAHA AV receiver RX-V861 I have the message 'Vol-fix' appearing on Zone 2 and no sound. This was working fine until then
Setting the RX-V861 remote control to operate Zone 2:
  1. Using a ballpoint pen or similar object and press the [CODE SET] button RX-V861 remote control. The[TRANSMIT INDICATOR]on the remote should flash twice.
  2. Using the [NUMERICAL KEY PAD] on the remote and key in 9992, the [TRANSMIT INDICATOR] should flash.
Assigning the receivers internal amp for Zone 2:
  1. Set the remote control selector to [AMP]. (Located to the right of the volume buttons on the Remote.).
  2. Press the [SET MENU]button on the remote control.
  3. Arrow down to Manual Setup and press the Enter button on the remote control.
  4. Arrow to the [SOUND MENU] option and press the [ENTER] button on the remote control.
  5. Arrow to Speaker Set and press the [ENTER] button on the remote control.
  6. Arrow to the EXTRA SP ASSIGN and select ZONE2
  7. Press the [RETURN] button on the remote control to exit out and return to the Manual Setup.
NOTES: There is an option for setting the Maximum Volume and Initial Volume in the Zone Set menu.
  • Max Volume: This is an optional feature but isrecommended to prevent the accidental change in volume levels thatcould damage the speakers and receiver.
  • Initial Volume: This is also a great feature that would seamlessly start the volume level for the second or third zone at the desired level.
We do not recommend using any Speaker Selector boxes to enable more than the recommended number of speakers per terminal.
Controlling Zone 2 using the RX-V861 remote control:
  1. If the Main Zone on the receiver is on, press the [POWER BUTTON]down and while holding that button down press the [PHONO]/[**] button on the remote. The [TRANSMIT INDICATOR] will light up.
  2. You will not be able to use the following buttons on the remote: (Pressing any other button will cause the remote to exit Zone 2 mode. [POWER], [STANDBY], [VOLUME], [MUTE] and the [INPUT SELECTOR] buttons [DVD], [CD], etc.)
There are the instructions as written straight from yamaha. If you need any further assistance please let me know.
Thank you,
Lee
Dec 13, 2009 | Audio Players & Recorders
Im in Australia I have a haier HTR-039 tv. It went into some settings mode (not the menu settings) and wouldnt go back to normal After messing around with some settings I got it to go away im not sure what...
HELLO
It appears you have accessed the SERVICE MODE settings - they must not be messed around with under any circumstances except for a service technician.
Contact a service centre who may just be able to put things right. Do yourself a favour - don't access this menu again! (:-)
Sep 30, 2009 | Televison & Video
DVD wont display anything on the TV
Some of these devices reset completely when you disconnect them from the electricity. Try this, if not, go to the menu, and in "set up" select te option "default settings"
Nov 19, 2008 | Televison & Video
Zone 2 issues
FIX ZONE @ SOUND - STUCK ON "ZONE 2 - FIX" 1. Press "Amp" button (right side of remote - 1/3 way down) 2. Press "Menu" button (center of remote - 1/2 way down) 3. Press "TV VOL" button (green letters) until "Manual Setup" is displayed on receiver 4. Press "Enter" button (green letters) 5. Press "TV VOL" button (green letters) until "3 Option Menu" is displayed on receiver 6. Press "Enter" button (green letters) 7. Press "TV VOL" button (green letters) until "D Multi Zone" is displayed on receiver 8. Navigate from there
Aug 03, 2008 | Yamaha RX-V659 Receiver
No zone 2 sound coming from yamaha amp rx-v861
We had the same problem - I think it was reset when the power went off in a storm. Went to Yamaha website (http://www.yamaha.com/yec/faq/faqdetail.html?CNTID=206010&CTID=5009135) and found the following worked:
  1. Set the remote control [SIDE SELECTOR SWITCH] to [AMP]. (Located to the right of the volume buttons on the Remote).
  2. Press the [SET MENU] button on the remote control.
  3. Arrow down to Manual Setup and press the [ENTER] button on the remote control.
  4. Arrow to the Sound Menu option and press the [ENTER] button on the remote control.
Feb 16, 2008 | Yamaha RX-V661 Receiver
Zone 2 Vol Fix
Try this:
FIX ZONE @ SOUND - STUCK ON "ZONE 2 - FIX" 1. Press "Amp" button (right side of remote - 1/3 way down) 2. Press "Menu" button (center of remote - 1/2 way down) 3. Press "TV VOL" button (green letters) until "Manual Setup" is displayed on receiver 4. Press "Enter" button (green letters) 5. Press "TV VOL" button (green letters) until "3 Option Menu" is displayed on receiver 6. Press "Enter" button (green letters) 7. Press "TV VOL" button (green letters) until "D Multi Zone" is displayed on receiver 8. Navigate from there Hope it helps. It worked for us.
Jan 19, 2008 | Yamaha RX-V657 Receiver
Televison & Video Logo
150 people viewed this question
Top Bush Televison & Video Experts
Joseph Hoffmann
Are you a Bush Televison and Video Expert? Answer questions, earn points and help others
