Question about Baumatic BTWM4 Front Load Washer
Stains on clothes
Hello, we have found stains on cloths that wern't there before they went in the machine. We have cleaned all the pipes in the machine, run the machine empty with washing powder only and still get marks, large and small grey stains that will not come off even with 'vanish'. Whilst cleaning the pipes and trying to see the reason for these stains we noticed the same build up of , what we can only describe as gunge in the pipes, on the outsine of the drum. We can't get to it to clean it. Any ideas?
  • Anonymous Mar 20, 2014
    Despite having cleaned the filter thouroughly and having run the cleaning cycle I get little black bits sticking to the clothes. Machine model is WA13V5
Have you tried Calgon to get rid of limescale deposits? Also have you used any laundry bleach at any point, because it stays in the machine for ages and clothes come out with faded patches and bleach marks for weeks afterwards.
Posted on May 14, 2007
How to remove grease stain from laundered shirt
How to Remove Grease Stains ' Stain Removal
www.howtocleanstuff.net > ... > Clothing & Fabrics > Stain Removal
Begin by blotting with a clean cloth to remove as much of the grease as possible. ... If your clothing is durable, spray oven cleaner on the stain and let it set for ...
Oct 07, 2015 | Washing Machines
White clothes come out stained
AT LEAST YEARLY YOU HAVE TO CLEAN WASHER ORTHER VICE STAINED COMING NORMALLY.. YOU HAVE TO CLEAN WITH OXSY CLEANE LIKE BORAX,CLOREX,,
Jan 20, 2014 | Miele Washing Machines
My washing machine stains my clothes with a brownish-black grease-looking smear stains! Awful. I've taken the center tub agitator out, looked inside for grease but there's nothing there. What's going...
You will need to check in the first place the water inlet that connects the washer as if the pipes are rusted then it will be bringing to the washer some stains along with the rust . So allow the water to be collected and checked outside and then connected to the washer and checked.
next check on the sides of the tub /drum for any rusted parts or foreign objects that are lodged into the drum.
Finally make sure that the tub is clean, the vents and all the sections connected are brushed off with light vinegar and detergent.
Feb 05, 2011 | Kenmore Washing Machines
Why does my washing comes out with stains on it.... they weren't there when it went into the wash...
yes sometimes ink pens can be washed when we are not aware it was in someones pocket. I use straight ammonia and a cloth to clean my washing machine drum a couple times a year because these things have happened to me before. The ammonia will cut the grime and pen stains out of the drum. Then take a squirt bottle and fill it with white vinegar and squirt all around inside the drum of the machine. Run a wash without any clothes with the hottest water to clean the drum and clear out the stains. Do this to the dryer also and clean out the filters. Take the dispensers out from the washing machine and clean those too and your cleaning is done for a while. Apparently the ink has been in the drum of your washing machine and putting the color into your clothes. You can bleach out the white clothes that turned blue. Use the stain remover for colored clothes. Hope this will help you.
Feb 01, 2011 | Whirlpool Washing Machines
Why is my washer leaving black stains on my clothes
It sounds like it might be leaving mold deposits. Try running a cycle with no clothes in it, hot, with a cup of bleach. If the stains are more brown than black, though, that would be rust in the pipes.
Oct 16, 2010 | Kenmore 44102 Front Load Washer
Random brown stains in random loads of laundry
Hi from Australia
Ok the problem with your washing machine is that there is grease and oil stuck in the machine and the oil will dribble out when you run the machine on a different cycle if you rince with cold water then the oil stays in there and the hot water lets a little bit out as it is stuck in the pipes of your machine ok the first thing is run an empty load on full hot water even the rince cycle with 1 cup of bleach nothing else let that go through the long cycle then do the same again with 1 cup of white vinger and 1/2 cup citric acid which you should be able to get over there or baking soda try that it will clean your machine and your pipes it is great way to keep it all clean by the time you have done this you should not have any brown stains
Have a great weekend
Jan 22, 2010 | Kenmore HE2 Plus Front Load Washer
I find that the seats do not clean very well ..is there a secret to cleaning this "material" without leaving water spots or stains
if they are cloth cleaning them is very tough, i usually get a profecional to do it but if its not so bad you can rent out a carpet cleaning machine from your local supermarket or hardware store, it works quite well on car seats and carpet
Jun 14, 2009 | 2005 Chevrolet Equinox
Stains
Apparently the residue is fatty buildup from fabric softener. Try filling it up with the warmest water possible and add some bicarb to dissolve it, then rinse a few times to get it out of the machine completely. Then use vinegar instead of softener for most washes, or dilute fabric softener with water 1:4 and occasionally rinse with bicarb. This works for me.
Oct 20, 2008 | LG WFT1071TP Top Load Washer
Moldy smell
A solution/suggestion from the internet:
Make a boil wash (with no clothes and detergents) put into the powder drawer a cup of bicarbonate of soda.
It should clean the machine and move out the bad smell.
Another:
I have a front loading machine also and am not willing to have to constantly clean out the machine; the soap and fabric softeners you use are building up between the inner and outer drums (and on the drum itself sometimes). Because the machines door is so tightly sealed (to prevent water leakage) the smell from this buildup is awful. I finally found the solution.
MAGGIE'S SOAP NUTS -- they are all natural (grow on trees) and will remove the grime from your drum and also clean your clothes (you won't even need fabric softener anymore). Stop using commercial detergents and fabric softeners and start using Maggie's Soap Nuts.
They are not very cheap but they work great --
I have found that making a liquid out of the soap nuts and storing it in a bottle works better than putting them in the sack cloth they come with (because front loaders do not agitate constantly like regular machines, the cloth bag sits on the clothes and sometimes leaves a stain -- the liquid will not leave a stain.
YOU WILL SOLVE YOUR PROBLEM AND HAVE SOFTER CLOTHES TO BOOT (without fabric softener so you save some money there). They are also better for septic tanks, the environment and your health!
I believe Whole Foods sells them and they are also on the internet at www.Maggiessoapnuts.com
Note: Also go to www.newstarget.com -- they are going to buy these in bulk to cut the cost in half but don't have them yet. You should be able to buy them there soon. Run some of this thru your machine with hot water before washing your clothing to clean out the buildup that is already in the machine.
May 30, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Baumatic BTWM4 Front Load Washer Logo
389 people viewed this question
Top Baumatic Washing Machines Experts
Marvin
Marvin
NOEL
NOEL
TriciaGirl
Level 1 Expert
Are you a Baumatic Washing Machine Expert? Answer questions, earn points and help others
