Question about Hampton Bay 24002 Ceiling Fan
Every winter water drips from my bathroom ceiling mounted extractor fan, worse when there is bad condensation. The vent goes straight up and up through the loft space and out of the roof, there appears to be a cover to this vent. This morning the extractor fan blew up, blowing the fuses upstairs. Just wonder what my options are, seal off roof, put elbow or something in vent ? Just replacing fan is not going to work. Thank you.
    Genius:
  • 1,605 Answers
Condensation is created by 2 exteme temperature change.
looks like the loft space is colder than the rest of the house.
first make sure there is not blockage in the vent. then warp the vent with fiberglass as much as you can. it doesn't matter what R value the fiberglass is. just enough to cut the temperture change.
you still going to need a exhust fan in the bathroom.
Posted on Oct 31, 2008
Wet ceiling from my bath exhaust fan, how to stop?
Probably due to 1 0f 2 things...
1- Not enough power in the exhaust fan to take out all the mist /steam from the shower.. or
2- Condensation build up due to too much steam at one time.
(especially if fan is NOT ventilated properly)
If you have access to the fan, see if the label states the CFM 's it can remove. May not be enough for the size bathroom you have.
Both of these can be solved by installing a larger capacity fan system. Make sure to vent it to the outside of the home too, since venting to a cold attic area (in winter) can cause even more condensation to drip down.
Feb 17, 2017 | Home
Fix a dripping ceiling fan in bathroom
I suppose the answer depends on where the water is coming from: bathroom steam, leaking water pipe, or from outside the house.
Jan 06, 2015 | Computers & Internet
Nutone bath fan how do you clean the vent
Usually the vent cover pulls straight down, and is held in place with 2 V-shaped metal spring wires.
Squeeze each spring wire together to release cover from ceiling box.
Use vacuum to clean vent fan housing. Some vent fans can be disassembled and motor housing removed for cleaning. Do NOT use water on electric motor. Simple vacuum, or dry toothbrush cleaning is good enough.
Spay tiny bit of WD40 on the fan motor shaft or add tiny dab of white grease if desired.
The plastic cover can be scrubbed with soap and water, rinse to remove soap residue, and when dry, paint with aerosol spray paint using 3-5 very light coats applied in 5 minute intervals.
Jul 28, 2012 | Broan-NuTone Fan,Bathroom Exhaust Broan...
My bathroom fan will not turn itself off, it is connected to the bathroom light, light is turned off but fan goes continuiously??????
Then it is not connected to the light switch as you think. This could be a dangerous situation, and you should have an experienced electrician look at it.
Mar 02, 2010 | HP Extractor Fan Kit 110V Rack Mount Fan
Some water condensations around bath fan
THATS GONNA HAPPEN WITH THE HUMIDITY IN THE BATHROOM AND THE TEMP DIFFERENCE. TRY INSULATING THE DUCT WORK FOR THE VENT. INSTALL A FLAPPER SIMILAR TO WHAT A CLOTHES DRYER HAS. U DON'T WANT COLD AIR COMING IN. INSTALL A DEHUMIDIFIER.
Dec 12, 2009 | Home
My Bathroom Extractor Fan does not work properly and for some reason the bathroom smells of cigarette smoke when the upstairs neighbours are at home!! Our landlord say's this is not possible!!!
Yes, very possible!. The bathroom fan is connected together, and the upstairs one is down-drafting to you. Have the exhaust checked for blockage, or buy a fan that has a built-in damper that closes the exit when not in use.
Oct 21, 2009 | HP Extractor Fan Kit 110V Rack Mount Fan
Bathroom extractor fan won't switch off
The fan most likely is turned on by the bathroom light switch. You likely have a defective fan motor.
May 01, 2017 | Hampton Bay 24002 Ceiling Fan
My extractor fan is leaking a lot of water, it is nothing to do with the weather as it happens when it is not raining. The extractor fan was working but now has stopped
sounds like
the extractor is mounted in a cold space, and the moist air is condensing on the cold fan as it exits,
the fan housing may need better insulation, and the flap valve in the exhaust pipe needs to be checked to ensure it is closing, and keeping cold air out
it is possible that condensate in the fan has fried the motor
something to check
Nov 05, 2008 | Heating & Cooling
Moisture on bathroom exhause vent
the fan is pulling too many cfm (cubic feet per minute).you can replace the switch of the fan with a potentiometer type switch (this works like a light dimmer)you can reduce the speed of the fan,or you can use a couple of synthetic fiber filters to trap the condensation.good luck
Jan 04, 2008 | Fantech Fans Exhaust Fan In-Line
Hampton Bay 24002 Ceiling Fan Logo
268 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Donald Klecher
Donald Klecher
Level 1 Expert
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
