Question about Dymo LabelWriter 400 Turbo Thermal Printer
Barcodes - removed from top of lable
How can I print labels without barcodes?
They are just for files
  • jbailey54 Nov 25, 2008
    HALF THE LABEL IS UNUSABLE BECAUSE OF THIS.
  • imendoza
    imendoza Apr 20, 2012
    Thank you. Problem solved
    Genius:
  • 1,605 Answers
Right click onthe barcode adn select none in the popup
if this help you solved you problem, please give me a FIXYA rating.
thanks
Posted on Dec 18, 2008
Datamax M 4208 Printer - Barcode is missing when we print the label and we also get 10 extra blank labels with it. Please help me with a solution
Sometimes it's simply the Internet Browser settings. Go to File, then Page Setup and change the margins to 0.1 and all footers and headers to Blank or Empty.
Feb 28, 2013 | Datamax M-4208 Thermal Label Printer
Can't get the Zebra S4m printer to align? How should I trouble shoot this? Sonya
I am assuming you mean misalignment of lable top or start of print moving on label.
check sensor for lable debris.
if OK then perform media calibration:
Enter menu and scroll to ADVANCED
press enter and use password 9999
scroll to MEDIA and RIBBON CALIBRATE
Remove a few labels and remove ribbon
Press right arrow to continue display CALIBRATING PLEASE WAIT.
When complete reload ribbon and labels press right arrow printer will feed approx 39"
printer should now print OK.
Aug 08, 2011 | Zebra S4M Thermal Label Printer
We use 2 column lables and when we print the barcode on the second side will not scan. there is missing lines in the barcode.
possible, need printhead replacement. Try to.
Turn printer off,
press pouse button,
turn printer on, still pressing pouse button for 10 seconds, and then relese the button. the printer will print the pouse test with barcode, check if coming with wihte lines across, if yes, change printhead.
Mar 03, 2011 | Zebra Z4Mplus Label Printer
Zebra 105SE printer will print text and images just fine, but will not print bar codes from any software including Bartender or TechnoRiverStudio. If i export the label as an image I can print it just...
Bartender is a pretty good label software package - strange that you're having problems with a barcode. Are you by any chance trying to print a 2D barcode such as Datamatrix ? If that's true, then the problem is that the datamatrix barcode is not a resident barcode in the firmware version of that printer which is an older model. There should be a choice in bartender, in the properties of the barcode field that allows you to send the barcode as an image or graphic. The barcode will then print.
If you're trying to print a linear barcode (C39 or C128 or UPC for example) and it they won't print with the steps you have taken, then something is definetly wrong. Another option would be to take your label format and print-to-file instead of print-to-printer. There should be an option on the print screen for this. By then opening the file, the ZPL (Zebra's programming language) can then be examined to see exactly what is being sent to the printer.
Hope this helps !
Apr 17, 2010 | Zebra 105Se Thermal Printer
Lables getting printed alternatively
This is due to :
Wrong size of label.
You must give a page size and the gap size
It is very important to give the correct height and ga dimensions
The detecting sensor chosen is not the right one
Nov 27, 2009 | Toshiba B-SA4TP Printer
Zebra S4M Lable Printer Not Scanning
You might want to check the barcode ratio, bar width, printer speed and printer darkness. I am assuming that you are creating the barcode in some sort of label design package, correct? You either need wider bars, or make sure you have enough quiet zone on both sides of the barcode, so shrinking it might be the solution as well.
Apr 12, 2009 | Zebra S4M Thermal Label Printer
I have sato cx400 printer, looking for VB6 code
Try this link:
http://www.filebuzz.com/files/Codabar_C/freeware-1.html
Have a look at the VB Barcode Integration Kit
Feb 04, 2009 | SATO CX400 Thermal Label Printer
Printing not centered
Check the width of the label format.
Normally this printer will center the printing automatically when it receives the instruction to change the coordinates
Sep 04, 2008 | Zebra LP 2844 Thermal Printer
Will not print on all four lables, and does not print in the same place each time.
for starters you need to calibrate your printer.
Note: If printing in Direct Thermal Mode, default the printer first (4 flashes).
1. Load the labels and ribbon (if used) and close the printer
2. Turn on the printer power.
3. Allow the printer to feed or error out.
4. Press and hold the feed button until the green status LED flashes once, then twice. Release the feed button.
6. The printer will set the media sensor for the label backing being used and then automatically feed until a label is positioned at the printhead.
7. A profile of the media sensor settings (similar to the example in Figure 1) will print. Upon completion, the printer will save the new settings in memory and the printer is ready for normal operation.
8. Press the feed button. One entire blank label will feed. If this does not happen, try defaulting (Hold the FEED button until it flashes 4 times)
Jun 23, 2008 | Zebra TLP 2844-Z Thermal Label Printer
Zebra S4M Thermal Lable Printer Not Printing Correctly.
Is the Media guide st corectly?
This link is for a datamax but all label printers are stuctured the same way.
check
http://www.posguys.com/download/88230401_a.pdf
Oct 26, 2007 | Zebra S4M Thermal Label Printer
Dymo LabelWriter 400 Turbo Thermal Printer Logo
1,326 people viewed this question
Top Dymo Office Equipment & Supplies Experts
Jax Planet
Jax Planet
jdthefixer
Are you a Dymo Office Equipment and Supply Expert? Answer questions, earn points and help others
