Question about ViewSonic VP191b 19" LCD Monitor
Monitor Blanking I have a ViewSonic VP171b that goes black at random times (anywhere from 10 minutes to 3 hours of being turned on). The power light for the monitor stays on (green), but the screen goes completely black. There is no warning (doesn't flicker, or get bright, or anything like that). I have to turn it off and leave it off for some time (usually between 1 and 5 minutes) and then it works fine again for a while (again random length of time). It does it not matter what program I am running. I have updated and re-installed the monitor and graphics card drivers. I have opened up the case and 'fanned' it and it didn't appear to help (not overheating of the graphincs card, cooling system in case working properly). Wiggling the connectoins doens't seem to make a differnce either. The monitor has worked fine for about a year before this happend. It was plugged into 220v 50hz (within the monitor's rating) for about 3 months before the problem started to occur. It is now plugged into a transformer (120V). Any ideas? My guess is the backlight, but I'm not certain. Is an LCD monitor easy to fix by yourself?
  • 2 more comments
  • Josh Garrett Sep 16, 2006
    Update: I paid a bit more attention to the latest occurance of the problem and the monitor did get slightly brighter before blanking out. Also, it has a barely audible high pitched sound just before going out (like the sound of a TV that is on, with no volume in a quiet room). Also, if I try to turn it on too soon(before the 1-5 minute 'cool-down' time), it will take 1-2 seconds to turn on, flash for a heart-beat, and then go blank again. When it does this, it also has that barely audible high-pitched sound.
    One last point, it is being used in an air conditioned room, so no overheating problems from the environment. I also have my cheap sub-woofer about 8" behind the monitor on the desk.
  • Anonymous Nov 13, 2007
    I have a Westinghouse that does the exact same thing, this is an external monitor for my laptop, will shut down from 10mins-3 hours as mentioned above, Still found no soloution.
    I know this is for a VS, but it may help my problem aswell.
  • Anonymous May 04, 2008
    I same issue for me, VP171B
    any idea of how to solve this ???
  • ahpeeyem Jun 04, 2008
    my VP171b does this as well, it sucks!
    It will work for a random amount of time (as you say, it can be hours or minutes) and then gets brighter for a few seconds, then goes black and the LED on the front panel stays on.
    After you turn the monitor off for a few minutes it's fine again for a random amount of time, usually not as long though.
Buy a new monitor... It will make your eyes stop watering.
Posted on Dec 09, 2008
SOURCE:
Viewsonic monitor vx2035wm goes black with a steady blue light on power button when the monitor is turned off or computer is restarted. Disconnecting it and letting it sit for a minimum of 24 hours makes...
I've been having the same problems with my Viewsonic.I plug it in and the blue light blinks but there's no picture it's just a black screen.I do know if Viewsonic doesn't repair my monitor I'll never buy anything from them again.I have the LCD Viewsonic 22' Vx2235wm monitor.
Does anyone have any idea what could be wrong with mine?I've bought a new video cable & video card but the monitor still does the same thing?Thanks
Oct 29, 2010 | ViewSonic VX2035WM LCD Monitor
Viewsonic has trouble turning on-- seems to backlight (screen lights, makes an electronic hum), and then go to dead (yet the green power indicator stays on).
Hi, well if this is the inverter board, then its probably more cost effective to buy a new screen, same thing if this is the cathode lights. Reason for that is the technician will charge to replace, so cost will get anywhere from 50 and up. Only one question, how many years old is it? I do believe Viewsonic has 3 year warranties.
Nov 01, 2009 | ViewSonic VP171B (Black) 17 in. Flat Panel...
LG 52SX4D turns off randomly.
My Lg 52"tv turn off and on
Apr 29, 2009 | Televison & Video
VX922 monitor, blank screen, blinking power light
If there is a flashing led on front of the monitor, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the Monitor goes on protection there are only two possible causes.
1 The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or a broken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the monitor will reset just unplugging power cord for one or two hours, sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occurr suddenly are a blown capacitor on power board, the inverter board powering up backlight lamp has blown, or a fault on main lcd controller board.
check also the video cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
Check connectors, try moving the video cable, and if the cable is not built in, then also try a replacement cable.
If under warranty contact Viewsonic to find out a Viewsonic service point.
See:ViewSonic - Support & Service
If you want to repair at your own expenses, just locate any good qualified repairer.
Regards
Mar 03, 2009 | ViewSonic VX922 19" Monitor Flat Panel
Samsung 204B random blank screen
I too have a dual monitor Samsung SyncMaster 204 setup. My monitors started flickering, then a week later had turn on problems like your describe. I found a fix on this fixya website and followed the fairly techie suggestion. It worked. I wrote up a .pdf set of instructions so others might also benefit. Hope this helps. Doug
Feb 07, 2009 | Samsung SyncMaster 204B 20.1" LCD Monitor
Viewsonic vp930b-3
MY VP930b has the same problem.
It takes a very long time (5-10 minutes) before it becomes normal.
Aug 04, 2008 | ViewSonic VP920b 19" LCD Monitor
Monitor Randomly Turns Black
I have exactly the same problem with my Benq FP71E+ ..
What i found is a temp fix is this :
When monitor dims and goes black i turn it off , hit the bottom left side (near the BENQ logo) turn it on again and it works ..
This works every time for me . But after a while it switches off again , could be 5 minutes could be 5 hours . Its random
May 02, 2008 | BenQ FP71E 17" LCD Monitor
Problem with 17" ViewSonic Monitor
The same problem w/ my viewsonic E70 17" monitor.The viewmeter or viewmatch color on screen do not appear when power ON, although the green led power is ON.
But if you rest your monitor for about 10 hrs or more the viewmeter will appear when you power ON the monitor.
You can now start your CPU.
Remember : No viewmeter screen on monitor when power ON, means no supply coming out the picture tube or high voltage.
But if there is Viewmeter on screen , this normal and OK>
Feb 04, 2008 | ViewSonic VA720 17" LCD Flat Panel Monitor
ViewSonic VP191b 19" LCD Monitor Logo
335 people viewed this question
Top ViewSonic Computers & Internet Experts
Steve Allison
Steve Allison
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
