Home | DVD Players | Toshiba m400 dvd doe...
DVD Players
Problem for DVD Players
Generic problem for all DVD Players
Toshiba m400 dvd does not
By clint005 on Oct 31, 2008
toshiba m400 dvd does not work. It just makes clicking and attempted access type noises. Does not seem to spin.
Comments:
Oct 31, 2008
- How do I clean the post on a dvd drive? It looks ok but mechanism does not slide easily.
Best Solution
posted on Oct 31, 2008
Very Helpful)
IrishDruid
Rank: Guru
Rating: 88%, 1776 votes
There is a problim with the optical drive/reading mechanism. You need to get it repaired or purchase a new one (works out almost the same, if not cheaper)
Rating Locked! (?) clint005 has rated this solution as Very Helpful
Solution #2
Not Rated)
ginko
Rank: Guru  Televisions & Videos  Expert
Rating: 89%, 4933 votes
Check if there is a disk stuck inside, if the problem is that it does not start and there is a cd inside, then remove the disk.
To remove a disk stuck, press repeatedly the eject button while you start up the unit . Do this a couple of times.
If instead the unt make a clicking noise each time you insert a disk, like it is attempting to read but it does not read:
If it does this always with same disk, then it is just a defective or dirty disk.
If it does this with all disks then it is a lens problem: the Cd starts spinning, the lens does not read the start of the track, and the motor keep clicking.
Clean the lens using a cleaning kit, the ones with cleaning solution.
Here you get cleaning kits.
If this does not work you will need to take apart the unit and clean the lens directly accessing the lens pickup, using soft cotton and isopropyl alcohol.
If
Solution #3
Not Rated)
Bappa170873
Rank: Wiz  Televisions & Videos  Expert
Rating: 80%, 178 votes
This is a mechanical problem. As an expert I would advise you to get it opened by some professional technican and let them check for the problem or elase the entire mechanism may get damaged. You can contact Bestbuy for this.
Thanks
Solution #4
Somewhat Helpful)
coolguy008
Rating: 83%, 565 votes
see if the player tries to read the disc. Load a disc and listen.
Does the player make squealing noises or is it totally quiet? Squealing noises may indicate that the player is trying to synchronize with the disc but can't due to an obstruction on the lens or in the laser path inside the pickup or a defect in the pickup. This can also be caused by an intermittent signal problem due to a faulty ribbon cable.
Totally silent means that the photo sensor is not getting any usable input from the laser at all, meaning that the pickup is "blind" for lack of a better word.
This can be caused by an obstruction of the beam by foreign matter on the lens or inside the pickup all the way to a marginal or failed laser diode and/or photosensor array. This can also be caused by a bad ribbon cable with one or more severed traces.
You could try to clean the optics. This is the most common malfunction as far as i know in all disc players. It would involve taking the cover off and finding a way to expose the lense, and then cleaning it with a very gentle brush. some players have a cover for the lense that swings to the side during playing, this greatly reduces the chance of dust accumulating, but its still worth the try.
If you actually see dust on the lense, then its just that simple. clean, close, play.
It may also be worth your while to check on the small shafting that guides the carriage of the laser pickup. Dirt, grome, dust and solidified lubricant can cause stoppage of the carriage and the laser eye then fails to read the next track. Please refer to the image i have attached.
Comments:
Oct 31, 2008
If you still face the problem then you will have to get it repaired.
Popular Solutions for DVD Players
Questions and Unsolved Problems for DVD Players
Answer
Curtis DVD Player with HDMI Port, DVD1098B
Answer
what dvd recorder provides best resolution. I willuse it to record ultrasound studies. thanks
Answer
the charger got crushed and cannot charge, can i buy a new charger or is there a certain charger... (More)
Answer
Hooking up DVD Recorder with Cable TV (Local Channels) and Direct TV that has a DVR Receiver?
Answer
Where Can I get a new battery replacement for my Protron PDV-288 portable DVD player
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For DVD Players:
Top DVD Player Experts
Rank: Guru Guru
Solutions: 1493
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more DVD Player Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
