Lost picture, unit will turn on and turn itself off a second later, no picture.
Most likely needs a new lamp.
Posted on Nov 09, 2008
HOW DO I FIX AN INSIGNIA LED TV?
The main board controls the on/off functions. You can get parts here:
Mar 11, 2016 | Insignia Televison & Video
Picture lost sound still ok 42" LG
Since it is coming back after a union-like break, it is probably the inverter for the fluorescent backlight rather than the light itself; they can flicker and die but normally don't recover after a rest. The inverter may be a separate board in the unit and you should be able to recognize the right board due to its relationship to the backlight.
This kind of problem will not repair itself but decay further with time.
Sep 04, 2009 | LG 42LC2D 42 in. LCD HDTV
TV Powers off
tap on the power supply borad not to hard
and have some one let you know if pix fark out
go all thur all the board soune like you have bad solder jonts
Aug 12, 2009 | Televison & Video
Picture shuts off
It seems as though the bulb(s) in your unit are about to go out. This is repairable/replaceable by calling your manufacturer. If you are still under warranty they can help you by possibly troubleshooting/replacement/referrals.
Aug 06, 2009 | HP Md5880n 58 in. HDTV
Picture and sound first turn on before disappearing over and over again.
Symptom shows its weak Lamp problem in TV and you need to replace lamp. Replacement procedure is easy and written in instruction manual of TV.
Always buy Sony Original Lamp from Sony Accessories for longer life of TV.
Apr 25, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
A95 PowerShot turns on and off until batteries die.
Sounds like you have a stuck power button or shorted power switch. To repair you'll need to remove the top cover. Please see the following disassembly guide. It's in Estonian, but you can follow the pictures.
Continue to page 2, paying particular attention to the second and third picture. It looks like the power switch is connected to the camera through a simple ribbon cable. I'd suggest removing the ribbon cable end from its connector, cleaning any obvious crud, and then reseating the ribbon cable end into its connector. Ribbon cables are notorius for suddenly shorting or getting a bad connection at the connector. Usually just jiggling the cable can fix it too :-) Good luck!
http://qman.fotokala.ee/Kaamerad/PowerShotA95/index.html
By the way, were you the person that left a similar comment on my blog? http://camerarepair.blogspot.com/2007/12/fuji-digital-cameras-showing-black.html
Jan 31, 2008 | Canon PowerShot A95 Digital Camera
Tv powers on and off
Sound
Sounds like your bulb is nearing the end of its life span you will be needing a new bulb soon.
Jan 14, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
GPS GARMIN 340 turn it off by itself.
Does the unit comes on by itself once power is applied to the unit? If it doesn't come on by itself, then there is a problem with your power supply. The unit is designed to detect when an external power supply is applied and turn itself on. It is also designed design to detect if you unplug the unit from the external power supply. It will say "Lost external power, shutting down in 30 seconds". BTW are using Garmin cables?
Dec 25, 2007 | Garmin StreetPilot C330 GPS Receiver
Pentax Optio SV tunrs off immediately
I have the same problem with my camera and the following activities solved it. Remove batteries and clean contacts of battery's host (include cover). Check as well that contacts are not bended and didn't lost their springiness. Good luck !
Aug 06, 2007 | Pentax Optio SV Digital Camera
Open Questions:
Televison & Video Logo
52 people viewed this question
Top Televison & Video Experts
Electro Med Services...
