Question about Sony Cyber-Shot DSC-P32 Digital Camera
Will not start when power button is pressed - Sony Cyber-Shot DSC-P32 Digital Camera
  • Anonymous Dec 25, 2008
    It will power up in set-up mode and allow proper set-ups and you can view pictures in memory but when I try to power up normally all I get is a black screen.
  • 40 Answers
I have a Breadman TR875 breadmaker. It will not do anything when I hit start. I've tried to unplug it, but didn't help.
I believe for this perticular model to power-up, you must press the Select button first to select a mode, then press the Start button.
Here's more on the subject...
Addressing Power-up/Start-up Issues:
1. Unplug the breadmaker.
2. Confirm the power source your accessing is live using a blender, toaster, etc.
3. Plug the breadmaker in.
4. Confirm the breadmaker is receiving power:
    1. Some models have a built-in off/on switch. Turn it to the ON position.
    2. Some models make an audible tone when plugged in.
    3. Some models have a colored light and/or a lighted display screen that lights up.
    4. Some models require you press the Select button down until the unit powers up.
    5. Some models require you press the Start button down until the unit powers up.
    6. Some models require you press the Select button first to select a mode, then press the Start button.
3. No, you were not able to confirm that your breadmaker is receiving power? Sorry to hear that. Attempt to have the breadmaker serviced by a small appliance repair facility or discard it.
4. Yes, you have confirmed that your breadmaker is receiving power? Fantastic! Now reset the breadmaker by pressing down on the Start button until you notice a visible and/or audible confirmation, usually within 5 to 10 seconds. Note: It bears mentioning again at this point that some models require you press the Select button first to select a mode, then press the Start button.
Jun 20, 2011 | Breadman Kitchen Appliances - Others
Sharp AR-M205 Calling for Maintenance. How do yuo reset?
1. unplug the printers power cable it resets ALL printers
2. Once you have it unplug the power cable back in and turn it on make sure it's plugged into the computer.
3. you may need to uninstall and reinstall any software and drivers that came with the printer
4. download and install all the critical updates and service packs for your operating system
5. download and install any updates for your printer from the shap printer driver site
Az.
Sep 17, 2008 | Sharp Office Equipment & Supplies
My b2300 bread maker wont start on the 15 min delay after i push the start button .......why? i hate this machine and wont recommend one to anyone.......love my old sunbeam machine which just broke down...
2. Confirm the power source you're accessing is live using a blender, toaster, etc.
4. Yes, you have confirmed that your breadmaker is receiving power? Fantastic! Now reboot the breadmaker's electronics by pressing down continuously on the Start button until you notice a visible and/or audible confirmation, usually within 5 to 10 seconds. Beware: Some models require you press the Select button first to select a mode, then press and hold the Start button to reboot the system.
That should fix it. Hope this helps!
Special Note: Often the + and - Timer Delay buttons are pressed by mistake, delaying Start by up to 12 hours. If you suspect the Timer Delay feature has been engaged accidentally, you'll need to reboot the breadmaker's electronics. You can do this by pressing down on the Start button continuously until you notice a visible and/or audible confirmation, usually within 5 to 10 seconds. Beware: Some models require you press the Select button first to select a mode, then press and hold the Start button to reboot the system.
Jun 19, 2011 | Black & Decker B2300 Bread Machine
It has stopped-no current at all. Plugs seem to be OK.
3. No, you were not able to confirm that your breadmaker is receiving power? Sorry to hear that. Attempt to have the breadmaker serviced by a small appliance repair facility or simply discard it.
Jun 16, 2011 | Breadman Kitchen Appliances - Others
I have an Oster Bread Machine model 5839. The display and timer work but nothing else does.
All breadmaker use a belt and pulley system. If your breadmaker powers-up but the mixer won't turn when it's supposed to, your belt is probably broken. You
Jun 15, 2011 | Oster Kitchen Appliances - Others
How to resolve "P07" message
Solution 1: If the device is not functioning properly or to clear memory, reset it.
1. On the operator panel, press the button. (The display will go blank.)
Note: It may be necessary to unplug the power cord if pressing the ON button does not shut off the printer.
2. Wait approximately ten seconds and then press the button again.
3. Wait until the device has completed its cycling process before submitting another job request.
Note: It may be necessary to unplug the power cord and retry if the above steps do not clear the error.
Solution 2:
Step 1: Entering Service Mode
* While the printer is OFF, press and hold the Start/Stop button (Resume/Cancel in some other models).
* While holding the Start/Stop button, press and hold the POWER button.
* When the POWER LED (green light) lit, release the Start/Stop button (still holding the POWER button).
* Press the Start/Stop button TWICE (still holding the POWER button)
* Release the POWER button.
* Wait for the LCD to display "0′ (zero).
Jun 10, 2011 | Office Equipment & Supplies
I have a Wrist Blood Pressure monitor MF 81 that I would like to set the Date and time on it - I don't have a manual
Start with the unit turned off. Now hold the Power button on until it starts to blink zero (0) on the display. Wait until the display shows two zeros. Press and hold the Memory button until a two-digit number starts flashing at the bottom; this is the year setting. Press the Power button repeatedly until the year is correct. Now press the Memory button, and the month will start flashing at the top of the display. Press the Power button repeatedly until the month is correct, then press the Memory button. The day is now flashing. Set it with the Power button, then push Memory. The hour is now flashing, set it with the Power button (note that it is in 24-hour format, so 1 p.m. displays as 13). Press the Memory button to advance to the minutes, then use the Power button to set it. Finally, press the Memory button to turn the unit off. It is now ready for use.
Sep 04, 2010 | Mark Of Fitness MF 81 Wrist Blood Pressure...
Waste ink tank full, what do I do?
1) With the printer power turned off, while pressing the Resume/Cancel button, press and hold the Power button. (DO NOT release the buttons. The LED lights in
green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (DO NOT release the Power button.)
3) While holding the Power button, press the Resume/Cancel button 2 times, and then release both the Power and Resume/Cancel buttons. (Each time the
Resume/Cancel button is pressed, the LED lights alternately in orange and green, starting with orange.)
4) When the LED lights in green, press the Resume/Cancel button 4 times (Each time
the Resume/Cancel button is pressed, the LED lights alternately in orange and green, starting with orange.)
5) After the function (menu) is selected, press the Power button. The LED lights in green, and the selected function is performed. (When the operation completes,
the printer returns to the menu selection mode automatically.)
Aug 02, 2009 | Canon PIXMA iP5000 InkJet Photo Printer
Canon ip 4200
(DO NOT release the buttons. The Power LED lights in green to indicate that a function is selectable.)
Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the Alarm and Power LEDs light
alternately, Alarm in orange and Power in green, starting with Alarm LED.)
4) When the Power LED lights in green, press the Resume/Cancel button 4 times, the green (power) led should be lit to reset ink absorbers.
(Each time the Resume/Cancel button is pressed, the Alarm and Power LEDs light alternately, Alarm in orange and Power in green, starting with Alarm LED.)
5)At the end of the service mode, press the Power button
Jan 10, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
Canon ip4200 waste absorber is full
Jan 10, 2009 | Office Equipment & Supplies
Sony Cyber-Shot DSC-P32 Digital Camera Logo
59 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
