Question about Thomson Televison & Video
I bought a thomson VS680U VIDEO SENDER BUT THE WIREING DIAGRAM IS A BIT VAGUE NOT SURE WHAT TO PLUG INTO ON MY SATALITE BOX ? AND DO I NEED ALL THE LEADS ? I ALREADY HAVE A DVD AND A VIDEO ALL CONNECTED I HAVE WIRES EVERY WHERE PLEASE HELP!
5 Suggested Answers
SOURCE: I need help to rewire
I eventually stopped panicking and then tried out as many different ways of connecting up the tv with video and digi box possible and eventually one of them worked.
So as Peggy Lee say's I'm a WOMAN..W..O..M..A..N !
Posted on Apr 19, 2008
  • 1027 Answers
SOURCE: Spark plug wire diagram
Visit a car dealer with same make, look under hood and sketch the wire layout, and copy in yours.
Posted on Jul 04, 2008
  • 1596 Answers
SOURCE: need wireing diagram for 2002 dodge grand caravan
------>>>FRONT>>>>of Van >>>>
______________________________
#5 cyl #6 cyl
#3 cyl #4 cyl
#1 cyl #2 cyl
_________________
I COIL BLOCK I
I I
I #3 #1 #5 I
I I
I I Firing Order Is
I I 1 2 3 4 5 6
I #6 #4 #2 I
I _______________I_
the Wires Go Accordingly to prospective Terminals, So Sorry Unable to Send Pics through FixYa, A Formating Problem Exists
and they show on my end but not on your end this is TRUE and CORRECT To The BOOK other than the Lines from Coil to Spark Plug ENDS at CYLINDERS. Please dont Forget to RATE Me
Thank You And Happy Motoring!!
Posted on Mar 27, 2009
JShreader
  • 50 Answers
SOURCE: NEED WIRING DIAGRAM FOR 2002 PT CRUSIER STARTER
Hello chk614, my name is JShreader. Thank you for choosing fixya.com.
Here is a picture showing the Wires connecting to the Starter...
If you are looking for the formal Wiring Diagram...see below...
I hope this helps you. If you have any more questions or need any more diagrams, please don't hesitate to ask...Thanks again, JShreader!
Posted on Apr 01, 2009
  • 10865 Answers
SOURCE: I'm replacing a non-hydronic electric baseboard
Hello. The red and the black are the hot wires. Therefore, connect one of your conductors to the red and the other conductor to the black. Use wirenuts. The bare ground wire should be solidly attached to the new unit's green wire using a wire nut.
Regards, Joe
PS: please rate my answer. Thank you.
Posted on Jan 06, 2010
Testimonial: "Excellent Reponse"
I have a thomson ths220 box and I am having difficulty recording a tv programme.
See if you can what the format is on the USB key that the video is in. It needs to be MPG, MPEG, TS, VOB, MP4 or AVI. If no it may be because, in THOMSON's own words:
"THOMSON cannot guarantee the playback of video files although extensions are listed here, as the correct playback depends on codec used, data bit rate and resolution as well. Please consult the THOMSON Hotline in your country to get more details."
May 30, 2014 | Audio Players & Recorders
Stereo wireing diagram needed
If you are putting in a after market sterio,you need to go to autozone or walmart and get a sterio plug that plugs into your factory plug and the wiring diagram will be with your new plug that you bought,real easy!!
Apr 10, 2014 | 1990 Geo Prizm
Wiring instrucutions diagram
were does yellow wire connect to on wireing harnnes on a mitsubishi 3000gt what color do i connect it to on the harnness reds posative weres the yellow wire go to
May 13, 2012 | Car Audio & Video
IVE BOUGHT A LOGIK AV SENDER AN THE PROB IS AFTER SETTING IT UP THROUGH MY SKY DIGITAL BOX TO MY TV UPSTAIRS I CAN ONLY HEAR THE SOUND AN CANT SEE THE PICTURE ALSO THEIR IS A WHITE, YELLOW AN RED LEAD AN...
ok these are called phono leads, yellow = video, red = left sound, white = right sound.
you need one of these http://www.maplin.co.uk/Module.aspx?ModuleNo=13372 there are 2 types, inputs and outputs, this one does both, (you need an output. sky to sender) let me know if this looks right for u
Jun 07, 2009 | Televison & Video
I dont know how to wire it to my car stereo wires
Do yourself a favor and run to audio store or even autoparts store & get an adapter plug/harness, cost is a few bucks but well worth it. It plugs into factory harness & you wire your new stereo to it according to diagram with new system.
May 02, 2009 | 2001 Dodge Stratus
Connection
hi, you can now buy a box that can take upto 5 hdmi inputs to plug into your tv, i'm sure your local game shop will supplie them, if not search on ebay. hope this helps
Feb 09, 2008 | Sony Playstation 3 (PS3) Console
NEED A WIRING DIAGRAM FOR A A200 HOBART MIXER
I had a look on google and came up with a service manual. not sure if this has the wiring diagram but the only other thing i can suggest is to contact te manufacturer direct. Go to http://cgi.ebay.com/HOBART-A200-20-QUART-MIXER-SERVICE-PARTS-MANUAL_W0QQitemZ160203114233QQcmdZViewItem
hope this helps.
Feb 02, 2008 | Hobart A200 Stand Mixer
WIRELESS LINK FOR SKY+ BOX
your sky box should have 2 scarts ;input and tv.I have one so as can watch sky upstairs and on projector screen.
reciever sender is in av on tv upstairs sender downstairs is in scart next to tv scart on skybox scart lead in tv scart connected to av on tv.some senders need to be turned on.when you plug in adapter and led is on doesnt necessarily mean sender is on .is this a new sender with instructions youve bought
Jan 01, 2008 | Acer TravelMate 2300 Notebook
Televison & Video Logo
Top Thomson Televison & Video Experts
 Grubhead
Grubhead
Are you a Thomson Televison and Video Expert? Answer questions, earn points and help others
