Question about Philips 28PW6006 28" TV
TV goes to standby without touching it
I have a problem with the TV going to standby on its own. This gets worse later in the day so it may be an overheating problem. At its worst point the screen goes red before the set goes to standby. It can always be switched on again from the remote. Can anyone help with this problem
    President:
  • 3,130 Answers
Soounds like the typical cold or bad solder connections somewhere in this set on the printed circuit board. Not the ez fix for a consumer. Must know how to solder and test solid state electronics
Posted on Sep 16, 2006
Elonex tv keeps going on standby, take 10-15 times for it to work
It sounds that there is some short circuit with its SCL-SDA rail, at its main digital circuit board. It will be best to contact any service technician, as troubleshooting the main board is a skilled work.
Nov 25, 2013 | Televison & Video
Elonex tv keeps going onto standby, take about 10-15 goes to work.
Sounds like you may have some capacitors going bad. If it is a high end TV it may pay you to take it to a repair shop.
Nov 25, 2013 | Computers & Internet
Turns on stays on five minutes works great then goes on standby
These tv is famous for high voltage it dead or cold solders to it FBT.The flyback transformer,a big black block of plastic with a red wire with a cap hook to the CRT(tv tube).U know how to solders? Take the tv aparts resolders the FBT.Or tries press the power button on/off couples times,if u get a picture.Don't touch it let it on,for three or four hours.Let the heat from the electricity to Amp up the heat,might solved this problems,without resoldering.
Apr 21, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Tv keep going on standby when you turn it on
tv goes into standby all the time if a power supply is not fine, what happens is that a power supply produces two voltages, one small one powers a standby components and bigger voltage powers a line transformer which later produces more small voltages,
then later cancels the first small voltage.
chec your power supply semi conductors like, transistors, diodes and small value resistors, on your power supply. some power supply uses a IC to oscillate a ht. so check a supply at a w/shop.
Feb 07, 2009 | Goodmans 257NS 20" TV
Sony KF-60WE610 Screen and Sound On/Off
All symptoms in your TV shows that you need to replace its Lamp as it has been consumed its life hours and TV requires new lamp. Lamp can be obtained from Sony Website. Price is $200, Hope this info will help you to enjoy your Sony TV in coming days.
Aug 17, 2008 | Sony Grand WEGA KF60WE610 60" Rear...
Every time i turn on my RCA tv the picture go's verical i hear and see the picture but it goes so fast verticly it used to go verically but then go to normal now it stays that way i found to switches in...
Hi there
Try replacing the electrolytic capacitors in the power supply section. I started with replacing (2) 860uf 180v caps just after the bridge rectifier and continued along the circuit. Some (15) or so capacitors later,it finally cleared the the horizontal bars and lines and the high pitched noise. It also fixed another intermediate problem of no video, when turning on the power.
Here is a picture of what they look like:
Thank you for using FixYa. Have a nice day and please remember to rate this solution as FixYa if it helps you.
Thanks
Dustin Ellse (BearWeb)
Jun 30, 2008 | Televison & Video
Flashing screen
The power compensator IC is bad along with most likley the main board. This is going to be an expensive repair. If the warranty expired in January, and you were in touch with them about then and they did nothing, you should try to fight with them. They may send out a repair person to get your set working again. Another possibility would be, if you have homew owners insurance and a tech can say that the problem was due to a power surge, the insurance will take care of part of the repair bill. Good Luck
Mar 23, 2007 | Samsung TXR3079 TV
Philips 28PW6006 28" TV Logo
229 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
