Question about Hoover F7431-900 SteamVac Vacuum
Permanant water flow
I have a Hoover F7431-900 with a problem. It continues to put out solution in forward and backward mode no matter what setting it is on. Even when it is on and locked in the upright position, the solution sprays out. It has great suction though. Can I fix this problem myself? If so, how?
  • tume Dec 01, 2007
    unpluged, switch off, refill the water tank with water and solution tank with the hoover solution ultra, attached the tank and it starts to pour out without doing nothing to it. How do i stop the water flow? Is it internal problem that i have to open it up and try to fix it? I need this to work!
    President:
  • 1,673 Answers
To check the water lines you have to take the top housing off, you may have a water line that came loose. It it is leaking from just under the water tank, there may be a line unhooked there. Check the seal that the tank sits on, it may have to replaced, the other is the diaphram that the tank sits on isn't closing alowing the water to keep flowing.
Posted on Jan 10, 2008
Hoover Wind Tunnel U6485-900 will not push forward but suction works?
sounds like something has got caught in the wheels/roller. Turn unit off, flip it upside down so you can see the bottom of the device and see if you can move wheels forward and backward...if you see something caught on the wheels, try and unroll it in the opposite direction. If the roller is jammed up, you may need to take the 4 screws holding the roller plate and then untangle/clean the roller and re-assemble.
Oct 09, 2018 | Hoover Vacuums
Hoover Savvy Brush only runs when the vacuum is moved backwards
That is brobably a bad wiring, that lose contact when you move the hoover forward. The wirings should be checked, here is some schematic:
Wiring Schematic :
Oct 22, 2008 | Hoover U8185-900 Upright Vacuum
Why does m hoover **** all rubbish back out
Filter or bag full? Or blockage to bag.
Mar 08, 2015 | Hoover Vacuums
We have a Hoover Steamvac F7452 that is leaking water from the bottom of the machine. If we place the water tank on the machine, water immediately starts flowing through to bottom of the machine. It'
When you put the tank on it connects with the unit and opens the valve on the bottom of the tank to allow the water to flow check for debris hair etc around the connection, it is possible the seal itself is worn or bad and needs replacement but I think the trigger only lets air in the tank so the water will flow out by gravity, I'm not positive on this but mine works that way.
Oct 19, 2014 | Hoover F7452-900 SteamVac Upright Vacuum
Hoover brush and wash instruction manual
Hi there! To prepare for cleaning, put the solution and water in the top tank. While cleaning, all the dirty water gets sucked into the bottom tank. To clean squeeze trigger to release cleaning solution and slowly push carpet cleaner forward, this equals one wet stroke. Continue to squeeze trigger and slowly pull carpet cleaner back toward you (second wet stroke). Release trigger and slowly push carpet cleaner forward over area just sprayed with solution (dry stroke). Then slowly pull carpet cleaner back toward you without squeezing trigger (dry stroke). To avoid saturating the carpet don't do more than 4 wet strokes over one area. Always end with dry strokes. Here is a link to view the instruction manual if needed.
http://hoover.com/file/604/
Hope this was helpful!
Jun 19, 2014 | Hoover SteamVac Carpet/Upholstery Deep...
Dirty water leaking? from cleaner.
1) you must test where is leak, for replace any hose or clamp tight , or repair some parts with Cool solder.buy it from any auto parts for fix it.
God bless you
Jul 03, 2012 | Hoover Floormax F5300 Upright Vacuum
What setting do I need to have the machine on to **** up the excess water? I want to download the manual but can't seem to find a link to do so, how would I do that?
You should have the vacuum set to Wash/Rinse for all steps in cleaning. Press the trigger to release the cleaning solution and push the vacuum forward. With the trigger still pressed, bring the vacuum back towards you). Then release the trigger and again move the vacuum forward and then back. Repeat the "dry" strokes until the dirty water enters the dirty water tank. Watch the water going through the dirty water tank lid. Empty the dirty water tank if the suction fails or the tone changes. Do more dry strokes after cleaning the entire surface until you do not see more water entering the dirty water tank.
The manual is available from Hoover at the product site: http://hoover.com/products/details/f7411900/max-extract-dual-v-widepath-carpet-cleaner/ . The direct link is here: http://hoover.com/file/592/ .
I hope this helps.
Aug 08, 2011 | Hoover SteamVac F7411-900 Upright Vacuum
Hoover steam vac dual v carpet cleaner has stopped dispensing soap. Water is still flowing fine
You probably have a solenoid valve which has failed and will not open. This will require replacement of the valve. For temporary use you can mix a soap solution and put it in the rinse tank. The correct mix is 5 ounces of Hoover shampoo to a gallon of hot water.
May 17, 2011 | Hoover Steam Vac Dual V w/ SpinScrub...
Lost instructions
The Hoover web site has all the owner's manuals posted for download, just go to this site and put the model number in, the next page will have a link to a pdf copy of the manual!
http://www.hoover.com/CustomerService/Manuals/Default.aspx
Nov 10, 2008 | Hoover F5886-900 Steam Vacuum
Hoover Elite motor runs when moving backwards but not forward
Are you sure its not just your belt on the beater of head slipping and needs to be replaced?
Oct 18, 2008 | Hoover Elite Rewind Bagless Upright...
Vacuums Logo
91 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Kirk Thompson
Level 1 Expert
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
