Question about Canon PowerShot S1 IS Digital Camera
No picture When looking at the monitor and the view finder all I have is some purple lines across the screen. The camera will flash and make a blank photo. I have recharged the batteries to ensure they are good.
  • paul1958 Nov 08, 2008
    I am having same problem- purple grainy pics when dowload-same thing seen through viewfinder and display.
    Problem Solver:
  • 4 Answers
Your problem is undoubtedly the CCD image sensor. Under normal circumstances it would be cheaper to throw away the camera & buy a new one, but...
As of Oct. 6, 2005, Canon issued a Service Notice pertaining to several different models, including the S1 IS. Here is an excerpt:
" It has been confirmed that the connecting parts of the internal wiring of the CCD used in affected products may become disconnected, especially if the affected products are stored or used in high-temperature and high-humidity environments. If this occurs, the signal is not output from the CCD normally in Shooting Mode, which may cause a distorted image or the absence of an image. This malfunction can be confirmed on the LCD monitor screen during shooting. The same malfunction also appears on the recorded image."
"Canon's Response: Effective immediately, and regardless of warranty status, Canon will repair, free of charge, the products listed above exhibiting the above-mentioned malfunction if Canon determines that the malfunction is caused by the CCD image sensor. Canon will also cover the cost of shipping and handling in connection with this repair."
Follow this link to the Canon website with all the info you need to send it back for free:
Service Notice: CCD Image Sensor Advisory
You should get the camera back within 10 days. Mine only took 6 days! Good Luck!
Posted on Nov 12, 2008
Screen and photos are purple-M575
If you view this pics in the oc, the same thing? If your answer is YES, its possible that you have a problem whit the CCD (Charge Coupled Device); this wrong include distorted images or abnormal colors, scratchy purple lines, blank or black pictures, and/or black videos with good sound being recorded on the camera's flash card.
Additional details could find in this previous solutions: images are_colored_when_picture
Isnt a good new but, hope this helps.
Jun 28, 2011 | Kodak EasyShare M575 Digital Camera
The problem i m having with my camcorder is when i want to record film screen goes blank but i can watch my previous recorded videos
Look in the view finder when recording instead of the screen. if you see the image there then the unit is probably set to look through there. Many of the new units dont' have a full view finder to lens item they actually have a small lcd screen inside the view finder. Check your options for recording.
Also if the view finder is tilted you need to close that before usign the lcd.
The image will not appear simultaneously on the LCD
monitor and the viewfinder. It will appear in the
viewfinder when the LCD monitor is in the lock position,
and it will appear on the LCD monitor when fully
extended.
Mar 02, 2011 | JVC GR-DVL820U Mini DV Digital Camcorder
View screen on back of camera blank,ie dark. No picture follows despite looking thru manual view-finder.
Hi there:
CCD problem would explain the black or lines on your pictures and the lines on the LCD (since the CCD is used to feed the live image). CCD (Charge Coupled Device) is one of the two main types of image sensors used in digital cameras.
Some symptoms of a defective CCD include distorted images or abnormal colors, scratchy purple lines, blank or black pictures, and/or black videos with good sound being recorded on the camera's flash card.
When a picture is taken, the CCD is struck by light coming through the camera's lens. Each of the thousands or millions of tiny pixels that make up the CCD convert this light into electrons. The number of electrons, usually described as the pixel's accumulated charge, is measured, then converted to a digital value. This last step occurs outside the CCD, in a camera component called an analog-to-digital converter.
In order to correct this issue, the repair facility needs to replace the CCD. This is not something you may do on your own; check this article for additional details: Bad CCDs. This, isn't a good new, but hope helps to solve it.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day
Nov 12, 2010 | Canon PowerShot A70 Digital Camera
View finder screen has horizontal lines, almost looks like static. Picture is black across the bottom with purple horizontal lines across the top. Help!
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free worldwide, and may also include free shipping both ways (free shipping varies with countries). This is regardless of your camera's warranty status. Please check this link for more info.
Applicable cameras include: A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/V3/300/400/430/500/II/IIs, IXY Digital 200a/300a/320/400/450/500/30/30a
Feb 08, 2010 | Canon PowerShot S1 IS Digital Camera
When looking through the view finder can only see flashing purple
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check this link for more info.
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 30/30a/200a/300a/D320/400/ 450/500
Dec 22, 2009 | Canon PowerShot S1 IS Digital Camera
I had Fuji S5000 for about 3 years. It worked fine. Now all sudden, I can't see any image when trying to take a picture. Both image through view finder and on LCD are just blank. Someone told me that a...
Hi
I have got an S5000 that I can still view previously taken pictures from the card, but when trying to take pictures the screen and view finder shows a peculiar distorted purple and green picture and any picture taken is just a green blur.
I contacted Fuji and they say they can repair it for £90 (about $120)
Nov 02, 2009 | Fuji FinePix S5000 Digital Camera
View screen has purple lines across whole screen cant take a pic.
It is bad ccd issue in Canon A95 camera and ccd imager needs to be replaced.
Canon will repair A95 free of cost as per announced scheme.
Click Canon CCD Advisory for details.
Good luck.
Dec 21, 2008 | Canon PowerShot A95 Digital Camera
Fuji s 20 pro
prior to this current problem did the pictures have a hazy contrast to them? if so then yes the apeture is faulty. if the cost of the camera does not exceed the the repairs then you should purchase a new one. this is the best option because i'm sure if you send it straight to fuji it will cost more than 350 bucks guarenteed. however you might save alot by just taking it to a local shop and have them repair it and you most certainly get it back alot quicker as well.........please rate this thanks
Sep 04, 2008 | Fuji FinePix S20 Pro Digital Camera
Fuji s 20 pro
CCD module failed, contact fuji, they got product recall for some camera models with faulty CCD
Mar 06, 2008 | Fuji FinePix S20 Pro Digital Camera
Z740 Digital Camera Dark Pictures w/ lines
My CAMERA is AN MD853 i hAvE tHiS SAME PR0BLEM i didNt dR0P MiNES EitHEr..d0ES S0ME0NE kN0w wHAt'S g0iN 0N?
Aug 30, 2007 | Kodak EasyShare Z740 Digital Camera
Canon PowerShot S1 IS Digital Camera Logo
108 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
