Question about Bosch Axxis+ WFR 2460 Front Load Washer
"door open?" alert will not go away even thought the door is shut firmly is there is nothing blocking the door.
  • 2 more comments
  • Anonymous Nov 25, 2008
    I have the Bosch Axxis WFR 2460 and have the problem of the "door open" fault.
    I replaced the electronic door latch but the issue still exists. What else would be present in the circuit that could be broken/replaced to make the washer serviceable?
    I have lots of soldering skills and can do just about anything, I just need to know where to look
  • digitalarmsd Nov 25, 2008
    I have the Bosch Axxis WFR 2460 "Door open" problem and replaced the electronic door lock. The problem still exists.
    What else could cause the problem. The switch has power going to it. Is there any other sensors that are in the circuit?
    I can do almost anything and have great soldering skills so if anyone knows where to start let me know.
    Thanks,
    Dave
  • Anonymous Feb 21, 2009
    I have the same problem and I want to know how can I replace the fault...
  • monahan1958 Mar 15, 2009
    I too have a bosch axxis wfr 2460 "door open?" alert . I too replaced the door latch mechanism, and still get the same "door open?" alert. What to do?? what to do??
This washer has a built in self diagnostics feature.
What you do is: With the selector knob in the off position, press and hold the "menu & select" buttons, then turn the selector knob to the "permenent press cold" until the display comes on. This puts you in the diagnostics mode, in which the last 8 errors codes will be displayed. At this point the display should read:
START-MENU T1:ERRORS
LA-Er:-------.
It gets a little hard to explain from this point on, but in my case I was able to scroll through the errors using the menu button, and I found that the were 7 errors related to the "FLOW THROUGH SENSOR".
I had already replaced the door latching mechanism without results.
Now I am going to replace the flow through sensor and see if that works, I will let you know what happens.
I have in depth information about the Axxis wfr2460 that will most likely be very helpful to owners of this machine, but I don't know how to attach it to this forum, so if you like, contact me: monahan1958@yahoo.com and I can send you the info that I have found. It explains the whole testing procedure as well as defining the error codes, which may save a lot of frustration in solving your problem.
Posted on Mar 24, 2009
I have this problem too. I didn't fix it but found a work around. If I push start before closing the door and then then close the door after it starts beeping and giving me the "door open" message, it starts.
Posted on Jan 14, 2010
  • 20 Answers
The electronic door lock is faulty. Door latch
Part Number: AP2822758
made by BOSCH
is the part, it cost about $50 and goes behind the front panel where the latch connects
Posted on Nov 20, 2008
    Genius:
  • 1,122 Answers
Have you tryed unplugging it for 5 minutes to see if it will reset itself?let me know-mike
Posted on Oct 31, 2008
2000 Ford Explorer back door driver side door WILL NOT unlock
For this type of problem I recommend YouTube. Always a wealth of information on rear gates door locks etc.
Google > YouTube 2000 Ford Explorer door locks
Oct 08, 2017 | Ford Cars & Trucks
I can't get the alarm ding to stop. this is the alarm that occurs when a door might be ajar.
if the door light is also on inside the inst cluster then yes a door is ajar (even thought you may not think so) , go back and open all doors even the back one shut firmly and see if it "feels right" also look into door jam of each door and see if any projected switches are maybe damaged , switches look like small mushrooms flat top narrow shaft sometimes covered with a rubber boot . these can get caught and bent on shoes and stuff as it's being loaded and unloaded easly
Jun 01, 2015 | 2005 Chevrolet Uplander
Lg intellowasher wd1074fb
When you see the DE error code, it means a "door error". This is a sign that either the door is not shutting, locking or opening. Most of the time, this is a simple fix and service is probably not needed. Check for something stuck or lodged in door. Check door gasket. Check door latch.
May 13, 2014 | Washing Machines
Interior lights flicker on and off with warning that doors are open sign on dashboard comes on at same time
Open each door (one at a time) with the car running and parked.
Look for the small contact switch that tells the car the door is open/shut.
See image for location.
Press that switch in firmly and watch the dash to see if the light comes on while you are pressing.
This will tell you which one of the switches is bad.
Mar 18, 2014 | Suzuki Grand Vitara Cars & Trucks
Freezer Door
There is usually some adjustment on the hinges. Your is termed buttbound, the door at the hinges is too close so it makes the door pop open. Take everything out of the inside door shelves if there are any. Slacken the mounting screws a little and pull the door away from the frame, make sure it sites square and tight, and then tighten up the mounting screws. With a freezer, i would also suggest fully defrosting it first.
Mar 15, 2017 | Refrigerators
My refrigerator beeps every five seconds...then repeats in a minute. I checked that both doors are shut and nothing is blocking the shutting doors.
try checking to make sure the door button is not stuck when you open the door. The beeping means the indicator is reading an open door. Also check the freezer side.
Jul 11, 2011 | Frigidaire FRS3R5EMB Side by Side...
DRYER DISPLAYS CODE F22. What does this mean?
"F22" is a door lock issue Press the "Stop" button twice to cancel the cycle if "F22" shows. Check that the washer door is firmly shut--open it and shut it and try again. Make sure there aren't items blocking the closing of the door. Don't overload the basket. Try the cycle again.
Nov 25, 2010 | Kenmore Elite HE3 Steam 8674 Dryer
Freezer door pops open
there's nothing wrong w/your dr seal. add a then layer of silcone or vaseline to the seal. this will make it sticky again.
Jul 14, 2009 | Refrigerators
The soap dispenser opens but the soap is not dispensed and the dishes do not get cleaned. Can you help?
Make sure that there is nothing blocking the soap door from opening fully when the dishwasher is shut. This happened to me and I also thought that the soap door was opening during the cycle when it actually only partially opened during the wash and then popped open fully when I opened the dishwasher at the end of the cycle. So some, but not all, of the soap was used.
Dec 28, 2008 | LG 24 in. LDS 5811 Built-in Dishwasher
Freezer Door Won't Stay Shut
OK LOOSEN THE HINGE THAT SUPPORTS THE FREEZER DOOR.IT'S ON TOP AND HAS 3 SCREWS .JUST LOOSEN AND NOT REMOVE THEM.NOW LIFT UP THE DOOR UNTIL IT LINES UP EVEN WITH THE OTHER DOOR.AT THE SAME TIME TIGHTEN ALL 3 SCREWS. YOUR DONE!!!
PLEASE RATE THIS. THANX!!
Jun 06, 2008 | GE GSS25QSTSS Stainless Steel
Bosch Axxis+ WFR 2460 Front Load Washer Logo
972 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
