Question about Sony STR-DE345 Receiver
SONY STR-DE345 This amp has some weak spots on the mainboard as it keeps losing signal. Sounds like the blue relays or switches keep shorting or losing contact at the back of the board near the speaker terminals. Problem is: it is very difficult to get under the mainboard to resolder. Why did Sony not make the board accessible from underneath? It looks like hours of work to be able to get the board out when all they would have had to do was make a bottom removebale panel. I don't think it is worth the time. I call this unserviceable and not user friendly to say the least. It almost makes the unit disposable. Any thoughts? Thank you. Tom
  • nilest Oct 31, 2008
    Dan. Thank you very much. You are right on top of this stuff. Very quick detailed response. I appreciate it. I will give that a shot. Have you had some with problems in the same area? I am assuming those blue things toward the back by the speaker terminals are relays or switches?
    Tom
  • 4,234 Answers
Having repaired many of this model and other similar models, I can get at teh board relatively quickly. That being said, it is a poor design for repairs. It is, however, cheap and quick for manufacturing. Take your time and remove all of the board screws, the screws that hold down the heatsink and the rear cabinet screws. The whole board should be able to lift from the back with a little patience. Be careful not to tear any of the ribbon connectors. With the unit on its side, you should have access to resolder any questionable joints.
Dan
Posted on Oct 31, 2008
  • ABRsvcs Oct 31, 2008
    They should be relays I believe. Over the years I have repaired 1000s of units. I can't remember all of them, but you see patterns.
    Dan
My unit powers up and then goes to protect, why?
This usually means there is a short in the amp section. It needs to be looked at by a pro.
Nov 20, 2012 | Sony STR-DE345 Receiver
My sony STR-DE345 amp says "protect" and there is
The manual says it thinks there is a short circuit on the amplifier output side. If it still says Protect after disconnncting all the speakers wires there is an internal problem. Take it to a hands-on tech.
If the problem disappears, you had a short. Attach speakers one at a time to isolate the cause.
http://www.retrevo.com/support/Sony-STR-DE345-Receivers-manual/id/387bh943/t/2/
Dec 24, 2010 | Sony STR-DE345 Receiver
Is there an internal battery on the STR-DE345 Sony receiver for the pre-sets? Can it be replaced if there is. Receiver no longer holds pre-sets when there is a power outage.
There is no battery to replace to hold preset channels. The preset channels are held by a charged capacitor to maintain the nominal voltage level to the PLL (phase lock loop) tuner. The capacitor can only hold the charge for a few hours, and then it will slowly discharge - for like a short power outage.
Fuse keeps poping, what other type of fuse can i buy for this, my model is STR-DE435 (sony)
If it keeps blowing the rated fuse you really need to take it in to a shop for further analysis. Using an incorrect, higher value fuse will only raise the risk of fire or more damage to whatever is blown in the unit.
Dec 08, 2010 | Sony STR-DE345 Receiver
Sony str-de345 this keeps on making a
the clicking is a power suplie overload some output amp is with problems and shutdown after overheat, when you tap is bad connection inside, normaly is related with sound off after 15min. needs to be checked by tech. to ensure perfect operation.
Jan 30, 2010 | Sony STR-DE345 Receiver
Sony receiver STR-DE345 OVERHEATED how do i fix it ??????
these do run hot, they don't have a fan so they need good ventalation. If your has completely failed you may be able to resolder the voltage str and stk voltage driver Ic's or replace them.
Jul 16, 2009 | Sony STR-DE345 Receiver
I need a schematic or service manual for Sony STR-DE345.
hi,
i can download it for you..
visit this site for manuals of your unit it will help you answer all your questions.
http://www.free-service-manuals.com/Detailed/15736.html
thanks,
you rate in our answers are much appreciated..
Feb 19, 2009 | Sony STR-DE345 Receiver
PROTECT FLASHING
The protect circuit is doing it's job....probably the amplifier
output stage is shorted.....have a technician check it..make
sure any / all bad connects are soldered when chassis is out
for service......................T.
Jan 04, 2008 | Sony STR-DE345 Receiver
Sony STR-DE345 Receiver Logo
226 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
