Question about Panasonic DVD-RV62EBS DVD Player
Panasonic fault codes
Please can some one help i have a panasonic dvd rv62 which when ever it is switched on comes up with a f498 code on the lcd display and nothing else mattie
SOURCE: Fault code F498 on panasonic
as far as i understand, it is caused by dry joints - poor workmanship. Try taking the top off and pressing down on right-hand side the green circuit board with the dvd in standby. Then switch on. If that works then what i did was to take all the screws out and jiggle it then put all screws back except the one to the left of the board, next to the brown board. seems to work now. Tip found on another forum, no credit to me
Posted on Jun 12, 2008
Benimur
  • 6966 Answers
SOURCE: DVD olayer displays fault code
Error code F498 refers to "failure to process digital communication" which refers to solder failure of connectors, PCBs, laser eye and other major component interaction. It is a fairly common Panasonic problem.
A logical course of action is to present it to an authorized Service Center for appropriate action.
Your alternate options are:
  • Try a reset. Unplug from the mains for 30 minutes, hoping that it is just a system's glitch;
  • open the unit and check for any cold solder, flexible cable connectors and other electrical joints;
  • seek the services of a qualified professional.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Aug 11, 2008
SOURCE: Panasonic SA-HT680 DVD Home Theater
You need to disasemble and clean up very well all the parts,because it´s out of time.
Posted on Oct 01, 2008
SOURCE: Panasonic DVD-RV32
dvd wil not function and screen display f498 i need help
Posted on Nov 25, 2008
fieldy14
  • 456 Answers
SOURCE: Panasonic DVD player RV62 H07 message - disc
You can try to clean the laser by opening the unit and wiping gently with a cue tip or cotton swab, but if you are getting a H07 errorit may be somethng more serious and require a replacementof the dvd drive.I hope this helps. Good luck.
Posted on Sep 03, 2010
Fault A2
Are you SURE it's a fault code, and not the selected AV input? (A1, A2 or A3?
Press the Input Select button on the remote to cycle between AV inputs and Freeview channels
Jun 22, 2014 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
Sep 03, 2010 | Panasonic DVD-RV62EBS DVD Player
Panasonic RV62 code
hi friend,
go to website
www.dvdcodes.net/prods/panasonic/pan60-69.php -
thank u for using fixya
regards,
sivaranjini
Aug 11, 2009 | Panasonic Televison & Video
Panasonic DMR-EX85 fault code U99
This is the solution from the on line owners manual for you product at www. panasonic.com. U99 ≥The unit fails to operate properly. Press [POWER í/I] on the main unit to switch the unit to
standby. Now press [POWER í/I] on the main unit again to turn the unit on. I hope this helps you with your problem.
Jan 30, 2009 | Panasonic DMR-EX85EB-S DVD Recorder/HDD...
DVD olayer displays fault code F498. How do I fix it?
Aug 11, 2008 | Panasonic Televison & Video
Fault code F498 on panasonic VCR/DVD player HV-VHD1. DVD draw will not open.
May 04, 2008 | Panasonic Televison & Video
PANASONIC DMR-ES30V KEEPS SWITCHING OFF
I had this code (f09) on my Panasonic DVD VHS recorder. After seeing that it meant overload I took the cover off to look for burnt out components. I found that an electrolytic capacitor had bulged (look up capacitor plague on wikipedia). I replaced the capacitor with one of a similar value from an old power supply and it worked fine.
Feb 16, 2008 | Panasonic DMR-ES30VS DVD Recorder/VCR
Panasonic DVD-RV32
Dec 01, 2007 | Panasonic DVD-RV32 DVD Player
Faut F489
This is for code f489 as well as f498 F498 means a problem with flash eprom IC; meaning that unit is unable to read the basic instructions from the eprom IC. Can be cuased by several; may simply be a "bad connection issue" at the eprom Ic or somwhere in the Bus line--defective Ic or corrupted information which may or may not be recovered with a "service recovery" disc.(not an end user procedure) First step; try resoldering Eprom ic being careful not to bridge pins. second would be to take the unit to a AUTHORIZED ONLY repair shop for a firmware or eeprom update. Good Luck
May 24, 2006 | Panasonic PV-D734S DVD Player/VCR
Panasonic DVD-RV62EBS DVD Player Logo
906 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
