Question about Sony Grand WEGA KF60XBR800 60" Rear Projection Television
Red ghosting Slight red ghost on right side of images
  • 2 more comments
  • realjay2 Nov 13, 2008
    My KF60XBR800 also show a right shift in the red that shows as a slight red ghost
  • Anonymous Nov 23, 2008
    I have the same problem. Ghosting or convergence issue with my KF60XBR800. What can I do to fix this?
  • patrick3 Jan 02, 2009
    Patrick,Belgium,
    My set is about 6 yearrs old, i do have the same problem, could it be dust in de optical block ,or converg. adjustment ?
    ps: It's my third lamp in 6 years ????, manuf by PHILIPS, and sold for
    600€ .
  • gio Feb 06, 2009
    I seem to have the same problem. Slight Red line across the right side of the screen causing a ghosting issue. Additionally, tried using teh settings on the television to correct teh porblem, was not able to correct it using the different settings.
  • 320 Answers
There is a bulletin that addresses this problem, but you must follow it EXACTLY as it invoolves changing settings in the service menu and you could easily make your TV unusable if you change the wrong thing. if you want the bulletin i could send it, but I would recommend you have a Sony qualified tech do the adjustment
Posted on Nov 15, 2008
I have a Sony TV model KDL-40BX412. There is a red ghost. Sometimes it is green. The longer the TV is on, the distance between the image and the ghost decreases, but never disappears.
Contact the authorized service centre for Sony. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Nov 17, 2014 | Sony Televison & Video
WD 73835 has ghosting images during dark or red scenes
Make sure your contrast isn't set too high. Most ghosting is caused by either contrast, brightness or tint issues. Try adjusting these settings. Also check if there is a Dynamic contrast setting for your TV as well as this can cause ghosting also.
Apr 06, 2014 | Mitsubishi Diamond 835 Wd-73835 73" 1080p...
Ghost-image on VPL PX31
There is dust in RGB Panel,that ghost image is actual dust.It need to clean.
Mar 16, 2010 | Sony VPL PX31 Multimedia Projector
Slight ghosting and color alignment problems
comvergencia that reviews the misaligned with the remote control and traps
Jan 05, 2010 | Televison & Video
Shadowing
GOOD DAY ND GOOD LUCK;
TRY THIS, IT WILL CORRECT CONCERN:
50V500 ONLY
GHOST: May be described as "Out of Convergence" but ghost is still attached to main image.
CONDITION:
A "ghost image" appearing to the left or right of images in the picture. Can be varying shades of a primary color (red, green, or blue) as well as gray. Can easily be seen in the 4 x 3 mode, at the edges of the picture.
CORRECTION:
To correct the problem, please do as follows:
  1. Access I2C Menu. (See page 57 of the Service Manual).
  1. To enter the I2C Service Menu, with power off, (on the front control panel) press and hold the INPUT button. Then press the POWER button for two seconds. The following Service Menu will appear.
03b_ghost_image01.gif Figure 1
  1. BEFORE CONTINUING: CONFIRM THAT THE R, G and B DRIVE ARE SET AT 40.
  • Be sure to press SELECT after each change to SAVE the new Data.
  1. Using the Remote Control joy stick, scroll down to next page (see Figure 2) until LCD ADJUST is highlighted.
03b_ghost_image02.gif Figure 2
  1. Move the joy stick to the right to cursor right once. The next page will appear with the word GHOST highlighted.
  2. Cursor right again, and a white screen will appear with a BLACK SQUARE in the center, as in Figure 3. You will see LCD ADJUST, followed by “SHP” and a number (value).
Figure 3
  1. If the unit is out of adjustment, you will see a gray ghost on either side of the black square. Move the joystick to the right or to the left until the ghost disappears. The number values will change up or down.
    • If the ghost adjustment is off with a lower value, there will be a ghost to the left of the square.
    • If the ghost adjustment is off with a higher value, there will be a ghost to the right of the square.
  2. Once you get the square to look good without ghosts, press "SELECT" to save any data values that have been changed.
  3. Press the "EXIT" button three times to return to normal picture.
  4. Adjustment is completed
  5. I HOPE THIS WAS HELPFUL, big IRISH.
Jul 26, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Tri coloured ghosting
maybe...it might need service mode aligning be a tech
Jan 02, 2008 | Televison & Video
Red-striped ghost images.
when you leave your TV (no matter what kind) and you leave it for long periods of time on a static image or something.. the image tends to burn in to the screen... so changing the glass would be a way to fix it.... the problem is that that kind of repairmen is more expensive and difficult than buying a new set...
Dec 24, 2007 | Sony Grand WEGA KF50XBR800 50" Rear...
Ghosting
Get firmware upgraded.
Oct 30, 2007 | NEC VT465 Multimedia Projector
Sony Grand WEGA KF60XBR800 60" Rear Projection Television Logo
155 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
