Question about Technics Audio Players & Recorders
ST CH770 Sir I have Technics ST Ch770 home theatre system. It often indicates F61.The out put line is not short. It works for few minutes again it shows the same. I do not have the circuit diagram. Please help me. Your early action will be highly appreciated. Thanks Samad exotictissue@yahoo.com
appman67
  • 33 Answers
SOURCE: panasonic home theater sa-ht920
Although the Panasonic Home Theater systems are great when they work properly. If your machine displays the "f61" error message, it's likely to be little more than a paper weight for the average person. The inner workings of the machine are rather complex to disassemble for diagnostics. And can take several hours to check all the components. The best advice I can give you is to sell the machine on e-bay as a broken item. If you offer shipping you can get more money for a complete system (speakers & all).
Posted on Sep 21, 2008
SOURCE: resetting the progressive scan mode on an LG lh-d2645 home theatre system
the above is correct but you need to have the dvd player on with no disc in so "no disk" is shown on the front display. then hold down the stop button for 5 secs to reset the display mode back.
Posted on Jan 02, 2009
poging
  • 14 Answers
SOURCE: Panasonic home theatre model SA HT640 with error
check fan on the power modele ic it might not be rotating
Posted on Mar 06, 2009
SOURCE: SC-BT 100 Error Code f61
Had the same problem. Found that the code refers to the cooling fan. Could be that the fan is dusty or not running when the system starts up. I removed the fan with the two screws and reseated the plug. Make certain that the short, black wire (that seems to go to nothing) is securing the plug to the board.
Posted on Apr 14, 2009
  • 336 Answers
SOURCE: stereo system technics sc-dv150 showing fault f61 how do i
f61 is a bad voltage code. I will probably need an output ic or a voltage ic.
Posted on Oct 16, 2009
Technics RS-CH770
It could be a belt that is not working right. But it could also be a fault on the drive itself. Check the plastic parts for damage.
Oct 01, 2017 | Technics Audio Players & Recorders
F61 ALARM IN PANASONIC HOME THEATRE
Audio amplifier Ic's damaged need to be replaced
Jul 24, 2010 | Panasonic Home Theater System System
Stereo system technics sc-dv150 showing fault f61 how do i
Oct 15, 2009 | Audio Players & Recorders
Won't turn on
Unplug all the input wires and then plug in just the power cable and see if it stays on then one by one add the wires bac until it does it again when it does the wire you just added may have a short in it check the line for touching wires. Let Me Know If this works for ya.
Apr 06, 2009 | Audio Players & Recorders
Panasonic SA-HT 955 Home Theatre System
The F61 is the shorthand for protect mode. This indicates a problem with the output amplifier section. I don't have a listing for your specific model, but a similar one HT95 lists IC501 as the output amp chip. Check for the marking on the large black IC attached to the heatsink it may be RSN311W. If so, this can be ordered using part number: RSN311W64D-P for $95.20 from tritronicsinc.com.
Hope this helps,
Dan
Aug 28, 2008 | Panasonic Home Theater System System
Error Message
The F61 indicates a problem detected in the output amp stage and the unit us shutdown to prevent further damage. If you can supply the model number, I can give you the part required and the approximate cost.
Dan
Jul 15, 2008 | Panasonic Home Theater System System
189 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
