Question about Insignia 3-Way Indoor/Outdoor Speakers (Pair)
Confused need help!!!
I bout these speakers as is. i didnt know it just had wires n thats it. im tryna hook the speakers up to my m-audio fast track usb audio interface. but the speakers do not come with a plug to plug them in. help me please.
  • Anonymous Jan 17, 2009
    the watt of the stereo is 40 watts per channel handling. and its a 90hz-20khz frequency respons.
I need the watt of da stero DC-Z92
Posted on Oct 31, 2008
How to hook up 18"
Hello!
SO I am going to give you more of a signal layout from the turntables (or whatever you use to DJ) to the speakers.
Turn tables-> Mixer-> Eq-> Amp-> Sub and other speakers.
The part that I am not understanding is why do you need the QSC amp if you have a powered sub? The powered part of that means that there is a built in amp, which eliminates the need for the QSC amp unless you are sending that sound to main (non sub) speakers.
Hope that helps!
May 03, 2011 | Audio Players & Recorders
Im tryna hook up my pansonic sa-pt 480 surround sound to my 42 inch plasma panasonic flatscreen and the cable but the sound not coming out the speakers
I couldn't find any info on sa-pt480 only scpt480. However, setup should be straighforwardly the same.
Generally you have to direct the sound in setup. The manual is here http://www.mito-oem.com/media/pdf/SCPT480.pdf Follow the instructions for setup
Mar 13, 2011 | Audio Players & Recorders
I'm hooking up my sony player to a nissan versa and the colors are confusing and I'm tryna get it to work , and it wont
Car Colors (Assuming NON-Rockford factory system)
4-6 speaker system.
Accessory 12 Volt L.GN
Constant 12 Volt BN
Chassis Ground BODY
Power Antenna
Remote
Illumination OG
Dimmer (-) Bk
Left Front Spkr + WT
Left Front Spkr - BN (PK @ Spkr)
Right Front Spkr + GN
Right Front Spkr - L.BU (RD @ Spkr)
Left Rear Spkr + VT (L.GN @ Spkr)
Left Rear Spkr - RD (GY @ Spkr)
Right Rear Spkr + L.GN
Right Rear Spkr - GY
CLICK HERE for generic wiring tips for your radio.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 19, 2010 | Sony XPLOD CDX-GT200 CD Player
When i hook up my m audio to my sound system, i get a steady unpleasant sount
It could be a couple of things. First the ground on the inside came loose and needs to be reattached. Second if it is an older model some have the capacity to take records. Records have a special prosseser that is diffrent than a digital input. It is very sensitive. That mght be stuck on. I think that it is the ground. Let me know. My name is Tony and I am very good with Computers, Remotes and real good with stereo and TV hook ups with wires fro your surrond sound systems. Im just not that good at spelling lol. My email is tvegas88@aol.com Like I said if you need help with any of that just ask you don't have to go through the web sight. You can write me direct. Take care and good luck. Tony D.<br />
Aug 26, 2010 | M-Audio Fast Track Pro External Sound...
I plugged my speakers in to the sound card and it
Hello!
You must try 2 options.
Try uninstall sound card drivers, reset comp., and again install sound driver.
In second case you must try new system, with full format hard drive, because you can have trouble with virus, and that is only safe way.
You can also try another sound card, but I think that is you sound card OK.
Nov 02, 2009 | HP (400745-001) Sound Card
Sony Model: STR-DG800
You've got a short in one of your speaker wires either at the receiver (most common) or at the speaker itself. you should only have a 1/2" of each side of the speaker wire stripped to put on each terminal, and when you strip them, twist them so there are no frays in the strands that will touch the other terminal. The receiver is protecting itself from harm. Turn it off then disconnect all speaker wires, examine each wire carefully before reinstalling, then turn the receiver back on. If it still says protection, look at each speaker and reconnect your wires the same way. If you still have a problem, disconnect the wires again at the receiver and turn on, at this point, if it say's protection, it needs to be serviced. Hope this helps
Jun 23, 2009 | Sony STR-DG800 Receiver
Music not playing from subs
Do this for the sub amp...
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
Jul 03, 2008 | Kenwood KAC-9152D Car Audio Amplifier
I have the cd player hooked up to the but I added rear speakers which didnt come with the car.
stomp_pete- do you need the speaker wires for the harness or vehicle,the rear speakers on your harness are as follows.
green- left rear -positive
green w/black stripe-left rear -negative
purple-right rear-positive
purple w/black stripe-right rear-negative
I hope this helps, let me know if you need more help.
cooltek Mar,12/08
Mar 12, 2008 | Pioneer DEH-2700 CD Player
Insignia 3-Way Indoor/Outdoor Speakers (Pair) Logo
120 people viewed this question
Top Insignia Audio Players & Recorders Experts
Alan Matzke
Alan Matzke
Curt Larson
Level 1 Expert
Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
